Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 4th of August 2009 (Tue)   #1
alabama1980
alabama1980's Avatar
Default Anyone that has Cybersyncs and Genesis lights Help!!
Just unboxed my Cybersyncs. RTFM even though everything is fairly self explanatory.
I got them on my Genesis 400 lights. They will fire ONCE and then the light locks up....it won't even fire via the test button on the back of the strobe....I can change power and all the other stuff, but it simply will NOT fire....
Anyone else run in to this or have any suggestions?? I tried this on both units and get the same results!
I've been lookiing forward to cybersyncs for a while now, and this feels kind of like when you were young and got socks for christmas....
Name's Andy!
Facebook
My 500px
asheltonphoto.com
alabama1980 is offline   Reply With Quote
Old 4th of August 2009 (Tue)   #2
slivr
slivr's Avatar
Default Re: Anyone that has Cybersyncs and Genesis lights Help!!
I use Genesis lights with Elinchrom Skyports so it's not an exact match, but I've never experienced a lockup or hiccup using the Skyport. That means nothing though, since we aren't comparing apples to apples.
Have you tested to make sure a sync-cord doesn't lock up the light as well? I.E.: If up to now you've used your Genesis in slave mode and fired them by using the on-camera flash ... you should get a synch-cord and run from camera to one of the lights (take it off slave mode) and see if the Genesis still locks up when you release the camera shutter. I dunno - just taking a stab to help identify if its the lights ... the cybersync ... or the combination that's the culprit. Got a buddy with a different studio light you can try your camera/your cybersync/his-light with? That would also narrow down the issue.
- Jason S.
More gear and money than talent ... but workin' at it!
slivr is offline   Reply With Quote
Old 4th of August 2009 (Tue)   #3
alabama1980
Yip. Works just fine. I called PCB and was told that some of the CS units are "finicky" with the Calumet lights. He said they had a Calumet 200 in the office and he would test several CSRB recievers on it and see if one would work and send me that one.
And my friends are lame...I'm the only photographer of the bunch...so no other lights to try it on.
Name's Andy!
Facebook
My 500px
asheltonphoto.com
Old 4th of August 2009 (Tue)   #4
Mac
Interesting. I have a pair of 200's and I have no issues with the cybersyncs.
Both of the lights do this? Do you have multiple cybersyncs, if so do all of them do it?
Sean
www.akamac.com
Mac is offline   Reply With Quote
Old 4th of August 2009 (Tue)   #5
alabama1980
Yip, have two and it does it on both. I just have the one receiver with intentions of adding a few more. What sort boggled me more than anything was that it would fire once, then lock to the point that the test button wouldn't do anything.
Name's Andy!
Facebook
My 500px
asheltonphoto.com
Old 6th of August 2009 (Thu)   #6
alabama1980
Update to this....
To try to keep this easier to follow we will say I have light "a" and light "b".
OLD RECEIVER
Using the mini to mini the original receiver will fire either of the two lights only once and then they lock up and have to be turned off then back on. If, however, I use the 1/8" to 1/4" cord with an adapter to revert it to 1/8" I can get the original receiver to fire both lights (I have to hold the adapter a certain way, but I think the adapter is the problem there). So that leads me to think it was the mini to mini cord....
NEW RECEIVER
The new receiver, however, will fire light "b" all day long without missing a beat using the mini to mini cord. So now I know the cord is not bad after all. If I use the mini to mini on light "a" with the new receiver, it fires once...locks the light up, and it has to be reset. It will fire with the other cord setup though.
So...its not the triggers....the lights....or the cord......it's just certain combinations of the three...
Anyone have a white jacket and a padded room for me? Or maybe a suggestion of some variable I overlooked? This is driving me insane....
Name's Andy!
Facebook
My 500px
asheltonphoto.com
Old 6th of August 2009 (Thu)   #7
mufutau55
mufutau55's Avatar
If you have to go thru white jacko jacket.. simply just return the DAMN thing and get Skyport.. there are alternatives.. Skyport and Cybersync they about the same price.. I hate it when you can't diagnose the cause of the problem.. I once had a car like that.. frustrating.
Mufutau
Originally Posted by alabama1980 View Post
Update to this....
OLD RECEIVER
NEW RECEIVER
mufutau55 is offline   Reply With Quote
Old 6th of August 2009 (Thu)   #8
alabama1980
Yahtzee!!
Ok...Can't explain why, but turned out it was the damned cable....
I snagged a couple of pc to mono cords, snipped em, soldered them up and that cable works on all my lights....
I still can't figure out why the cable that PCB sent worked with two out of three lights I tried it with, but not one.....Oh well....Im a happy camper now anyhow
As far as Skyports go, they were considered, but I personally like the design of the Cybersyncs better.
Name's Andy!
Facebook
My 500px
asheltonphoto.com
Old 6th of August 2009 (Thu)   #9
djtrackie
you got me scared now, my Genesis 200 kit AND cybersyncs were delivered to my door TODAY!!!
djtrackie is offline   Reply With Quote
Old 6th of August 2009 (Thu)   #10
slivr
slivr's Avatar
Sorry - "Finicky" is just another way saying "I dunno what's wrong ... I've looked at it but can't figure it out". Sending replacement parts that exhibit the same problem is embarrassing quality control.
I promise I'm not ranting against CyberSyncs. Any manufacturer sweeping a production issue aside deserves consumer backlash. Hope it works out for you.
- Jason S.
Old 7th of August 2009 (Fri)   #11
BigBlueDodge
BigBlueDodge's Avatar
My Cybersync's and Genesis 200's work flawlessly together
David (aka BigBlueDodge)
Gear
BigBlueDodge is offline   Reply With Quote
Old 7th of August 2009 (Fri)   #12
alabama1980
don't worry...like i said it ended up being just the cord. there are WAY more post about successful uses of cybersyncs and genesis lights than the threads like this.
I think it was just a fluke, and their customer service was top notch as far as im concerned!
Name's Andy!
Facebook
My 500px
asheltonphoto.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Genesis Lights and Grids Mac Small Flash and Studio Lighting 0 23rd of November 2008 (Sun) 20:10
Genesis 200 Kit & Cybersyncs Questions DarthMTS47 Small Flash and Studio Lighting 13 21st of November 2008 (Fri) 20:00
Self-portrait with Genesis Lights turbo212003 Small Flash and Studio Lighting 11 22nd of September 2008 (Mon) 14:00
Snooty Goodness for Genesis Lights ... tetrode Small Flash and Studio Lighting 44 13th of June 2008 (Fri) 17:38
What else do I need for my Genesis 400 lights 737mechanic Small Flash and Studio Lighting 5 26th of April 2008 (Sat) 19:06
