Thread started 06 Jun 2009 (Saturday) 00:37
Prev/next
Best tripod under $100ish bucks?
AprilArchambeau
Martinsburg, Wv
Jun 06, 2009 00:37 |  #1
I need a tripod, I bought a POS one from Walmart and learned the hard way, its decently put together, however, with my lens on it its too top heavy and tilts down. I found a ton on B&H and Adorama website but I do not know which are better, post any you have experience with in that price range please :)
April
www.AprilArchambeauPho​tography.comexternal link
5D l Calumet Genesis 400 light kit (2) l 430EX II l 50mm 1.8 l 70-200 f/4L IS l 85mm 1.8 coming soon!
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Jun 06, 2009 06:50 |  #2
Under $100? There really isn't a "best", only a "least worst" in that group. What camera and lens are you trying to carry? You might try looking for an older Manfrotto 3001 or 3021 with their 488 ballhead, selling used on here, eBay or Craigslist.
Jon
Cocker Spaniels
René ­ Damkot
René Damkot's Avatar
enschede, netherlands
Jun 06, 2009 07:12 |  #3
Agree. Buy used.
Why Color Management.
Color Problems? Click here.
MySpaceexternal link
Get Colormanagedexternal link
Twitterexternal link
5Dmaniac
5Dmaniac's Avatar
Scottsdale, AZ
Jun 06, 2009 07:37 |  #4
There is no decent trippod for under $100 - sorry. You are better off saving some more - whatever you buy for less than $200 will be crap.
squiress
squiress's Avatar
Denver, CO
Jun 06, 2009 08:26 |  #5
Here you go. Probably better than anything you'd find in a Wallymart or the like and they will respond to issues. Aluminum and durability will be an issue from now until it finally fails a couple years out, but I think it will serve.
http://cgi.ebay.com ...ViewItem#ebayphotoh​ostingexternal link
My Stuff
Thoughts-Tripods-Ballmounts-Teardown(TD)Benro KB2 Ballmount
TD Weifeng FT-565H Ballmount-TD Benro C128, C328n6 Tripods
TD Dynatran AT-A105T Tripod-TD Benro MC-68n Monopod
Ralph ­ Merlino
Jun 06, 2009 08:37 as a reply to squiress's post |  #6
I would have to agree with all above.
katodog
katodog's Avatar
Carol Stream, Illinois
Jun 06, 2009 08:40 |  #7
This is so not true. You can find plenty of great tripods for around $100. But, you have to realize it's not just the tripod, it's the head too.
For example, Dolica Prolineexternal link tripods are built pretty good, and they are strong. I have one of the carbon fiber models, and am very happy with it. If you get one with a ball head, you will probably want to swap it for a stronger one. The ball head that came with mine was just enough to hold up my gripped bodies with the Sig 150-500mm, but only if I really tightened it down. I put a Cullman Magnesit 35Nm on the tripod, and it works like a charm. The ball head that came with the tripod is actually a nice one, but I prefer the better design and ability of the Cullman. I put the Dolica ball head on my monopod.
Depending on what you put on top of the Dolica ball head though, it could be more than enough. The tripod is definitely a good deal. I bought mine when it was on sale, and I paid $100 for it. I think otherwise the model I have was around $150 or so, still a good price. The only thing I had a problem with is the lock for the center column, it has a compression fitting for tension and wouldn't lock down tight enough to prevent the center column from spinning when trying to change heads. So I did what any mechanically-minded person would do, I drilled a hole through the center column and put a nail through the hole.
Of course, that was after I cut the center column down to allow the tripod to reach ground level. I did that for a few reasons. One reason is that I don't normally use the center column. If I need more height, I use my DynaTran tripod, since the center column on that is rock-solid no matter how much I extend it. The other reason is that I wanted to get the tripod lower for macro shooting.
But, long story short, Dolica Proline is a good tripod and it's not expensive. As Squiress posted, look at DynaTran too. Great tripods, basically knock-offs of the "name brand" tripods, but equally as tough. I love my 858, it's solid as a rock, and the only thing that's a drawback is the weight of it. Otherwise, it's strong, tough, and can be adjusted into many positions, just like the more expensive tripods.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
mufutau55
mufutau55's Avatar
Bronx, New York City (USA)
Jun 06, 2009 08:47 as a reply to katodog's post |  #8
Not under $100 but $130, it's one of the best buy in tripod.
SLIK PRO 700DX.
http://www.bhphotovide​o.com ...ro_700DX_Tripod_wit​h.htmlexternal link
Mufutau
tvphotog
tvphotog's Avatar
New York City
Jun 06, 2009 10:24 |  #9
mufutau55 wrote in post #8060138external link
SLIK PRO 700DX.
Mufutau
+1.
Slik makes extraordinarily good tripods for reasonable money. They have a long and good reputation. They're handled by B&H which I feel is a very good sign. I recently bought an inexpensive table top tripod from them, and found it was constructed as well as any big tripod I've seen. I also had the cf614 bought from B&H, and was very happy with it, and when I got heavier gear, I sold it for not much less than I paid for it.
These sticks in the above link are heavy, that's the only drawback. Remember the adage: There are three things you want in a tripod. Light weight, stability, and low price. But you can have only 2 out of 3.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Powershot S100 | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
AprilArchambeau
Martinsburg, Wv
Jun 06, 2009 10:52 |  #10
Possibly a grip in the future, but the heaviest lens I will have on it will more than likely be just a 55-250, probably nothing more than that. So I should be able to find something that will hold just that :)
René ­ Damkot
Jun 06, 2009 14:53 |  #11
Remember: A tripod is not about "holding" but about "holding still". Two different things.
My Gitzo 1325 will support me (roughly 70kg's) but it is only stable enough for up to about 400mm unless I'm careful, and conditions are good...
Pommekitty
Pommekitty's Avatar
Vosges, France
Jun 07, 2009 08:59 |  #12
+1 with the Slik comments above. I've found they sell great products.
I have a Slik Sprint Pro II which I bought for 70€ and I couldn't be more pleased with it. It's light to carry around but sturdy enough to support my 40D+70-210mm zoom without problem (however, I mostly use it with my lighter 1000D + 18-55mm). It comes with its own head and quick release plate. I often take it to shoot in the mountains and have had no problem in windy conditions.
5DII -- 1000D // 50 1.8 -- 24-105L -- 135L -- 70-210 USM
http://www.n2dphotogra​phy.com/external link
mangaloreaviators
mangaloreaviators's Avatar
Jun 08, 2009 16:23 |  #13
Check the Tripod Sticky
http://photography-on-the.net/forum/showthre​ad.php?t=681408
TexasStalker
Jun 08, 2009 16:44 as a reply to mangaloreaviators's post |  #14
What is there to consider when looking for a tripod? What makes one from Wal-Mart a bad choice?
tvphotog
tvphotog's Avatar
New York City
Jun 08, 2009 17:44 |  #15
TexasStalker wrote in post #8073145external link
Read the stickey. If you spend $100 on a cheap tripod that breaks or shakes, you're out $100. If you buy a $250 tripod that works for a year or two and falls apart, you're now out $350. If you buy a good tripod and use it and want to upgrade, you can sell it here and get near what you paid for it.
There are some excellent Manfrotto tripods for not much more than $100. They're heavy, but stable. You can also sell them for close to what you paid. Don't get a Wally World tripod.
Jay
21,916 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.0013 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is Z28Camaro
885 guests, 321 members online
