Reply
Thread Tools Display Modes
Old 27th of April 2005 (Wed)   #1
raylks
Default Tripod ring for 70-200mm f4L
I am planning to purchase one. When I look at amazon.com, it said that the tripod ring is designed for 70-200 f4, 300mm f4, and 400mm f5.6. Hey guy, I have the 300mm f4L already but I cannot fit the tripod ring in my 70-200mm f4L!
The tripod ring on my 300mm f4L is tripod ring B, but the listed triod ring is tripod ring A. What's the difference?
Ray
www.fotop.net/raylks
raylks is offline   Reply With Quote
Old 27th of April 2005 (Wed)   #2
gasrocks
gasrocks's Avatar
Default Re: Tripod ring for 70-200mm f4L
Tripod Ring A & B are different things - different sizes for different lenses. Yes the tripod ring for the 70-200/4 is the same as the one you get if you buy a 400/5.6 L. The ring that comes with the 300/4 L IS is different - will fit the 100/2.8 USM macro if you get an adapter from Canon. Some lens come with rings/collars, some don't. Sort of like hoods. Some do, some don't.
gasrocks is online now   Reply With Quote
Old 28th of April 2005 (Thu)   #3
norcal99
I bought the Tripod Mount Ring A(B).. the black one for my 79-200 f/4. It's supposed to only fit the 200 f/2.8L but it fits fine. I'm assuming hte A(A) is the white one? It should fit...
Canon EOS D60 w/ BG-ED3
Canon EF 50mm f/1.8 mkII
Tamron 28-75mm F/2.8 XR Di
Sigma 70-200mm f/2.8 EX HSM
Sigma EF-500 DG ST Flash w/ omnibounce
norcal99 is offline   Reply With Quote
Old 28th of April 2005 (Thu)   #4
gcogger
The 300 f/4 L uses Tripod Ring A, the same as the 70-200 f/4 and 400 f/5.6 L.
The 300 f/4 L IS uses Tripod Ring B (same as 70-200 f/2.8 )
gcogger is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
70-200 F4L tripod ring DegasGoneDigital Canon EF and EF-S Lenses 22 10th of April 2007 (Tue) 09:59
Canon 70-200 f4L with tripod ring??? jesusdelallata Canon EF and EF-S Lenses 18 3rd of August 2006 (Thu) 21:24
Tripod Ring question, 70-200 F4L aussieskier Canon EF and EF-S Lenses 7 17th of December 2005 (Sat) 13:53
Tripod ring for 70-200 F4L with 10D w/ Grip???? Won't fit Toogy Canon EOS Digital Cameras 6 17th of November 2004 (Wed) 14:58
