#1 |
When shooting the last airshow I noticed most of my pics all have the same bluish look to them. Will a UV filter help combat this problem? I am looking for something worthwhile as it is for my 400L. Thanks.
Canon EOS 30D / Canon 430EX | Canon BG-E2 Grip | Canon 400mm f/5.6L | Canon EF 70-300mm f/3.5-5.6 IS USM | Canon EF 28-135mm f/3.5-5.6 IS USM | Canon EF 50mm f/1.8 USM |
| sponsored links |
#2 |
A skylight filter is what you want to try. UV is filtered by the camera...it already has a UV filter just in front of the sensor. But I rather doubt it is the need for a Skylight filter to remedy the problem.
Did you have Daylight WB set, or were you relying upon the fickle AWB setting? Post a sample, and include EXIF data.
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php Last edited by Wilt : 22nd of June 2009 (Mon) at 16:19. |
#3 |
I have attached a sample that I only cropped in ps.
| sponsored links |
#4 |
How about editing the photo instead of using a filter? Not sure why there are two pictures?
Take Care, Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS Click Here To See My Gear Click here to see my Flickr |
#5 |
I only posted one, I see you posted two. I could edit it out, but I would rather get it straight from the camera. I have a hard time sometimes noticing color casts. I also would not mind some protection on the front of my 400L.
#6 |
I notice that your camera was set to AWB. It does seem bluish. Bumping the color balance via PP a small amount seems to bring it to a more neutral appearance.
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php Last edited by Wilt : 22nd of June 2009 (Mon) at 18:22. |
#7 |
If your photos are mostly shot in the same quadrant (like a runway approach), then a manual gray or white card reference WB would give you "faithful" results, although doing it in a crowded is easier said than done, especially if cloudy conditions are intermittent.
#8 |
That looked like a gloomy day. It may have been a matter of the subject not getting direct sun.
Average white balance is probably the last choice you want to use. If you think you need a warming filter, just apply a CC factor right in the camera. It will apply no matter what white balance method you use. |
#9 |
For me anyway, 13:30 is still high noon for this type of photo, and my worst aircraft in flight photos are between 09:00 and 15:00, so I agree RDKirk.
#10 |
yes. look at "uv-haze" filters -- some block more uv than others.
#11 |
There was a low cloud ceiling that day and the sun shined through from time to time. Thanks to everyone for the advice. So setting the WB to daylight may have helped?
#12 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
Looks to me like there was enough haze in the air that you really would have needed something like a Skylight 1A or even a Skylight 2 to take out the excess blue. With B&W aerial photography, the standard was a Wratten 12 deep yellow filter to cut the haze.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
#13 | |
#14 |
It looks to me like it needs editing in any case because the contrast is very low. There is nothing even close to black in the image. A single click on the paintwork with the WB dropper had the colour fixed and then it was a matter of deepening the blacks massively, dialing up clarity and vibrance and adding a little more sharpening to get this....
(results would look better with the original file to work with, and if the original file was raw |
#15 |
Great PP Tim!
| Thread Tools | |
| Display Modes | |
| Hitech ND filter color cast? | n2_space | Accessories & Storage | 5 | 18th of June 2009 (Thu) 16:25 |
| Recommend ND filter with no color cast | CronoDL | Nature & Landscapes | 0 | 21st of March 2009 (Sat) 00:15 |
| Bluish cast on G6 pics | Superbaldguy | Canon G-series Digital Cameras | 6 | 11th of May 2005 (Wed) 20:18 |
| Using Auto Color To Remove A Color Cast | scottbergerphoto | RAW, Post Processing and Printing | 10 | 1st of May 2005 (Sun) 06:52 |
| Remove green cast on 1D image? | oeyvind | RAW, Post Processing and Printing | 1 | 28th of December 2003 (Sun) 21:48 |
