Thread started 03 May 2005 (Tuesday) 06:19
What is a split-screen focus screen (EC-L)
schmoelzel
Lord of the Holy Trinity
Joined Aug 2001
May 03, 2005 06:19 |  #1
Since I have acquired a few manual focus lenses lately, I have read info concerning new focus screens for the 1-series viewfinders. What exactly does a split-screen do to the normal focus screen of the camera? Any info is much appreciated!
mdr
Joined Jan 2005
May 03, 2005 06:37 |  #2
This is a quote from a website:
3mm diameter split-image spot, for precise pinpoint focusing on subjects with distinct contours, use the central split-image rangefinder; turn the focusing ring until the split image becomes a sharp, clear, complete and undivided image
A split-image focussing screen is of no use when you're using autofocus. It can be very useful for manual focus, as aligning an object across the two halves can be much easier in determining whether your subject is in focus.
Hope this is clear. If not, let us know.
Cheers,
Marc.
Marc
Glasgow, Scotland
www.marcderidder.com (external link)
www.deridder.me (external link)
PacAce
Joined Feb 2003
May 03, 2005 06:39 |  #3
A split-screen focusing aid is that little circle in the middle of the focusing screen that looks like it's been cut into two equal parts with the cut usually running either diagonally at 45 degrees or horizontally. Each half of the circle is actually a small prism.
The way that it works is that when you point the circle over a subject that has vertical lines, when the subject is not in focus, the top half of the lines will not lineup with the bottom half. When you adjust the focusing ring so that the subject is in focus, the lines will all line up perfectly. The diagonal split has the advantage that you can also focus with it using horizontal lines.
The other common type of focusing screen is the micro-prism focusing screen. The same principle is applied here except that when the subject is out of focus, the image breaks down into lots of "speckles". When the subject is in focus, the speckles will not be evidient. Some people find this type of screen harder to use than the split-screen focusing screen.
...Leo
PacAce
Joined Feb 2003
May 03, 2005 06:43 as a reply to  @ mdr's post |  #4
Cheers,
Marc.
Although the range-finder camera does indeed have a split-screen type of focusing aid, it's not the same split-screen focusing screen that's used in SLR cameras.
...Leo
mdr
Joined Jan 2005
May 03, 2005 07:17 as a reply to  @ PacAce's post |  #5
Think you're confusing terminology here. The split image on an SLR focus screen is called split-image rangefinder. The quote actually comes from the early 1980's manual of my FE, a manual SLR, so maybe it's old terminology.
Marc
Glasgow, Scotland
PacAce
Joined Feb 2003
May 03, 2005 07:53 as a reply to  @ mdr's post |  #6
OK, sorry. I thought you were talking about a range-finder camera which also focuses using a split image but works differently from that used in the SLR.
...Leo
Longwatcher
obsolete as of this post
Joined Sep 2002
May 03, 2005 08:57 as a reply to  @ PacAce's post |  #7
The first thing I did when I got my 1DsMkII was to swap the standard EC-CIII laser focus screen for the EC-B split image screen. Works much better when I need to manually focus (as in I can do it now). My eye tends to adjust for bad focus (my eye will tend to put it in focus - even if it is out of focus), so I needed the split screen to make sure I am focusing correctly. So know I can use auto-focus or manual and get good results.
The reason I got the EC-B versus other splits is I was told the camera had less problem with it then other split focus screens (something to do with accurate exposure). I have not noticed any problems using it so far. But I use center weighted anyway as my default which the camera doesn't have problems with split image screens on anyway.
The split image circle is also what I am used to using from my old film camera days.
Just me and my experience,
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
PhotosGuy
Moderator
Joined Feb 2004
May 03, 2005 09:11 |  #8
Here's an example:
schmoelzel
Joined Aug 2001
May 04, 2005 05:37 |  #9
Thanks for all the answers! Thank you photosguy for showing what this looks like in the actual viewfinder! (PERFECT)
PhotosGuy
Moderator
Joined Feb 2004
May 04, 2005 06:41 |  #10
That is a Nikon P screen. Your experience may differ! ;-)a ;-)a
TomBrooklyn
Oct 29, 2008 01:11 |  #11
If I'm not mistaken, that screen also has a microprism "donut" around the 45 degree split part, like PacAce referred to.
Quad
Joined Nov 2005
Oct 29, 2008 01:17 |  #12
Why? Just why?
Here I was exited and thought schmoelzel was back.
Lyndön
Oct 30, 2008 05:17 |  #13
Wow, that brings back memories of my old AE-1 days. :D Still got it in the closet somewhere.
Lyndön
Oct 30, 2008 05:21 |  #14
Just found this on google for those who wonder what this looks like. Split Screen Focusing (external link)
Jman13
Oct 30, 2008 05:24 |  #15
I have a Katz Eye (external link) focusing screen for my 30D. Makes manual focus SO much easier (as the stock screen is essentially useless for manual focus.) Since I have a few manual focus only primes that I use, it was an essential piece of gear.
Jordan Steele - http://www.jordansteel​e.com (external link)
Admiring Light - http://www.admiringlig​ht.com (external link)
32,260 views & 0 likes for this thread
version 2.0 /
Latest registered member is lihaowei
769 guests, 385 members online
