Thread started 12 Aug 2009 (Wednesday) 07:22
Prev/next
50d Card will not format.
jonathan41
Aug 12, 2009 07:22 |  #1
Hi guys, a newbie here. I have just got a 50D today and have tried three of my memory cards in it but it will not accept any of them. I am at my wits end, you know what its like, new camera and all that.
When i have tried the camera it says CARD NOT FORMATTED. FORMAT CARD.
so i go into the menu and try to format the car but it says CARD NOT FORMATTED. CANNOT FORMAT CARD.
I have always had canons for many years and have never encountered this before. Can anyone help a desperate man!!!
The cards are blank and have been used in my 40D and 400D and 300D before that. One of the cards is a new sandisk IV 8gb, so its not a quality issue??
Help? Jon
mprayii
Aug 12, 2009 08:18 |  #2
can you format it with your pc?
probably fat32 or 16, i doubt you'd want to use NTFS.
jonathan41
Aug 12, 2009 08:40 as a reply to mprayii's post |  #3
Hi Mprayii, thanks for the reply. Can you please explain your answer in idiots terms please.
I am not too computer literate. The camera was bought and i got it today from Simply Electronics and i would urge people not to deal with them. The 50D took 2 weeks to arrive....!! and it seems it has a fault. can anyone elabourate further on this ErRR CF/formatting error?...many thanks,,jon
Mike
ugly when I'm sober
Mike's Avatar
Gallery: 23 photos
Sandwich UK...the place, not the food!
Aug 12, 2009 08:44 |  #4
So, what is the process you go through with your card, just to be clear?
Do you put the CF card in to the CF card slot in your camera, close the cover, switch the camera on, enter the menu and select Format Card?
www.mikegreenphotograp​hy.co.ukexternal link
Gear
UK South Easterners
flickrexternal link Blogexternal link 5∞pxexternal link
Quis custodiet ipsos custodes? ::: A closed mouth gathers no foot.
jonathan41
Aug 12, 2009 08:54 |  #5
HI. I take the camera out of the box, fitted battery and lens. Made sure meory card was firmly in place. Turned camera on.
If i press the button down (to take a shot) then ErrCF displays on the top mini screen and "Card not formatted. Format card with this camera" appears on the back screen.
so i go into menu, to format and then press the OK button to format the card. Once pressed it says "Cannot format. Change card".
I am really frustrated as i only got it today and wanted to go out playing with it!!
Mike
ugly when I'm sober
Mike's Avatar
Gallery: 23 photos
Aug 12, 2009 09:01 |  #6
Hmmm...does sound like a fault somewhere. If the cards work fine with other cameras it could be your camera, I hate to say.
Gear
UK South Easterners
mprayii
Aug 12, 2009 09:17 |  #7
plug card into pc with the USB reader or directly into the face of the pc if supported.
Go to My Computer
Right click on your memory card, select format. I think I have used fat32 on my card and had no problems with it.
Its also worth trying another card to see if that works. Is there a Ritz or Bestbuy local to you? Ritz would probably let you try before you buy... dont know about bestbuy.
jonathan41
Aug 12, 2009 09:51 |  #8
But should i have to do that?? I have now tried to use the same card in the 40D and that wont work either. there is nothing wrong with the cards, as all three wouldnt have had a funny turn exactly at the same time. I think the 50D has done something now to my cards....i will try the computer thing...
any other ideas guys???
mprayii
Aug 12, 2009 09:56 |  #9
i guess I dont know? Was just trying to help - at this point it doesnt seem like it would hurt anything to try.
mprayii
Aug 12, 2009 09:58 |  #10
reset to defaults? update firmware?
irispatch
irispatch's Avatar
Maryland
Aug 12, 2009 10:01 |  #11
If the cards have been working in your other canon cameras they should work in the 50D. Before sending it back format one card in the 40 D or thr 400d. Then transfer to the 50D that way you know that the card can be formated in a canon camera. Then try to format in the 50D. I have no problem switching cards between a 350D and the 50d so I am inclinded to think that there is something wrong with the camera.
Canon 50D, Canon 100mm f/2.8 IS L, Canon 20-35mm f/2.8L, Canon 70-300 f/4-5.6 L IS and Kenko 1.4 TC :lol:
Gitzo G2228 with a Markins Q3, and assorted gadgets. :)
The Iris Patch
jonathan41
Aug 12, 2009 10:14 |  #12
Hi guys. Well i have tried both cards in the 40D and they dont work in that. Isd it possible the 50D has done somethingt o them when i followeed the onscreen instructions to reformat them??...
I have then been on my PC and reformatted them to FAT32, but it hadsnt made any difference to the CF cards. Neither will work in either cameras now...HELP!!!
Im a bit sick because both cards were working perfectly weell yesterday int he 40D, both are extremeIV , one being an 8 the other a 4!!
jonathan41
Aug 12, 2009 10:21 |  #13
sorry about spelling1!! its my frustration coming out..lol
mprayii
Aug 12, 2009 10:25 |  #14
are you able to return the camera? And its rather weird that both cards are not working. I believe fat or fat 16 only supports 2 gb, but it could be worth a shot. have you tried formatting it within the camera after using the pc?
Roach711
Roach711's Avatar
Joined May 2004
Farmington Hills, MI USA
Aug 12, 2009 10:28 as a reply to jonathan41's post |  #15
I have heard of devices killing CF cards. If they worked fine before in the 40D and don't after attempting to use them in the 50D I'd conclude the 50D caused the problem. I certainly wouldn't try any more CF cards in the 50D.
Sorry to say, it's time to send the camera back with a request to replace the dead CF cards. The retailer probably won't honor your request, but it doesn't hurt to ask.
50D, 100-400 L IS, 100 Macro 2.8, 24-105 L IS, 420EX, No talent
Shoot 'em all and let Photoshop sort them out.
19,087 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00138 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Dastarblazer
759 guests, 306 members online
