Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 23rd of June 2009 (Tue)   #1
Joe M
Joe M's Avatar
Default My SX10is and a monopod?
I read that when you shoot with the camera attached to a tripod, Canon recommend you set [IS Mode] to [Off]. Is this the same with a monopod? I need a monopod when a tripod is to much or too heavy. I had a stroke and my right side is numb all the time and holding a camera is very hard. The monopod makes it great. I use a Stoney Point shooting pod with a 1/4-20 thread and a Manfrotto quick release. The setup weight is 1.25 lbs. Just what I needed.
I thank you all for your answers.
Joe M
Joe M is offline   Reply With Quote
Old 23rd of June 2009 (Tue)   #2
jasonstiller
Default Re: My SX10is and a monopod?
I would think that you should keep IS on with a monopod. I never knew about canons reccommendation to turn it off with a tripod. Can anyone chime in with the reasoning behind this? I wouldnt think it would matter.
jasonstiller is offline   Reply With Quote
Old 23rd of June 2009 (Tue)   #3
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Yep. Use IS with a monopod - it's not anything like as steady as a tripod. Canon recommends not using IS with a tripod so you don't get into a "feedback" situation, where the IS is looking so hard for non-existent vibrations that it starts making its own. Smarter (and newer IS EOS lenses recognixe when they're on a tripod and stop the IS but the PowerShots aren't typically used on tripods so Canon didn't include that capability. And older IS lenses (100-400 IS springs to mind of those currently in production) don't have tripod recognition.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 23rd of June 2009 (Tue)   #4
Joe M
Joe M's Avatar
Hi Jon and jasonstiller, I thank you for your info. This is a photo I shot with my SX10is and my new monopod. It is in Lancaster,Pa. Have a great day. Joe M
Old 24th of June 2009 (Wed)   #5
gitarmac
It will be obvious if IS is interferring with your monopod efforts. Mine did that feedback thing once, it was like the screen was vibrating. It doesn't do it every single time. I turn mine off (when I remember) when I use a tripod, but a monopod isn't as steady.
At any rate, just turn it on and if you see a problem turn it off.
gitarmac is offline   Reply With Quote
Old 25th of June 2009 (Thu)   #6
eosphotomanoftennessee
In your situation I would use IS, but I would set it to "shot only" mode so that it freezes the movement only during the click of the shutter. This mode generally produces better results since you will less likely to have the lens moving into a corrected movement during the moment of capture (according to Canon). If you are having steadiness issues due to your stroke you also may find it easier when you set a delay timer of 2 seconds after shutter activation to take the photo because you won't be "moving" at the time of capture.
Doug, eosphotoman@yahoo.com
7D
, Canon SX1 IS, Film Rebel for history
300L, 70-200L, 50 1.8, 28-105 EF, Sigma 18-50 EF-S
580Speedlite, AB Ring Flash, Excalibur 320, 2- Morris Optical Slaves
Adobe CS5 Extended, Wacom Graphics Tablet
eosphotomanoftennessee is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CHDK for SX10IS originalstarlite Small Compact Digitals by Canon 18 10th of April 2009 (Fri) 07:55
sx10is aperture pinkcrayon Small Compact Digitals by Canon 1 15th of March 2009 (Sun) 12:38
SX10IS @ ISO3200 lensmen Small Compact Digitals by Canon 11 7th of February 2009 (Sat) 15:53
SX10IS nick j Small Compact Digitals by Canon 4 20th of November 2008 (Thu) 09:42
