Thread started 22 Jun 2009 (Monday) 12:02
DIY Grey Cards
clams
Jun 22, 2009 12:02 |  #1
So I'm finally making the jump from Av to manual and i was wondering if there were any DIY grey cards to make my transition a little easier. I know that there are a ton available at my local photo shot but I'd like to try to make one myself first.
Canon 40D | Canon XTi SOLD | Sigma 30mm f/1.4 | Canon A-1 | Canon FD 50mm f/1.4 | Vivtar FD 28mm f/2.8
arkphotos
Jun 22, 2009 13:18 |  #2
I don't think Av-> manual will affect your white balance.
(sorry - i have no actual advise on a diy gray card)
1.6 crop & some lenses
Tixeon
Joined Oct 2004
Jun 22, 2009 13:38 |  #3
Personally I'd invest in a good Incident hand held meter or use the Sunny 16 rule if on a tight budget. You were referring to achieving correct exposures & not white balance - right?
check out my post http://photography-on-the.net/forum/showthre​ad.php?t=671277 for results of using the Sunny 16 rule - no meter or grey card involved............tw
Tim
______
Any cat owner will tell you -- no one really owns a cat...
PhotosGuy
Moderator
Joined Feb 2004
Jun 22, 2009 14:05 |  #4
White balance not ...balanced? What am I doing wrong?
number ­ six
"After 40 years still not housebroken, I still piddle on the carpet"
Jun 22, 2009 15:45 |  #5
Ummm, looks to me like clams is asking about exposure, not white balance. Which, of course, is the same in Av or M.
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
I do not piddle on the carpet!
clams
Jun 22, 2009 17:42 |  #6
Yeah i was referring to using the grey card to measure exposure. The exposure changes a lot in Av giving me weirdly exposed pictures when ppl with dark or light clothing pop up. I'd just like to set the exposure once for the light condition I am in and not have to worry about constantly compensating like in Av mode. The grey card I believe will help me with that. I mean, if I get really cheap, I could just meter off my hand...
Tixeon wrote in post #8154253 (external link)
That sunny sixteen rule looks interesting though. I'll try it out. My sigma 30 has f/16 as its highest aperature so I got lucky right there. But I think I'll need to just use a plain old meter if I want some shallow DOF.
SOK
Jun 22, 2009 18:59 |  #7
Hi,
I was interested by your post. It's not uncommon to hear people refer to 'making the jump from AV to Manual', but they often don't relate the jump to metering rather than exposure.
I hope you don't take this the wrong way, but I've found that those who don't understand shooting in Manual mode don't actually understand shooting in AV mode either.
I'm not suggesting you don't understand exposure...but judging by your post, it sounds like you've only really starting to give some thought to metering now that you're contemplating switching to Manual mode. (Forgive me if this is not the case, just my interpretation of your OP).
The thing is, metering works exactly the same regardless of whether you shoot M, Av, Tv, P, or G (Green Box).
I'm going to go out on a limb here and suggest that you would be better served by learning about, and experimenting with your camera's internal meter than mucking around with grey cards, incident meters and Sunny16 at this stage. (I'm not saying they don't have their purpose, but personally I prefer being able to shoot without relying on any of them to get consistent exposures).
First, if you don't 'get' the concept of in-camera metering, Cambridge In Color (external link) has a good intro article on it, but I suggest searching Google and POTN for additional resources.
Second, experiment. Put your camera in M mode, and choose spot metering (it helps to understand what spot metering refers to...consult your manual if you don't). Start with a middle-ish grey subject (it doesn't have to be exact...just close). Centre the needle, and make an exposure. Keep the lighting and camera settings constant, and then watch how the meter responds to different subjects. Choose a variety of things (black suits, white walls, green grass, blue sky) and eventually you'll learn how to 'see' the way your camera is seeing the world. Whilst it's undoubtedly rooted in science, there is a certain art in mastering in-camera metering that can only come from experimentation.
