Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 2nd of June 2009 (Tue)   #1
texaskev
texaskev's Avatar
Default I’m shooting Robbie Knievel – Metering Mode Advice Needed!
I’ve shot several motorcycle jumps and motorsports in general. But on June 12th I’m shooting Robbie at 11pm at night. Not sure how much light will be available. I’m guessing that I’ll have a brightly lit guy (in white leather jump suite) with a black background. I’m only going to get one crack at this so here is my question:
- Evaluative Metering or Partial Metering?
I’ll be in AI Servo and automatic AF Point mode.
Many thanks for any advice!
Kevin
texaskev is offline   Reply With Quote
Old 2nd of June 2009 (Tue)   #2
HutchPhoto
HutchPhoto's Avatar
Default Re: I’m shooting Robbie Knievel – Metering Mode Advice Needed!
Kevin I can't help you out there Sorry. Where is he doing his jump?
~ Tim ~
GearList
HutchPhoto is offline   Reply With Quote
Old 2nd of June 2009 (Tue)   #3
amitch
amitch's Avatar
One focus point, the one on the rider. And of course use RAW.
Cheers Alex.....
amitch is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #4
Semmonka
Semmonka's Avatar
I would go to manual mode. Meter the ambient just before the event if you want some detail on BG. You will need hi ISO. Use fill flash to make the rider pop more.
I think in manual mode you will get consistent exposures.
Also I would use only cross type AF points as they are more sensitive
Just remember to post the results
Vesa
"Opinions are like a$$holes, everybody has one"
Flickr | MM
Semmonka is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #5
texaskev
texaskev's Avatar
He's jumping 3 trucks end to end in Austin Texas on June 12th at 11pm at a huge bike ralley that is held every year. Should be a good show!
http://www.txcn.com/sharedcontent/dw....1c84eac2.html
Thanks for everyones advice.
Old 4th of June 2009 (Thu)   #6
HutchPhoto
HutchPhoto's Avatar
Thanks Kevin!
I will do my best too get out there too see this.
~ Tim ~
GearList
Old 5th of June 2009 (Fri)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
I wouldn't expect the light at that time will be changing? Find something white in the scene near where he'll be, shoot it & chimp the histogram to the right. Something like this ref's white shirt:
Need an exposure crutch?
I don't trust that. With my 20D, I'd switch the camera to Custom Function 13-1 to put point selection on the Multicontroller (Joystick), & life with AI Servo becomes a lot easier. It only takes a fraction of a second to set the point you need.
OTOH, if you're a long way away & don't have a long tele lens, I might set the focus & then switch to manual focus.
This would work. You'll be surprised at how far it will reach out at f/2.8. BUT, I'd run a test beforehand & only use it on manual because, believe it or not, it's possible that you could overexpose with it on auto.
Read post #3
Tips for Xmas Ball Please
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
30D Focus mode & Metering mode advice... theboyk Canon EOS Digital Cameras 5 27th of March 2008 (Thu) 10:28
Advice for shooting snow scenes with my XTi which lacks spot metering? St. Germain Canon EOS Digital Cameras 7 14th of January 2007 (Sun) 09:51
Wedding setup and mode dilemma– advice needed cmo Weddings and Other Family Events 7 5th of September 2006 (Tue) 12:38
I need some basic advice..AF mode, metering mode .. xxbodkinxx Macro 3 6th of July 2006 (Thu) 23:16
Advice Needed on Through the Glass Shooting DocGeoff Canon G-series Digital Cameras 1 28th of May 2004 (Fri) 06:09
