Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 13th of June 2009 (Sat)   #1
XR3ste
Default First AIRSHOW tips
Hopefully i will be attending my first airshow with my EOS 400D tomorrow and wondered if anyone has any good tips on settings and practices for getting good results of the aircraft in the air. in terms of settings would i be best with a center wieghted metering setting, so that the cammera will set itself for the aircraft and not the sky around it, and what speed do i use etc etc etc thats the sort of thing im thinking through. I will be taking my 70-300 is lens for the in-air shots and my 18-55 is lens for the static shots, and plenty of memory and batteries. Any advice would be verty much appreciated
XR3ste is offline   Reply With Quote
Old 13th of June 2009 (Sat)   #2
aviator.4.life
aviator.4.life's Avatar
Default Re: First AIRSHOW tips
I think you may have better luck in the Transportation section. Anyways, I love to do panning shots when they're low to the ground. What airshow is this?
"Climb like your life depends on it....because it does."
-O'Hare ATC
aviator.4.life is offline   Reply With Quote
Old 13th of June 2009 (Sat)   #3
phoenix54
A good start here:
http://digital-photography-school.co...-for-beginners
Jim
phoenix54 is offline   Reply With Quote
Old 13th of June 2009 (Sat)   #4
Medic1
Medic1's Avatar
I am not sure what you skill level is or what your comfortable with but I find that using manual for airshows is what works best if you have somewhat consistent sky. Just set your exposure either metering off the grass or grey tarmac and then make sure you recheck your exposure every 20-30 mins. The in camera meter is easily fooled in alot of situations and you will end up with nicely exposed sky and underexposed aircraft.
I try to keep my shutter speeds up as high as I can get them with jet aircraft....prop jobs I try to keep it low to get some of the blur from the prop otherwise you will end up with an aircraft that looks like its stalled in mid-air.
Medic1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Airshow Tips JeffreyVB General Photography Talk 3 9th of August 2008 (Sat) 14:55
airshow tips Kaya75 General Photography Talk 3 26th of June 2008 (Thu) 19:48
Airshow tips stp72 Canon EOS Digital Cameras 3 22nd of June 2008 (Sun) 10:01
Can I get some tips for shooting an airshow? TMR Design Small Compact Digitals by Canon 5 24th of August 2006 (Thu) 17:20
Tips to shoot airshow Amorous Transportation 16 17th of May 2006 (Wed) 15:04
