Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Performing Arts Talk
Reply
Thread Tools Display Modes
Old 20th of June 2009 (Sat)   #1
Doemasters
Default I have a photo pass for tonight
and was wondering what the best setting would be to keep my cameras on for low light.
I have a 40d and the eos 5d mark2
lenses are 24mm 1.4
70-200 2.8
85 1.2
thanks for any suggestions, will keep looking around in this forum for ideas
Doemasters is offline   Reply With Quote
Old 20th of June 2009 (Sat)   #2
rgs-
rgs-'s Avatar
Default Re: I have a photo pass for tonight
you pretty much have the ultimate low light combo w/ the 5d2 and 85 1.2. you should do quite fine
Ryan
www.ryansaundersphotography.com
stuff: 5DII : 1DIII : 17-40L : Σ50 1.4 : 135L : 70-200 2.8L IS II
rgs- is offline   Reply With Quote
Old 20th of June 2009 (Sat)   #3
Doemasters
thanks, what setting should i put the camera on
Old 20th of June 2009 (Sat)   #4
narlus
narlus's Avatar
what sort of show is it? how large is the venue? will there be a photo pit? what is the band like?
those are all good questions worth knowing the answers to prior to setting foot in the venue.
i am not sure what your shooting style is, but if it helps here's what i do.
start @ ISO 1600 in M and i use partial metering
shoot @ f/2-2.8 or so and check the histogram to see what the exposure looks like...hopefully you will have shutter speeds of 1/100 - 1/250.
you could use spot metering and zoom in on a face to get a reading there as well.
don't be afraid to shoot 3200 ISO w/ the 5D2 or even higher if you really need it. it controls noise very well.
narlus is online now   Reply With Quote
Old 20th of June 2009 (Sat)   #5
Bobster
Bobster's Avatar
depending on the venue, you'll be shooting ISO800-ISO3200/6400
always 2.8
shutter can vairy from 1/30-1/200
you're at the mercy of the Lighting Tech
Robert Whetton Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood | Gear | Tweet | Google+ | Get your focus spot on
Bobster is offline   Reply With Quote
Old 20th of June 2009 (Sat)   #6
niqqunos
niqqunos's Avatar
lenses are 24mm 1.4
70-200 2.8
85 1.2
Wow, are you kidding me? Did you find all that gear somewhere?! :P
Any of the lenses will handle the lighting conditions, just depends on how far away you are and what the lighting tech decides to do!
Personally, I'd give the 70-200 and 5D2 combination a go... use a higher ISO setting and 2.8 so you've got control over the focal length without having to change settings on the fly. If the band is moving around a lot, stick to 1/160 to 1/200 shutter and you should be fine.
Or, I'll swap my setup with you and you can use a very handy 350D and 50mm 1.8 which should be more than fine and I'll use your gear!
Dan
Daniel Kell
Gear List | [danielkellphotography] | my Flickr | citiesoftherednight
niqqunos is offline   Reply With Quote
Old 21st of June 2009 (Sun)   #7
Doemasters
Had to leave before i saw the advice but i got some decent shots i think. I mainly stayed with the 5d mark11 and the 700-200mm lens. It was at a festival and I was down in the pit and tried shooting in av mode at first because i read about alot of people using that but the pictures were to hot the whole time, like one of you said it may have been the light guy killing me. I turned to tv mode during the show and the pictures seemed to be a little crisper. Maybe next time i will just shoot some all til i get the hang of it. Thanks for the help. Here is 2 pictures below
Old 21st of June 2009 (Sun)   #8
Bobster
Bobster's Avatar
looks like you did well for your first outing
1st pic is very hot, need to reduce the exposure by about 1/2 a stop
no exif?
Old 21st of June 2009 (Sun)   #9
Doemasters
i didnt take it off, i actually uploaded straight from the card
Old 21st of June 2009 (Sun)   #10
Doemasters
i forgot to shoot in raw as well, had my main memory card not work for some reason when i started taking pictures so i panicked
Old 21st of June 2009 (Sun)   #11
Bobster
Bobster's Avatar
DOH!
Old 21st of June 2009 (Sun)   #12
Doemasters
learned my lesson, just bought more memory cards this morning
Old 22nd of June 2009 (Mon)   #13
René Damkot
Moderator
René Damkot's Avatar
No. It was the cameras metering being thrown off by the large amount of black in the background. Get to know how your camera meters: http://www.canon.co.jp/imaging/enjoydslr/part2/2E.html
Should not make a difference exposure wise, unless you chose a shutterspeed that was so high that the camera couldn't open the aperture far enough to get what it considered a "good" exposure.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Photo Pass question / complaint veddderman123 Performing Arts Talk 8 11th of October 2009 (Sun) 23:10
Question Regarding a Photo Pass Agreement. bkothe Performing Arts Talk 41 29th of March 2009 (Sun) 23:40
P-51 photo pass adamsti Transportation 26 3rd of July 2008 (Thu) 01:31
my wife's first photo pass thelightofsound Performing Arts 4 1st of January 2008 (Tue) 20:19
Music Event Photo Pass Cross † Image The Business of Photography 2 17th of February 2007 (Sat) 21:56
