Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of July 2009 (Wed)   #1
TMR Design
TMR Design's Avatar
Default REVIEW: CHEETAHstand Cheetah8 Light Stand
I received my CHEETAHstand Cheetah8 light stand about a week ago and I'm very happy to report that it's an excellent product.
The stand is lightweight, compact and very portable, made of die cast aluminum. Collapsed size is 28.5" and when set up it has a working height of 29" to 96", making it useful for just about anything from a background light to main, fill, accent or hair light. The footprint diameter is 32.5" and quite stable when used as intended with a shoe mount flash or small strobe. The stand has a 5/8" stud with a 1/4"-20 thread on top. It is not intended for use with a boom or any modifier that is too far from the center of gravity.
I tested the stand with a Nikon SB-900 Speedlight and a 33" umbrella, 45" umbrella, 46" Softlighter, 16" x 22" softbox and a 24" x 32" softbox. Even with a grid in the 24" x 32" softbox there were no problems with stability and no need for weights or sandbags. My tests were done indoors so there were no issues with uneven terrain or wind.
For indoor location work this stand really makes life easy and allows you to move your setup quickly for on-the-fly portraits. You can place the stand in a corner or off to the side and when you need it you can just grab it, lift it up and move through a crowded room or across a dance floor, placing it down on the floor and continue shooting instantly, all without having to put your camera down.
Most stands that are this compact extend to 6 or 7 feet. The Cheetah8 extends to a full 8 feet and still maintains stability, although I wouldn't fly a 24" x 32" softbox off the top at that height. I would, however, place a Speedlight on the stand and raise it up to 8 feet for a room or ceiling bounce.
Considering the cost of other light stands that are well constructed and extend to 8 feet I consider the price of $89.95 to be very reasonable. Online checkout was a breeze, shipping was fast and customer support is excellent.
Also, if you order a Cheetah8 before July 31 you can get free shipping by entering coupon code cheetah at checkout.
I really like this light stand and highly recommend it for wedding and event shooters. Event photographers are always looking for ways to make life simpler and for those that work without an assistant this is a blessing.
EDIT: My purchase and this review was a direct result of THIS THREAD I initially posted.
It should also be mentioned that this is a modern redesign of the original Red Wing QuickStand and then the short-lived Kwik Stand.
Please call me Robert or Rob, not TMR
Gear List & Feedback | The Lighting Academy
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #2
MR do little
User is banned from forums
Default Re: REVIEW: CHEETAHstand Cheetah8 Light Stand
Look and sounds like a great product Robert!
Thanx for sharing.
Kindest
MR do little is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #3
Marloon
89.99 is not cheap!
I'm MARLON
Canon Platinum CPS member
Marloon is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #4
J Kacey
J Kacey's Avatar
Glad it worked out for you Robert.
Thanks for the Review
Kacey Enterprises
J Kacey is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #5
bobbyz
Originally Posted by Marloon View Post
89.99 is not cheap!
Well everything is relative. If it saves you some time in setup and makes your job easy, I think it is $100 well spent.
BTW - Robert, thanks for the review.
Back to basics 5dc with 35L & Sigma 85mm f1.4
bobbyz is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #6
Rudi
Rudi's Avatar
Absolutely - I wouldn't call $90 expensive! With the amount of money that we spend on photographic accessories, something that makes your life easier on location, lasts pretty much forever, and costs only $90... is a freaking bargain!
• Wedding Photographer - Sydney and Wollongong
• Borrowed Moment (blog)
Life is uncertain. Eat dessert first.
Rudi is online now   Reply With Quote
Old 15th of July 2009 (Wed)   #7
bobbyz
Agree. If it was listed on strobist website it would be flying off the shelf at even much higher price. What they pay for that dinky nano stand?
Old 15th of July 2009 (Wed)   #8
tetrode
I am a walking repository of thoroughly useless information
tetrode's Avatar
Thanks for the review, Robert, but you're slipping. The stand hasn't been added to your gear list yet
Dave F.
tetrode is offline   Reply With Quote
Old 15th of July 2009 (Wed)   #9
TMR Design
TMR Design's Avatar
Thanx for sharing.
Kindest
My pleasure Paul. I know I'm going to get a lot of use out of the Cheetah stand since I'm now doing many more events and some of them are in tight spaces where it's not practical to have a permanent setup and this lets me capture candid portraits and then get the heck out of the way quickly.
Old 15th of July 2009 (Wed)   #10
TMR Design
TMR Design's Avatar
89.99 is not cheap!
I suppose by some people's standards $90 is not cheap but if you look at comparable stands you'll see it is actually more affordable than other stands with the same or similar features.
I see you have a 70-200mm f/2.8 L IS... that's not a chap lens by any means, but you deemed it important or necessary to your work. Relative 'worth' is a very subjective thing and if we take a look at all the doodads, gizmo's, camera bags, etc. that we spend insane amounts of money on, then $90 for a light stand that improves creativity and workflow is a minor expense, in my opinion.
Old 15th of July 2009 (Wed)   #11
TMR Design
TMR Design's Avatar
Yup!!
Old 15th of July 2009 (Wed)   #12
TMR Design
TMR Design's Avatar
Dave F.
You're right Dave.
On occasion I do slip a bit. I've been so busy shooting, editing, designing albums and learning new techniques that I haven't quite been myself lately.
The stand is now in my gear list.
Old 15th of July 2009 (Wed)   #13
TMR Design
TMR Design's Avatar
Thanks Jerry. Edward Tang is a great guy and the product is well designed.
Old 15th of July 2009 (Wed)   #14
TMR Design
TMR Design's Avatar
I forgot to mention....
If you order a Cheetah8 before July 31 you can get free shipping by entering coupon code cheetah at checkout.
I'll edit the original review post to include this information as well.
Old 15th of July 2009 (Wed)   #15
Brett
Brett's Avatar
Thanks for the review Robert. I remember seeing the video where the photog moves in and out of the pews (which I believe was the KwikStand) and searching for it, but it wasn't available anywhere I could find.
Glad someone's making these now. Any other comments on the construction? Is it built as nicely as some of the stands in its price range? How smooth is the opening/closing action? Do the feet have rubber tips, and if so, do they bind up on hardwood or linoleum/tile when opening? How are the clamps (plastic or aluminum)? I assume it's not air-cushioned?
TIA.
flickr
Brett is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Using backdrop stand as a light stand? k4show Small Flash and Studio Lighting 2 23rd of April 2009 (Thu) 20:02
Light Stand as Bacground stand? Tareq Small Flash and Studio Lighting 17 10th of March 2009 (Tue) 19:24
WTB: Light meter, 30D remote shutter release, backdrop stand + backdrops, light stand ryancr711 Classifieds: Buy 0 11th of July 2008 (Fri) 04:22
Impact stand and Umbrella kit - mini review rklepper Small Flash and Studio Lighting 57 16th of February 2008 (Sat) 22:48
