Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Motorsports Talk
Reply
Thread Tools Display Modes
Old 3rd of June 2009 (Wed)   #1
lordlardofframs
Default Sports Shooting
Hi all,
I thought I would take this opportunity to say Hi as this is my first post on the forum and to ask for some help at the same time.
My son has asked if would take some photo's at his local r/c car club this week.
I have posted this pic i found on another forum to give you some idea
http://i706.photobucket.com/albums/w...rams/r3005.jpg
I have a 350D body and the largest lense I own is a f2.8 70/200
Your suggestions for settings to get the sharpest high speed action shots would be greatly appreciated.
Darren
Last edited by In2Photos : 3rd of June 2009 (Wed) at 14:28. Reason: Change image to a link
lordlardofframs is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #2
canonloader
canonloader's Avatar
Default Re: Sports Shooting
You will need good light to get a high shutter speed. High shutter speeds are the only way to get sharp shots of moving objects without flash. You can use flash to stop action also, not because the shutter speed goes up but because the flash is so fast. Better get some practice though.
Mitch- ____...^.^...____
My Microscope Stuff
Gear List, My Flash Gallery, My You Tube, Ride My Bi-Sickle
canonloader is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #3
Thalagyrt
D'OH. I need to wake up some more.
Thalagyrt's Avatar
Indoors, outdoors? That really factors in a lot in which type of settings you should use. Considering the cars are small, you should be able to shoot just fine at f/2.8 or 3.2 and still get the whole thing in focus. I'd meter the ambient light of the track, set a manual exposure for that that gets you a shutter speed of around 1/500th of a second or higher, and go from there. That's what I do at NBA games.
James
Gallery
Thalagyrt is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #4
In2Photos
Moderator, Archive Keeper
In2Photos's Avatar
Hi Darren, welcome to the Forum. I'm sure there will be plenty of helpful folks to come along and provide you with help. That being said please take a look at the Forum Rules regarding posting of images. Any images that do not belong to you should be linked and not embedded.
http://photography-on-the.net/forum/...ad.php?t=51022
Enjoy your time here!
In2Photos is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #5
jwelch761
Holy hell, independent disc brakes?? What scale is that? I got out of 1/10th scale nitro about 3 years ago and my RC10GT never had four disc brakes!
jwelch761 is offline   Reply With Quote
Old 3rd of June 2009 (Wed)   #6
lordlardofframs
Ooops really sorry,
I hope you forgive me as I am new!! very humbled.
The shooting will be outside and flash will be permitted. Any suggested settings??
Old 3rd of June 2009 (Wed)   #7
lordlardofframs
Default JWELCH761
The r/c cars with the hydro bakes are ll 1/5th scale, 26cc petrol engines. Rapid to say the least
Old 3rd of June 2009 (Wed)   #8
Thalagyrt
Thalagyrt's Avatar
If you're outside during the day you really won't need a flash. How far away will you be? How big are the cars?
James
Gallery
Old 3rd of June 2009 (Wed)   #9
lordlardofframs
The cars are 1/5th scale so about 700mm long, traveling at 30/40mph distance I will be shooting is from 5m min to 30m max
Old 3rd of June 2009 (Wed)   #10
Thalagyrt
Thalagyrt's Avatar
My thoughts are to shoot at f/4 so you have some margin for error on the focus, and use whatever ISO is necessary to have your shutter speed be above 1/500th of a second and you should be golden then. Absolutely make sure you're in AI servo for this, using the center point as it's your most accurate point.
James
Gallery
Old 3rd of June 2009 (Wed)   #11
lordlardofframs
Thanks guys, will show you my attempts (very nervously) at the weekend
Old 3rd of June 2009 (Wed)   #12
In2Photos
In2Photos's Avatar
I'm going to disagree with James.
I would treat this as shooting motorsports instead of field sports. Use a slower shutter speed and pan to give a sense of motion. Otherwise it will look like the car is setting still. You could put it on the track with the car turned off and get the same shot.
Check out some of the threads in the motorsports shaing section adn see what others are using (probably low ISO, f/10ish, and 1/50-1/100 along with a good panning technique).
Old 3rd of June 2009 (Wed)   #13
In2Photos
In2Photos's Avatar
So maybe I'm not right on this one!
I took a look at some of the RC shots on here and most are using a high shutter speed and still getting plenty of motion in the shots. Who knew? Oh yeah, James did!
Old 3rd of June 2009 (Wed)   #14
lordlardofframs
I am so glad to see that even the mods can get it wrong sometimes
Old 3rd of June 2009 (Wed)   #15
Thalagyrt
Thalagyrt's Avatar
Haha, Mike, I'd imagine either method would work with the right technique! I was just speaking from my experience, which really is very different from motorsports.
James
Gallery
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
when shooting sports umphotography Sports Talk 8 17th of December 2007 (Mon) 16:34
Shooting sports psuphoto09 Sports 11 18th of May 2007 (Fri) 21:29
New to shooting sports... michaelsink Sports 1 12th of May 2007 (Sat) 17:21
More Shooting Sports M4gery Sports 1 16th of July 2006 (Sun) 18:47
