#1 |
Please explain with I am doing wrong.
I have a 580 EXII mounted on my Canon 50D. I set everything on manual. Speed at 1000. When the flash is on, it only takes photos at 250 max. I tried the internal flash and it does the same thing. No matter what the speed is, if I set it over 250, it will give me at 250 max. Appreciate any help. Thanks! |
| sponsored links |
#2 |
I think you have to set the flash for high speed sync.
Canon 400D + Grip | Canon 10-22 | Canon 17-55 (kit lens) | Canon 55-250 IS |
#3 |
That is your cameras fastest sync speed.What is it that you want to shoot?
Canon 7D - 70-200 f4 - Fujifilm X-E1 |
| sponsored links |
#4 |
"Im completely lost"
Thats as fast as it will go with a flash on. You arent doing anything wrong
#5 |
Yeah that's the fastest a flash will shoot, although i think there is an option for high speed syncing in where you can increase the speed of the flash fire.
When you photograph people in colour, you photograph their clothes. When you photograph people in B&W, you photograph their souls. |
#6 |
Master Flasher
Here's a thread to explain flash sync (X-sync) speed, and high speed sync.
http://photography-on-the.net/forum/...d.php?t=208520
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#7 |
You didn't say what camera body you are using but I gather 1/250 sec is your cameras' sync speed. Your camera manual should cover using external flash units.
Mike |
#8 |
Hi and thanks for all your reply.
I am trying to shoot hummingbird in the shade and I read somewhere in here that if you turn on flash, you will get a freeze wing shot. I know if I have higher speed it should freeze the wings, but in shade, you don't get a nice color of the hummer so I thought I would turn on the flash to get a nicer shot. But when I do that, it goes down to 1/250 and I got a blurry picture. So, let me know if you know how to shooot humming birds in the shade. Thanks all!!! |
#9 |
Master Flasher
If you intend to expose your subject predominantly with flash, then use 1/250 shutter speed. Underexpose the ambient light at least 2 stops with a low ISO and a small aperture (higher f/ number). In this scenario, the duration of your flash becomes your "effective" shutter speed. With a 580EX II this will be approximately 1/1000 or faster, depending on the amount of flash power used.
If you want to incorporate a significant amount of ambient light, then use a fast shutter speed to freeze the action and switch your flash to high speed sync (FP Flash) mode. Hish speed sync flash has no motion-stopping ability and is essentially a continuous light source that lasts through the duration of the ambient exposure. Keep in mind that high speed sync is a less efficient way to use the flash. It needs more power, has less range and will give you longer recycle times. Keep an eye on the distance scale on the back of the flash unit to make sure you have the range to make it work.
#10 |
And also keep in mind that because of the hummer's wing speed you will in all probability need high speed sync to stop it. That will, as Curtis N said, reduce your range considerably.
http://www.jedlovec.com/Hummingbird-Flight.php Last edited by Titus213 : 27th of June 2009 (Sat) at 23:24. |
#11 |
The flash has to be in E-ttl mode for high shutter speed synchronization to work.
and... be sure you have not set the custom function in the camera to lock in 1/250 as the synch speed. |
#12 |
If you are trying to freeze action, high-speed sync is not the solution.
Dave Hoffmann |
#13 | |
Master Flasher
HSS works in manual flash mode, too, as long as it's on the hotshoe of a dedicated camera.
#14 |
Well, if it does allow a very short exposure time, it will, but then you have to be really close.
Anders |
#15 |
Yes, that's correct. You can reduce the flash power to minimum to speed up the flash. Or you can use ETTL and HSS to run the shutter speed up to max. Either option will reduce the flash range. I don't know what the flash duration is on the 580EX II but I think the max shutter on the camera should be about 1/8000. In either case there is a good chance it won't be enough to freeze the wings on a hummer.
| Thread Tools | |
| Display Modes | |
| WTB: Canon CP-E4 flash battery pack and 8gb compact flash card | ooztuncer | Classifieds: Buy | 0 | 1st of November 2008 (Sat) 07:11 |
| Photogenic Powerlight - how to disable your flash from point & shoot camera flash | shoot_a_star | Small Flash and Studio Lighting | 4 | 15th of June 2005 (Wed) 12:57 |
| Sigma EF 500 DG Super Flash & 300D: Flash Exposure Compensation? | Vita Rara | Canon EOS Digital Cameras | 2 | 4th of January 2005 (Tue) 15:31 |
