#1 |
Hi all,
I'll have to shot body details with water drops. What is the trick to have beautiful drops ? Thanks for help.
Xavier Wanna see my photographs ? here http://xavier-claise.book.frand here http://www.pbase.com/ixessC&C always welcome! Gear List |
| sponsored links |
#2 |
First oil body then spray on water. You may have to wipe and spray again but you will quickly get the results you want.
#3 |
Mix a bit of glycerine with the water to significantly increase its surface tension--makes the drops stay discrete drops instead of being so quick to run.
| sponsored links |
#4 |
Baby oil and a spray bottle worked great for me.
Cameras: 5DMK2, 5DMK3, 7D, S90 Triggers: AB CyberCommander system, 6 RF602, 4 cactus5 Flash: 580ex, 430ex, 2ea YN-560 Lights: 2ea Einsteins, AB1600, 2ea Ab800 Modifiers: 3 each Folding Softboxes /w grids, 4 Umbrellas, Snoot, reflectors, grids, Kacey BD, 45" & 22" w 5 stands Primes: 35L, 50L, 85L Zooms: Tok 11-16, 24-70 MK2, 70-200 F2.8 MK2 Ext: 1.4 , 2x MK3 |
#5 |
First put the body lotion on your skin and
then sprinkle water on you, It will work.
" Every steps you make, Make sure you get one step closer to your destination." |
#6 |
Lotion or baby oil skin first
Spray with fine mist of 50% water 50% Glycerin (better drops and slows evaporation)
~ Jeff Canon EOS-1DX & 1Ds MkIII, 20D(IR), G12, G9, G5, ... Gear List JMM Photography ~ Discovering Art in Everyday Life | Model Mayhem #675060 |
#7 |
Demoted and banished by the TF
Thanks so much for asking this question. Thanks to all who answered too!
Racquel is my real name Gear List Flickr ModelMayhem Website BugGuide Etsy Facebook Otero Ferret Rescue |
#8 |
By the way, ordinary glycerine is made from animal fats--usually pork. If that's unacceptable for your model, a pure vegetable glycerine is also available, although you may have to order it over the Internet.
#9 |
You can also add flourescent tempura paint to the mix and use a black light for cool effect. You can add black or brown or ... and smudge it around for grunge.
#10 |
Thanks for all your replies
i'l make a test on next tuesday, and make the shoot on wensday 5th of august i'll post some results for comments and critics
| Thread Tools | |
| Display Modes | |
| Water Drops that would make a Peacock Proud | jmchooper | Macro | 14 | 1st of April 2009 (Wed) 19:16 |
| Some water drops. | long jetty | Wildlife | 3 | 18th of February 2006 (Sat) 22:22 |
| This will make your skin crawl... | Tyger | Macro | 7 | 28th of December 2005 (Wed) 05:45 |
| Water Drops | JonathanS | Macro | 5 | 22nd of September 2005 (Thu) 17:10 |
| water has skin | Muunstruk | Still Life, B/W & Experimental | 7 | 18th of September 2005 (Sun) 17:20 |
