#1 |
Alright, I can already tell its soft, not sure if it was focus or motion as I was panning.
Also, sky is blown out as well. Anything else I didn't get on this one? ![]() Exposure: (1/200) Aperture: f/7.1 Focal Length: 300 mm ISO Speed: 100 Exposure Bias: 0 EV Flash: Off, Did not fire Date and Time (Original): 2009:07:22 18:53:50 C&C welcomed
Shooting with canon rebel XT or Canon Rebel XS.
Kit 18-55mm, 18-55mm IS, Sigma 70-300mm APO Macro lens, Canon 60mm f2.8, nifty 50 and Speedlite 600EX-RT (Flash) My Flickr Last edited by Jpatten : 1st of August 2009 (Sat) at 22:36. |
| sponsored links |
#2 |
1/200 is pretty slow to be capturing a plane in flight.
Today is a great day to take photos. |
#3 |
Ouch, yeah you needed more shots and play with exposure more. play with your EV and bring up lightness in PP.
Eos 7D, 40D w/70-200L 2.8 IS, Nifty Fifty II, 100MM 2.8 Macro, 18-55mm IS II, 24mm 2.8, 28-135 IS, 580ex II |
| sponsored links |
#4 |
ISO is too low to get the shutter speed you need at f/7.1. Also, get a polarized filter for the sky. Barring a good polarizer, at least turn off AWB and set it to sunlight if you are going to shoot the sky in your shots.
#5 |
motion blur?
#6 |
Too dark for shooting that plane with your lens.
#7 |
#8 |
User is banned from forums
Airwaves Salvage lines,
![]() Somewhere along the way I lost the shadow of the prop. |
#9 |
speeding up your shutter speed will help with the blown out sky also.
#10 |
OutDoor action I usually start ISO at 400 and get a grip of the other settings by the LCD review. I set the blinkies to show the blownout and dial accordingly or as close as I can get.
< name shows where I start the F stop at. then its just a matter of shutter to totally freeze it or to pan and hold it. Last edited by F4 Cyborg : 2nd of August 2009 (Sun) at 12:59. |
#11 |
Ok, well I will bear all the advice in mind. But if I pushed the shutter much higher wouldn't I also freeze the prop?
ISO 400? I usually try to keep my ISO as low as possible to reduce noise.
Kit 18-55mm, 18-55mm IS, Sigma 70-300mm APO Macro lens, Canon 60mm f2.8, nifty 50 and Speedlite 600EX-RT (Flash) My Flickr |
#12 |
if it does freeze the prop (though it is moving faster than the plane) it can be motion blured in PS. Noise does come into play just depends on the camera as to when. Noise for the most part can be handled with practice and software.
#13 |
ISO 800 is no problem in broad daylight. Digital ISO noise would be most problematic in darker sections of the image, but you're shooting a bright sky (and overexposing to get detail on the plane underside, most likely), so you won't have too much "dark" in your photo. As long as you don't try to over-process the image, you probably won't notice unless you're specifically looking for it.
#14 |
| Thread Tools | |
| Display Modes | |
| Tear me apart please | ArjunaCapulong | Critique Corner | 6 | 30th of May 2009 (Sat) 22:51 |
| Tear Apart My Logic | Eagle Eye | Canon EOS Digital Cameras | 18 | 21st of October 2007 (Sun) 09:53 |
| Please tear those apart | dr_who | Critique Corner | 16 | 22nd of August 2006 (Tue) 08:39 |
| Tear them apart | NeedleInTheHay | Critique Corner | 4 | 4th of April 2005 (Mon) 08:41 |
| Tear this apart | Malok | Critique Corner | 7 | 24th of October 2004 (Sun) 22:15 |