Steve
SOK Images - Wedding and Event Photography Gold Coast (external link)
PhotosGuy
Moderator
Joined Feb 2004
Jun 22, 2009 19:11 |  #8
That will be the next question? ;)
OK, so, this is what I use: Need an exposure crutch?
Why? Post #47
clams
Jun 22, 2009 20:33 |  #9
SOK wrote in post #8155926 (external link)
Hi,
I think I understand that aspect of metering pretty well. Matrix metering meters the whole scene with some funky averaging formula, spot meters that 3ish percent indicated by the circle in the viewfinder, partial meters off a bigger area than spot, and center does the whole frame with emphasis on the center of the frame. It's just the fact that the meter reads the changes in the scene constantly in Av mode and Tv, therefore changing exposure values constantly due to the semi-automatic nature of those modes. I think this is mostly right? Correct me if I'm wrong.
The main reason I'm trying to switch to manual. So that regardless if ten people with white shirts pop in, the exposure value will stay constant to how the light is hitting the subject. I thought that the grey card would help me out with metering the light that hits the subjects.
That link to the exposure crutch pretty much seems like what I'm looking for though. A question about that link to the exposure crutch though. It says that I should expose to the right. I'm pretty sure that that's a technique to retain highlight (or shadow?) detail but requires post processing in ACR. True? Untrue? Sorry for all the beginner questions.
toxic
Jun 22, 2009 22:01 |  #10
clams wrote in post #8156336 (external link)
If you know the "correct" exposure settings already, there's no need for a gray card. It just lets you do it with having to take a bunch of test shots.
Exposing to the right is to minimize noise and maximize the detail recorded in a scene. It can result in an overexposed-looking image.
On the Sunny-16 rule: All this means is outdoors in daylight, the "correct" exposure is about 1/ISO at f/16. If you are familiar with exposure, you should know this does not mean you must be at f/16.
Jon ­ Foster
is it safe?
Jun 22, 2009 22:03 |  #11
Clams, have read this book?
http://www.amazon.com …tal-Updated/dp/0817463003 (external link)
It's actually a pretty good read and may help you out a bit.
Jon.
I shoot with a Little Canon
Check out my photos @ PBase.com (external link) & ModelMayhem.com (external link)
number ­ six
Jun 22, 2009 22:52 |  #12
You're exactly right. The classic case is shooting a basketball game in an evenly-lighted gym. If you use Av or Tv you'll get different exposures on the guys with the white jerseys and they guys with the dark ones.
Very strange.
In this case, once you've got a good exposure (never mind the gray card, just take some test shots), use the settings of that good exposure in M and you'll be fine.
-js
"Be seeing you."
SOK
Jun 22, 2009 23:07 |  #13
No, no - you're spot on. Apologies if my first post sounded condescending, but it was hard to gauge your understanding of metering specifically.
What I was trying to get at was; where a grey card provides a reference for you to center the metering needle on, there are usually plenty of items within real-world scene that you can use instead of a grey card.
The key difference is that in most cases, you won't want to center the needle....but you do need to know where the needle should sit.
In your example of 10 people wearing white shirts, you could meter off the shirts and expose at just under +2 stops as a starting point. Or you could use Frank's venerable hand metering trick and expose for 1+ stop as a starting point. There are 'constants' for green grass, black suits, grey pavements and blue skies....it's just a matter of learning them!
Hope this clarifies my earlier ramblings!
Steve
tzalman
Fatal attraction.
Jun 23, 2009 02:57 |  #14
clams >> It says that I should expose to the right. I'm pretty sure that that's a technique to retain highlight (or shadow?) detail but requires post processing in ACR. True? Untrue? Sorry for all the beginner questions.
Yes, post processing is 50% of ETTR.
Elie / אלי
PhotosGuy
Moderator
Joined Feb 2004
Jun 23, 2009 10:13 |  #15
I chimp flat white to the far right. Somewhere in that thread I point out the difference between that & ETTR.
Different strokes for different subjects/applications.
4,373 views & 0 likes for this thread
DIY Grey Cards
Latest registered member is thisisntme
747 guests, 395 members online
