| sponsored links |
Thread Tools | Display Modes |
#1 |
Has anybody taken Macro shots exploiting the TILT capability of a Tilt-Shift lens ? Currently, Canon provides 4 focal lengths TS-E lenses: 90mm, 45mm, 24mm, & 17mm. I guess that the 90 & 45 are good candidates.
Can anybody share/upload his/her experience ? Thanks |
| sponsored links |
#2 |
Moderator
This might be better in talk about, more response and room for inevitable technical discussions.
A few shots have been shown, a search may find them. I can't show any shots as I don't have a T&S, but I can help on the theory. It is worth noting that when focused at infinity the lens tilt available is sufficient to tilt the sharp focus plane to 90 degrees, however this reduces dramatically as you focus closer. Typically only about 16 degrees of tilt can be obtained at life size (using equations here http://www.zen20934.zen.co.uk/photog...hift.htm#Close Up). This can be illustrated with this plot, showing the tilt of the planes of sharp and acceptable focus (ie the planes of depth of field, this is not affected much by focal length. ![]() Of course you can use focus stacking to improve DOF for some subjects rather than T&S, most obviously mushrooms, flowers etc that would be good applications for T&S. I would be interested in hearing from anyone that manages to use lens tilt handheld with insects.
My Photography Home Page RSS Feed MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair! Gear List FAQ on UV and Clear Protective Filters Macrophotography by LordV Last edited by Lester Wareham : 1st of August 2009 (Sat) at 10:42. Reason: Reply added |
#3 |
I have seen good closeups using a 90mm TSE with ext tubes. These were all "still-lifes" as the necessary lens adjustments just take too long for live insects seemed to be the verdict of users.
Brian V.
http://www.flickr.com/photos/lordv/ http://www.lordv.smugmug.com/ Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056 Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits |
| sponsored links |
#4 | |
Moderator
If it is still life then focus stacking is an easy option, allthough this means time on the PC it is probably quicker than doing the tilt adjustment.
My Photography Home Page RSS Feed MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair! Gear List FAQ on UV and Clear Protective Filters Macrophotography by LordV |
#5 |
Moderator
Thinking about it further, you could pre-adjust the tilt and just judge the plane of focus.
Normally one approaches insect photography by making small position adjustments to optimise sharp plane of focus, one could do the same with a tilted plane of focus. This would work if you previsualise your composition and set the plane of focus. The complication is I think the plane of focus for a given lens tilt will vary, for typical close-up work it is going to be between 16-20 degrees. I can see it working as long as one did not fiddle with the lens tilt adjustment whilst trying to line up a shot.
| Thread Tools | |
| Display Modes | |
| MACRO: Tilt-lenses usable for macro? | Rogert | Macro Talk | 9 | 27th of July 2008 (Sun) 14:51 |
| My first Macro shots with a non Macro lens | mypoppy31 | Macro | 7 | 15th of May 2008 (Thu) 06:06 |
| Where have all the sticky threads gone? (moved from share wedding photos) | Visual Bride | Forum Talk | 3 | 14th of December 2007 (Fri) 17:59 |
| Macro Lens without Macro, Help! (Tamron AF 75-300mm f/4.0-5.6 LD Macro Autofocus) | janapriya | Canon EF and EF-S Lenses | 6 | 21st of May 2007 (Mon) 22:47 |
