Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 6th of May 2005 (Fri)   #1
Motorsports Photo
Motorsports Photo's Avatar
Default Why we have to use unsharp masking
I thought someone beside myself might like a topic that didnt include "What lens should I use for_____"
Heres an interesting quote from "Evaluating Color Sampling Technologies" by Rudy Guttosch in the April 2005 issue of "Advanced Imaging"
Its a trade magazine that covers industrial and armed forces image technology.
"Most digital cameras utilize image sensors that use a mosaic of color filters to capture color. The filters are applied to each pixel through photolithography as a secondary process of sensor manufacturing. The Bayer mosaic pattern is the most popular design and consists of an alternating pattern of red, green and blue filters whereby 50% of the pixels have green filters, 25% have blue filters and 25% have red filters. Because each pixel captures only a single color, two out of three colors are not sampled at any one given point. Image sensors that use the Bayer mosaic pattern require the camera to perform color interpolation to estimate the missing colors from neighboring pixel data. For a red pixel location, for example, the green and blue data must be interpolated from green and blue neighbors because these values are not directly recorded.
Bayer pattern images are less sharp than they otherwise could be as a result of undersampling of color and post processing compensation that is applied to minimize visual artifacts. Color aliasing which causes white lines in the image, is a common side effect of Bayer pattern color sampling because of the lateral distribution of the color filters across the image sensor array. Optical or mathematical blurring is commonly used to reduce the presence of these artifacts, although by doing so, the overall sharpness of the image is significantly compromised."
I thought others might be interested in this technical, but understandable explanation.
-Pete
Motorsports Photo is offline   Reply With Quote
Old 6th of May 2005 (Fri)   #2
steven
Default Re: Why we have to use unsharp masking
It this problem that I keep hoping that the foveon technology catches on as they don't use a color mosaic filter and all three colors are take at every location. But I guess Canon (and all the camera makers) have too much money invested into their own indivudual tech to be interested in someone else's
1Ds
Canon Lens
16-35mm L, 24-70mm L, 28-135mm IS, 50mm II, 70-200mm L ISf2.8, 100mm Macro, 100-400mm L IS
Sigma Lens
180mm Macro
steven is offline   Reply With Quote
Old 6th of May 2005 (Fri)   #3
J Rabin
That's an engineering discussion. It's nice information, like the Mars Rover beung a 1 Mp camera with big pixels. But few really care a hoot.
As long as resulting photos are attractive and meet people's quality expectations, and every camera generation improves. For practical purposes, current generation of dSLRs already exceeds the output quality of scanned 35mm film going to print. The engineers will continue to do their thing, thank gosh! J.
J Rabin is offline   Reply With Quote
Old 6th of May 2005 (Fri)   #4
ron chappel
Honorary Moderator
ron chappel's Avatar
There seems to be some common missunderstandings about bayer sensors -even that article quoted hasn't got it exactly right (or more correctly doesn't tell the whole story)
If i recall rightly,foveon (and it's supporters) say that a foveon type chip has three times as much effective resolution as a comparable type bayer sensor.....but this is simply not the case.
And's it's very easily proven wrong by testing.
The reason a bayer sensor is not as blury as it's detractors say is that interpolation is applied to the *colour only* (not the actual pixels)
When one thinks about it,this is no big deal.Trying to guess what colour to apply to a given pixel is not too hard (how often do colours change throught a scene compared to the extremely dense pixel spacing?)
**Remember the relative lightness/darkness of each pixel is totally unaffected by the bayer matrix -and it's these bright /dark changes that show up as edges/sharpness**
Non Bayer sensors DO give more resolution per pixel but it's roughly in the order of 50% more,not the three times claimed by foveon
(that 50% was a guess,i havent studdied this subject for awhile and have forgotten most of the exact numbers-sorry)
ron chappel is offline   Reply With Quote
Old 9th of May 2005 (Mon)   #5
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Originally Posted by ron chappel
Non Bayer sensors DO give more resolution per pixel but it's roughly in the order of 50% more,not the three times claimed by foveon (that 50% was a guess,i havent studdied this subject for awhile and have forgotten most of the exact numbers-sorry)
Latest issue of Pop. Photo ran a sub-$2500 DSLR shootout that found the SD-10 had about 5 MP effective resolution, so about what you remember.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 9th of May 2005 (Mon)   #6
adas
adas's Avatar
What's even more interesting about it is that you can reach the full resolution of your camera by shooting BW subjects asnd ofcourse using an appropriate demosaicing algorithm. The question is where to find BW subjects elsewhere than shooting documents or the old grandfather's photographs?
adas is offline   Reply With Quote
Old 9th of May 2005 (Mon)   #7
robertwgross
robertwgross's Avatar
Chessboard with chess pieces.
---Bob Gross---
robertwgross is offline   Reply With Quote
Old 10th of May 2005 (Tue)   #8
Jesper
Jesper's Avatar
I agree that the Foveon sensor idea sounds more attractive at first sight than it really is, if you think about it.
One other disadvantage of the Foveon sensor, which hasn't been mentioned yet here, is that it is more noisy than a Bayer sensor. Because the three pixels (R, G, B) are stacked upon each other, less light will reach the middle and bottom pixels, which means the signal has to be amplified more, resulting in more noise in the image.
Please visit my gallery!
Canon EOS 5D
EF 24-105 f/4 L IS, EF 70-200 f/4 L IS, EF 35 f/2, EF 50 f/1.8 II, EF 100 f/2.8 Macro USM
Extender EF 1.4x II, Speedlite 550EX
Jesper is offline   Reply With Quote
Old 10th of May 2005 (Tue)   #9
pierrot
pierrot's Avatar
I do agree that Foveon technology looks more advanced at first glance.
The question is: what is the impact on real life photography? Do the images look sharper? Better defined? More contrasted? More true-to-life coloured? Is there a visible difference on enlargements?
Without examples, it's hard to make one's opinion. And besides of that, I wouldn't change my whole lenses collection just to be able to use a Sigma body, even if it is "better"...
Eos 5D + Eos 7D + Eos 20D + f/1:1 L eye-glasses
pierrot is offline   Reply With Quote
Old 10th of May 2005 (Tue)   #10
ssim
ssim's Avatar
What in god green earth did you jsut say. Yeah I got, didn't like and it hurt.
I just not that technically inclined and itf the test was next week I'm suire that I would flunk.
Sheldon Simpson | My Gallery | My Gear updated: 20JUL12
ssim is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Masking help...I think. nickybegood1998 RAW, Post Processing and Printing 9 21st of January 2007 (Sun) 21:49
Masking Julio RAW, Post Processing and Printing 6 3rd of December 2006 (Sun) 12:41
Need help with delicate masking Picture North Carolina RAW, Post Processing and Printing 9 14th of September 2006 (Thu) 21:48
what is masking? demarco36 General Photography Talk 3 28th of July 2006 (Fri) 03:18
Greetings and a great Unsharp Masking technique pixelgrunt RAW, Post Processing and Printing 7 29th of September 2005 (Thu) 13:46
