Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Photography Industry News
Reply
Thread Tools Display Modes
Old 7th of June 2009 (Sun)   #1
Brianbar
Default New factory
Canon are building a new factory in Japan, lets hope they will have better QC.
Brian
http://www.photographyblog.com/news/...tory_in_japan/
Brianbar is offline   Reply With Quote
Old 7th of June 2009 (Sun)   #2
john-in-japan
Default Re: New factory
Being particularly pleased with current QC, would assume the new plant would not result in it being worse. First new plant for them in 27 years. Maybe from money saved from not buying chairs? Ha! Ha!
John
JohnW
5D Mark II Dual Battery Grip, 100-400f/4-5.6L, 200 f/2.8L, 70-200 f/2.8L II IS, 24-70 f/2.8L 180Macro f/3.5L, 85 II f/1.2L, 17-40 f/4L, 50 f/1.4, 50 f/2.5 Compact Macro, MPE-65, 550EX, 580EXII, Canon RingFlash, RRS Perfect Portrait Pkg., Velbon with PH275 and Slider, bunch of filters, Canon 1.4X & Having Fun! http://kamogawa.smugmug.com/
john-in-japan is offline   Reply With Quote
Old 7th of June 2009 (Sun)   #3
alt4852
alt4852's Avatar
John
no the money saved from the chair budget went into the motion speed detectors in the hallways.
5D3 | 5D2 | Z21 | 35L | 50L | 85L | 135L
alt4852 is offline   Reply With Quote
Old 8th of June 2009 (Mon)   #4
Desertraptor
Desertraptor's Avatar
New factory built for new techology?
Easier to build new than refit old?
Peter
Canon 60D|40D|10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8L|70-200mm f4L|100-400mm f4.5-5.6L |430EX II
Desertraptor is offline   Reply With Quote
Old 25th of June 2009 (Thu)   #5
elisesanchez
Japan is a pretty small country. I wonder if they could have retrofit an older factory.
elisesanchez is offline   Reply With Quote
Old 17th of July 2009 (Fri)   #6
Bodog
Bodog's Avatar
Hey, don't forget all the R&D that went into that "print" button...
JimE
Color? It's all relative...
Bodog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
At the factory Anthony_S Still Life, B/W & Experimental 2 9th of January 2008 (Wed) 07:49
Factory Demo? SKCIH Canon EOS Digital Cameras 27 19th of December 2006 (Tue) 20:32
The Factory Anthony McAvoy Urban Life & Travel 6 7th of December 2006 (Thu) 01:09
Local Factory madpup Nature & Landscapes 6 28th of October 2006 (Sat) 18:25
Factory (2-14-06) i7137 Urban Life & Travel 3 17th of February 2006 (Fri) 00:23
