Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 16th of July 2009 (Thu)   #1
2005GLI
2005GLI's Avatar
Default Will 30D L bracket fit on 40D?
Like the title says. Will a RRS/Kirck L plate for a 30D with grip fit on a 40D with grip? Ignoring the hole for the remote release, is it a straight bolt on?
Canon XT|BGE3|40D|BGE2|24-105 F4/L|70-200 F/2.8 APO|
|12-24 F/4|50 F/1.8|8mm F/4|kit lens|
|Other goodies that I can't fit in here|
2005GLI is offline   Reply With Quote
Old 17th of July 2009 (Fri)   #2
2005GLI
2005GLI's Avatar
Default Re: Will 30D L bracket fit on 40D?
anyone?
Old 17th of July 2009 (Fri)   #3
krb
krb's Avatar
All of the xxD cameras are the same external size and have the threaded hole in the same place (otherwise they wouldn't be able to all use the same battery grip) so I would assume that the L plate will fit correctly.
-- Ken
Flickr
Gear list
krb is offline   Reply With Quote
Old 18th of July 2009 (Sat)   #4
DANATTHEROCK
DANATTHEROCK's Avatar
Email the company that make it. Can't see why it wouldn't fit.
Canon 5D Mark II & 50D with 17-40, 24-105, 100-400, 50 f/1.4, 100 f/2.8 macro, and 1.4TC
FEISOL CT-3442 (ARL) tripod w/ Photo Clam 40-NS ballhead
DANATTHEROCK is offline   Reply With Quote
Old 18th of July 2009 (Sat)   #5
2005GLI
2005GLI's Avatar
thanks guys. Now I wish I bid on the one on ebay. Sold for $40
Old 18th of July 2009 (Sat)   #6
Mr.Black82
It will not fit.
Look here at "Design changes compared to the EOS 30D" you can see that the connections on the side are different.
http://www.dpreview.com/reviews/CanonEOS40D/page4.asp
What will fit is 40D and 50D l-bracket.
Mr.Black82 is offline   Reply With Quote
Old 18th of July 2009 (Sat)   #7
argyle
argyle's Avatar
That may not be a good assumption. Sure, the mounting bolt may be in the same position, but there's no guarantee that the electrical ports will be fully accessible when using an L-bracket not specifically designed for a particular body.
You may have saved yourself $40 and shipping charges. The bracket for the 40D differs slightly from that of the 30D (at least the RRS model). You'll save yourself some grief by emailing either RRS or Kirk...they're both friendly and knowledgeable and will answer any question.
argyle is offline   Reply With Quote
Old 18th of July 2009 (Sat)   #8
krb
krb's Avatar
He did say "Ignoring the hole for the remote release" in the original post...
-- Ken
Flickr
Gear list
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RRS 30D L bracket on 40D, why not? 2005GLI Accessories & Storage 4 5th of January 2009 (Mon) 20:02
Fisheye lens to fit the 30D and/or 40D? TourBusLive Canon EF and EF-S Lenses 18 13th of September 2008 (Sat) 21:41
