Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 4th of July 2009 (Sat)   #1
yonimation
Default Help setting up my 580ex ii w/ cybersync triggers
hey guys, first of im new to photography and even newer with flash stuff. i recently purchased a 580ex ii and the alienbess transmitter and receiver.
i have attached pictures how its connected and whats displayed in the speedlite.
somehow when i attach it and take a picture, no matter if the flash exposure is set to +3 or -3 or 0, the flash output flashes the same. anyone know the problem? any help would be greatly appreciated!
yonimation is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #2
HeadShotz
HeadShotz's Avatar
Default Re: Help setting up my 580ex ii w/ cybersync triggers
Welcome to the world of manual flash! With the cybersync's you lose your ability to shoot in ETTL..which is where you have your flash set. Change your flash setting to manual and adjust accordingly.
If you want to keep ETTL, you'll have to move to Radio Poppers or the new Pocket Wizards.
HeadShotz is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #3
BigBlueDodge
BigBlueDodge's Avatar
It's because your flash is in ETTl mode. In ETTL mode the camera tells the flash what power it needs to fire at. Since the flash is not connected to the camera or an ETTL capable trigger, the flash is just firing at a default level. You need to change your flash to manual output, and then do manual metering and adjust flash output accordingly (do you have a light meter).
If you wanted to retain the ETTL functionality and have the flash compute the output, you need to buy the Canon ST-E2 or the new PocketWizards
David (aka BigBlueDodge)
Gear
BigBlueDodge is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #4
rikaro
put it on manual. problem solved.
Matt Kwok
http://www.matt-kwok.com/blog
rikaro is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #5
40Dude6aedyk
Furthermore, your speedlite is set to MASTER mode which is not going to do any good either. And it's set to HSS mode. That is probably not going to be useful either since your light output will be drastically reduced and the CyberSyncs cannot really do much better than 1/320th or 1/250th synching anyways.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
40Dude6aedyk is offline   Reply With Quote
Old 4th of July 2009 (Sat)   #6
yonimation
when i put it in manual mode, i see can def see the power difference. but it does not sync up with the camera. meaning i test it out using the pilot, and then i try to use the cybersyncs test buttons, they do not fire.
Old 4th of July 2009 (Sat)   #7
FlashZebra
This space available
FlashZebra's Avatar
Set your flash to a manual mode, but not manual-master mode. Use one of the other manual modes like manual-slave.
The PC port on the 580EX II is turned off in manual-master mode.
Enjoy! Lon
http://flashzebra.com/
FlashZebra is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AlienBees Cybersync Triggers in the UK rgrebby Small Flash and Studio Lighting 14 21st of August 2009 (Fri) 10:49
WTB: Cybersync triggers and receivers uracowman Classifieds: Buy 0 31st of May 2009 (Sun) 21:25
WTB: CyberSync radio triggers doubledragon Classifieds: Buy 0 28th of March 2009 (Sat) 09:26
Anybody got the AB CyberSync triggers yet? Lonnie Small Flash and Studio Lighting 69 19th of July 2008 (Sat) 13:39
