Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 30th of April 2005 (Sat)   #1
MenionLeah
Default Need advice on my 300D and sports photography
I recently bought a 300D and am having problems getting quality shots/action shots. We've started by using the default action/sports setting, but i'm not real happy with the results. I know they're are just presets, etc.
I'd really appreciate if someone could share some advice on settings, etc. for action shots in average conditions.
I've seen the great action shots that this camera is capable of. But it's obvious to me that the action preset is not the best way to go.
I'd appreciate any advice.
Thanks.
MenionLeah is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #2
tim
Light Bringer
tim's Avatar
Default Re: Need advice on my 300D and sports photography
What's not working for you? Can you post samples of pics you think are bad?
tim is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #3
Skippy29
Skippy29's Avatar
Try a shutter speed of 800 or 1000th of a sec @ about f/8 on a sunny day and go from there.
I personally like the sports mode on the dial, except that the constant focus seems to be fooled once in awhile.
Skippy29 is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #4
Kennymc
Kennymc's Avatar
More info on lens and shutter speed used would be required to give positive advice...
Kennymc is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #5
MenionLeah
Thanks everyone.
Basically, what i'm asking is, what would be a good point to start at in one of the other modes?
For sports, should i shoot in Tv mode so that i can control the shutterspeed or should i shoot in Av so that i control the aperture value?
For instance, my sons game tonight will be at 6 p.m. in very cloudy conditions.
What settings may be a good starting point?
Thanks.
Old 30th of April 2005 (Sat)   #6
Kennymc
Kennymc's Avatar
Shoot in AV with the lens set to its maximum aperture then you can be sure the camera will choose the fastest shutter speed possible...
Old 30th of April 2005 (Sat)   #7
Kinger
Kinger's Avatar
Well that also depends on what lens you have. I personally like controlling the shutter speed, which means Tv mode. Then because you are talking a cloudy condition, adjust the ISO to achieve the desired shutter speed. Also check the historgram, since you are going to be using a high ISO make sure you expose slightly to the right. A brighte shot will appear to have less noise then darker ones. Just check out the dolphin pics on the link in my signature, those were done with ISO 1600.
Stephen King
Drebel, EF 17-40L, EF 50, EF 85, EF 100-400L, 550 EX
http://home.comcast.net/~king247 (randomly changing)
Kinger is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #8
gasrocks
gasrocks's Avatar
I agree. Forget the presets. As soon as you use the word sports or action - you hand should be turning the dial to TV, adjusting the speed to the action. Yes, watch what f/ you wind up at and bump the iso up a bit if you'd like more DOF. Good, fast lenses always help, too.
gasrocks is offline   Reply With Quote
Old 30th of April 2005 (Sat)   #9
Jetmech1
I've had better results shooting Av mode at a higher ISO setting. The only advantage to using the SPORTS mode is the camera will use AI Servo. You may want to experiment a little to see what works best in your shooting conditions. What Lens are you using?
Canon Rebel XT (350D) W/Generic Grip - Canon 17-40mm L - Canon 75-300mm IS lens - Canon 85mm 1.8 Prime - Olympus SP-570UZ (Point & Shoot)
Jetmech1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sports Photography- Need Advice snavlee Sports Talk 6 2nd of November 2006 (Thu) 13:01
Need advice on a good lens for sports photography Q20D Sports Talk 7 27th of January 2006 (Fri) 17:00
advice on sports /event photography magmac21 The Business of Photography 9 16th of November 2005 (Wed) 08:40
300D. Overexposure in sports mode mcklemme Canon EOS Digital Cameras 14 30th of August 2005 (Tue) 02:26
300D Sports mode limitations Sherpa Canon EOS Digital Cameras 2 4th of October 2004 (Mon) 11:25
