Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 26th of June 2009 (Fri)   #1
belsokar
Default What would you do if you had some bad photos?
So I shot a wedding using some rented lenses...unfortunately, there was a problem with one of my lenses...the left 25% of the image was always out of focus...I picked up the lenses right before the wedding, and had no time to test and view on a larger screen which would have easily shown the problem...out of about 1000 images, about 50 images display the issue...of those 50 images, I have enough similar type shots with other lenses that I could delete 40 of the 50 poorly focused images...so that leaves about 10 images that just stink! Do you just deliver these to the client? Hold them back and tell them the shots were no good? These were from a set of posed family shots that I'm sure the client will remember and notice are missing...
belsokar is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #2
belsokar
Default Re: What would you do if you had some bad photos?
sorry, meant to put this in the "Business..." section, don't know what happened!
Old 26th of June 2009 (Fri)   #3
hypertech
I don't deliver bad photos.
If the choice is no photos or poor photos in a situation where retakes are impossible, I think I would deliver them what I had along with an apology, an explanation, and a refund.
Canon 5Dm2, 50D, XSi (450D), 580 EX IIx2
24-105mm f/4L IS, 70-200mm f/2.8L IS, 100mm f/2.8 Macro, 50mm f/1.4, 18-55mm IS, Tokina 116
www.reflectivecanvas.com
hypertech is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #4
giuliasmith
giuliasmith's Avatar
NEVER DELIVER IMAGES THAT YOU ARE UNSURE ABOUT!
Wow - I always have a fear of something like this happening when shooting weddings! Personally, I edit out ALL the pictures I have any doubt about - this usually takes my 1200 shots down to about 350-400. I would rather deliver 400 good shots than 800 mediocre shots.
Think of it this way, they will never see the shots that are deleted, so they won't know they ever existed!
giuliasmith is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #5
OdiN1701
User is banned from forums
OdiN1701's Avatar
See if you can fix them, or crop, etc. but if not, I wouldn't deliver them. Are those 10 shots "key" shots?
Also - lesson learned - you will test your lenses next time won't you?
OdiN1701 is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #6
Anke
Anke's Avatar
How bad exactly are they, would the client notice if its in a small print?
Can you post an example?
Anke
1D Mark IV | 16-35L II | 24-70 f/2.8 II | 70-200L f/2.8 II | 100L Macro | 50 f/1.4 | 580EX II
Join the Official POTN UK South-East Thread | Follow me on Twitter | Tunbridge Wells | Flickr
Anke is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #7
Karl Johnston
Rare exception that I didn't say anything stupid"
Karl Johnston's Avatar
Delete the bad ones.
Karl Johnston is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #8
neil_r
Cream of the Proverbial Crop
neil_r's Avatar
delete the bad ones if you don't have enough for their album give them a refund
Neil - © NHR Photography
There are no rules for good photographs, there are only good photographs. ~ Ansel Adams
neil_r is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #9
Karl Johnston
Give them a refund because 50 didn't work out? That's madness ! Unless you've specified that you would deliver 1000 or a certain number.
It's pretty standard to have some shots that don't work out or need to be culled; most photographers have at least 50% on average. The fact that 50 didn't work out isn't much to sweat over. It's very impressive you have that high of a keeping ratio, anyway, good job.
Old 26th of June 2009 (Fri)   #10
neil_r
neil_r's Avatar
sorry a poor attempt at irony on my part.
Twas a joke.
The party do not know how many images were taken and as long as you have not screwed up the formals they will never know!
Old 26th of June 2009 (Fri)   #11
noxcuses1
So you're worried about 1% of the images being bad? Just delete them and use the other 990 images you took.
Don't give any bad work to the client. period.
Portfolio | Feedback |
noxcuses1 is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #12
belsokar
I appreciate all the feedback...I have already deleted several hundred shots that are just poorly focused, un-salvageable, etc...
These 10 shots in question will most likely be noticed as they are family shots where anyone in the left quadrant is out of focus...It's definitely not noticeable on my 3" camera screen though!
But it would definitely be noticeable on a 4x6...I am not on my biz computer right now, so don't have a sample image, but can try to post one a bit later...
Still not totally sure if I should deliver or not, I can always leave them out and see if they notice...
Old 26th of June 2009 (Fri)   #13
noxcuses1
If you feel that you can't leave them out, can some editing do the trick? Maybe darken around the edges, or change to black and white with more contrast?
Old 26th of June 2009 (Fri)   #14
canonnoob
Ignored by the TF and i am soo confused
canonnoob's Avatar
sounds like user error.... like you didnt have enough DOF or something
Dave W.- "I don't want to be famous, I just want to make great photographs"
Gear
Springfield, Mo Sports Photographer
Model Mayhem
SportsShooter
Selling Gear: 1D mk II N
canonnoob is offline   Reply With Quote
Old 26th of June 2009 (Fri)   #15
belsokar
Nope...I was worried that maybe that was the issue for a bit, but these were shots with people standing side by side...
plus to test, when I got home and noticed the issue, I tested again to make sure I wasn't crazy...set up the camera for several shots on a tripod...setup some objects to photograph, all side by side...everything equidistant and symmetrical,...and just as I had suspected, everything in the left quadrant was out of focus...everything in the right and center was perfect...
plus rental shop agreed with me and didn't charge me for the lens after testing themselves...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Never felt so bad about my photos CartoonBear General Photography Talk 36 5th of April 2009 (Sun) 13:27
I think my photos are bad... Take a look at one example! Fellipe de Paula Small Flash and Studio Lighting 18 11th of November 2008 (Tue) 16:07
Seeking ID Using Bad Photos Zipline Birds 8 8th of April 2008 (Tue) 22:27
ID Please (REALLY bad photos) eenorton Birds 6 17th of November 2007 (Sat) 15:22
Sunset photos are they bad. Click-it Nature & Landscapes 4 11th of August 2007 (Sat) 14:03
