Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 3rd of July 2009 (Fri)   #1
gchette
Default Distant Lightning
Shot from the roof of my house last weekend before the storm. Corrected some white balance and saturation because it got slightly blown out.
Settings:
ISO: 100
Focal: 18mm
f: 3.5
Aperture: 5s
gchette is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #2
Bobinpeterboro
Default Re: Distant Lightning
Well done for the capture, but next time try to get into a position where you cannot see any lights. That will enable you to use the "Bulb" setting and capture more than one lightening bolt
Bobinpeterboro is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #3
AlphaChicken
Knot Hank
AlphaChicken's Avatar
"f:" is "aperture:""
what you have listed as "aperture:" is in fact the shutter speed.
and as bob said use bulb, a small aperture, and a middle ISO.
that way you can hold the shutter open for a while (15-30 seconds) and not have to worry about lights in the picture as well. Use a tripod. If any lightning bolts strike in the 15-30 seconds, you have a cool shot. Otherwise try again.
I am Henry. NOT Hank. And certainly not a length of rope tied in a knot.
My family calls me Hen, but you can call me Chicken. See you out there!
|Deviant Art
|Facebook|Gear List
AlphaChicken is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Distant First Nighthound Birds 4 20th of December 2008 (Sat) 15:32
Distant Lightning R Hardman Wildlife 16 15th of August 2008 (Fri) 08:00
Huge Lightning Panoramic - using my lightning trigger PAS Photography Nature & Landscapes 49 4th of June 2008 (Wed) 16:45
Distant Desert Lightning R Hardman Nature & Landscapes 3 20th of July 2006 (Thu) 06:16
