Thread started 17 Jul 2009 (Friday) 22:34
Prev/next
Review: Domke Backpack Strap (FA-100 review)
Jim ­ G
I feel thoroughly satisfied
Jim G's Avatar
Joined Jun 2005
Australia.
Jul 17, 2009 22:34 |  #1
This is a review of an item I don’t see mentioned much – it’s a strap/harness which allows you to strap your Domke shoulder bag over both shoulders much like a backpack. Putting it all together is all a bit esoteric but here’s how it works for me…
IMAGE: http://farm3.static.flickr.com/2444/3730426973_706c5eb958_o.jpg
This is the strap in situ on a F-3x – the narrow strap clipped to the two steel rings at the back of the bag and the wider straps hooked onto the same plastic ring that the shoulder strap goes onto. A closer look:
IMAGE: http://farm4.static.flickr.com/3517/3731221732_b1a42f22c4_o.jpg
Gear Listhttp://www.codastudios​.com.auexternal link Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514external link & 1610/1614external link - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Homeexternal link - FA-100external link
Jim ­ G
Jim G's Avatar
Joined Jun 2005
Australia.
Jul 17, 2009 22:35 |  #2
Straps go over your shoulder – I’m not even going to try to describe how it works so here’s some photos:
IMAGE: http://farm4.static.flickr.com/3512/3731315272_9b6f45eef5_o.jpg
IMAGE: http://farm3.static.flickr.com/2513/3731223134_451bc5ffbd_o.jpg
Jim ­ G
Jim G's Avatar
Joined Jun 2005
Australia.
Jul 17, 2009 22:35 |  #3
IMAGE: http://farm3.static.flickr.com/2452/3731222634_9df5d7b04d_o.jpg
The hardest part of these shots was finding a non-black shirt… turns out I haven’t owned a coloured t-shirt for quite a few years and had to borrow one :p
As you can see in the side-on view it sits quite low on the back which makes it quite comfortable. You can cinch the wider straps tighter to sit higher on your back which also makes it more stable if you were to, say, be likely to want to run at times or were moving quickly over uneven terrain.
Jim ­ G
Jim G's Avatar
Joined Jun 2005
Australia.
Jul 17, 2009 22:35 |  #4
Clipping it on and off is the work of moments and it rolls up into a pretty compact package:
IMAGE: http://farm4.static.flickr.com/3637/3730426015_050239156e_o.jpg
Difficult to see here and since I was selling this setup that day I didn’t have time for a better shot… however! You can see that it takes up less than half the space of the side pocket of a F-3x:
IMAGE: http://farm3.static.flickr.com/2437/3730425737_72c1e0cc86_o.jpg
Small and quite lightweight so it’s not an issue to have it in a pocket should you think you’re likely to need it.
Jim ­ G
Jim G's Avatar
Joined Jun 2005
Australia.
Jul 17, 2009 22:36 |  #5
A strap like this could easily be improvised for pretty much any bag system – the Domke one isn’t too expensive – US$27 at B&H and the bags it’s designed to be fitted to already have appropriately located rings.
B&H states that it is designed to fit the F1X, F2, F3X, F4AF, F7, F804, F805, J1, J2 or J3.
It is also quite easy to sling the harness off from one shoulder and swing the bag around so that you can access it normally – the mounting points for the harness are all clear of the bag’s opening so it makes the bag into a somewhat-Slingshot-esque quick access backpack.
All in all it’s a feature of the Domke system which I greatly appreciated with the F-3x. I didn’t end up using it all that frequently as I have camera backpacks for when I know I’m going to be walking very long distances but they’re quite slow to access; using the harness you get a mix of both worlds in a similar way to what Lowepro’s Slingshot line gives you. Not quite as elegant and a little bit more strange looking but quite functional.
Comments, suggestions and criticism welcome!
Rudi
Rudi's Avatar
Joined Mar 2002
Australia
Jul 17, 2009 22:49 |  #6
Yup. Very handy, and works well. I've got one for the big Domke (F-7? I forget the model designation), but it fits on all the Domke shoulder bags that I have, and I usually carry it in one of the pockets, just in case.
• Wedding Photographer - Sydney and Wollongongexternal link
• Borrowed Moment (blog)external link
Life is uncertain. Eat dessert first.
rklepper
Dignity-Esteem-Compassion
rklepper's Avatar
Joined Dec 2003
No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA.
Jul 17, 2009 22:53 |  #7
It looks like that would pull on the shoulders a little more that a regular backpack. Does it?
Doc Klepper in the USA
I
krb
krb's Avatar
Where southern efficiency and northern charm come together
Jul 17, 2009 22:59 |  #8
Good review.
I use an F4AF for my "outdoors" kit and it works great when I'm shooting but when I'm hiking to or from the location it gets uncomfortable. All the weight on one shoulder means that after a mile or two the hip that is supporting the weight starts to get a little sore and I feel like I'm walking sideways. I bought a set of these backpack straps and the 4th of July weekend was my first time using them. I went hiking on each of the 3 days, not long hikes but 5-6 miles each day, and these straps made it very comfortable. Like you said, not a replacement for a "real" backpack but I have one of those if I needed it.
My only compaint is that they are only available in black, I'd rather have them in OD green to match my bag.
-- Ken
Flickrexternal link
Gear list
krb
krb's Avatar
Jul 17, 2009 23:07 |  #9
rklepper wrote in post #8299794external link
There's no sternum strap and no waist belt so it's certainly not as good as a regular backpack, but they are more comfortable than I had expected when I first saw them. If you need a regular backpack then that's what you should get. If you need a shoulder bag, and just need to occasionally set it up to distribute the load over both shoulders then these can be a good option.
-- Ken
Flickrexternal link
Gear list
Todd ­ Lambert
I don't like titles
Todd Lambert's Avatar
On The Roads Across America
Jul 18, 2009 22:53 |  #10
Agreed to everything here.. I bought mine because it was pretty cheap (actually got mine second-hand from POTN) and I liked the idea of having it if it I need it.
It works well... for it's purpose.
Anyways, nice review.
Year of Night - 365 Night Project - check it out! (external link)
Follow me into the night.
Unique Night Photography - twilightscapes.com (external link)
crispy12
1 post
Joined Jul 2012
Jul 06, 2012 23:00 |  #11
Sorry I had to register just to reply to this post. I just got this strap had trouble finding a comfortable position. I installed the clips in the layout according to the images in this thread (thanks Google!) however the bag kept digging in to my back and tilted backwards.
Turns out that the thin straps actually attach to the plastic D-ring of top, and the thick shoulder straps attach to the smaller metal D-rings on the back of the bag. Opposite of the photos above! Much more comfortable and the bag sits upright. Hope this helps, recommend this strap for Domke users who cycle/hike!
9,906 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.0015 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is josejoseph1
832 guests, 443 members online
