Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 16th of August 2009 (Sun)   #1
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
Default Review: Promote Control advanced remote shutter control
My Times With The Canon TC-80N3
I've been doing night shooting for some time now. I purchased a Canon Remote Timer shutter release, the TC-80N3. This is a very nice piece of equipment, though I understand that you can get (much) cheaper clones nowadays. I like the TC-80N3 quite a bit, since I don't like to touch the camera during long exposures.
Then I started playing with HDR shooting (not always garish!). The TC-80N3 allows HDR night exposures without ever touching the camera, which allows for excellent alignment of frames. I could set the remote's Long Exposure for 1 second, take the shot, set the remote for 2 seconds, shoot, set it for 4 seconds... and so on. It is great for night HDR shooting.
I ran into a couple of scenes that showed a limitation of the TC-80N3: I couldn't set the shutter speed for less than 1 second. I had to touch the camera if the HDR series spanned that 1-second mark - for instance, if the scene decreed that the shutter speeds had to be 4 seconds, 2sec, 1sec, 1/2-sec, and finally 1/4-sec. In a situation like this, I had to manually change the camera settings for the last 2 shots. This caused some alignment issues, since touching the camera invariably meant that I'd knock it slightly out of position. The short shots only captured the small, bright lights, but they easily showed alignment issues. This was in the days of CS2 and Photomatix 2, neither of which allowed good alignment of frames. I had to manually align frames in the stack, which was not easy.
This played absolute havoc with the idea of doing HDR panoramics, another thing I enjoy.
Researching A Solution
So I began to long for a device that would remotely control the camera, much like Breeze System's PSRemote or DSLR Remote Pro packages. I like to travel light, so I didn't want to carry a laptop around - and I didn't want to pay for a laptop just to take pictures. (I also didn't want to be displaying a laptop in the back alleys of Boston, either.) Breeze's software is a perfect solution, but a very expensive, cumbersome one for me.
But there was nothing else, so I gave up the search.
Recently I got hooked on HDR photography. I got the bug. So I started researching again. Little "netbooks" could be had for a few hundred bucks. They were small. I started debating. I started looking for even-smaller netbooks, which were quite expensive. I found tiny devices, like smartphones, but none of them ran the OS that Breeze requires.
I found a couple home-brew devices, one using an Arduino (http://newyorkpanorama.com/2009/01/2...-with-arduino/) and one using a Nintendo DS (http://panocamera.com/blog/?p=26). But neither are commercial products, and I can't build them myself, so they are out off my list of possible solutions. They'll probably be available sometime in the future, but I have no patience, so I kept searching.
Last week I stumbled upon a post here that mentioned something called a Promote Control device. I did some research. It was exactly what I wanted. Exactly.
But it was $300! Plus another $15 for shutter release cable. Ouch! (By the way, the shutter release cable isn't necessary, but it is very, very beneficial to own).
So I researched some more, and debated. A few hours later I showed the Promote Control web page to a coworker. We had been both researching and discussing small laptops for the last week, so he knew exactly what it was. I mentioned the seemingly expensive price tag of this Promote Control, and he said: "It's cheaper than a laptop, and a heck of a lot smaller. It's EXACTLY what you've been looking for!"
I ordered the Promote Control five minutes later, from Adorama. For some reason they don't have the N3 cables, but I found one shipped directly from Amazon (who doesn't carry the Promote itself - go figure).
What The Heck Is A Promote Control, Anyway?
The Promote Control is an advanced remote shutter release system for Canon and Nikon cameras. It allows four modes of control:
One Shot
Acts like a standard remote shutter. Press the button and it takes a picture. The Promote allows you to take a picture using the current settings set on your camera, or you can dial in a specific exposure time in hours, minutes, and seconds. Note that you can not specify sub-second exposures, like 1/125th.
Manual Hold
Hold the button down, it holds the shutter open. Let go of the button, the shutter closes.
Time Lapse
Take a preset number of photos, separated by a specified interval. The exposure can be set in hours, minutes, and seconds (again, no sub-second settings), or you can set the camera with the desired settings. You can set the number of frames to shoot - up to 999 by the looks of the menu. The interval can be set in the same way - but note that you can't set anything less than 1 second for an interval. It would be nice to set an interval of 0, which would be great for astrophotography and stacking images. You can set a delay, in second, before the sequence starts.
High Dynamic Range
Take a specified number of photos, incrementing the shutter speed for each, in order to capture the full dynamic range of the scene rather than the limited dynamic range that the camera can capture in a single frame.
For those of you who aren't used to HDR, this allows you to take, for example, 5 photos set 2 stops apart in order to capture all the details in a scene where the dynamic range exceeds the capabilities of the camera. The images can then be merged into a single image that captures all of the details in the highlights and shadows.
Wikipedia article: High dynamic range imaging
POTN Post: HDR : Tutorial And Information Links
This mode is where the Promote Control really shows its abilities. It's the most interesting mode to me, since it absolutely crushes the TC-80N3's limitations with HDR.
For this mode, you set the desired middle exposure, the EV step, and the total number of shots to take. The Promote figures out the correct settings for all the other shots, and steps through them automatically, without any delay. You can set the EV step in 1/3 EV increments, and you can set the number of shots to any odd number from 3 to 45. Yes, 45 shots set 1/3 EV apart! Wow.
Some Neat Tricks
The Promote Control can be configured to engage mirror lock-up, whether you have it enabled on the camera or not. (As long as the camera can do MLU, of course.)
The delay between locking the mirror and taking the picture can be set from 1 to 20 seconds. You have to go into Setup to set this delay, but MLU can be enabled or disabled from any of the mode settings screens.
It can focus for you. Yep, it has a Focus button on the front that works like the shutter button. Press the Focu button and the lens does its AF thing. Pressing the Focus button and holding it is just like holding the camera's shutter button down halfway. Alas, this doesn't work with back-button focus - which isn't a big deal for me, since I wouldn't want this feature for night and HDR shots. But it could be an issue for someone. This problem, however, is easy to fix - just set your camera to have auto-focus control on the shutter button (i.e.; the factory default) and it works perfectly.
You can set really long shutter speeds - up to hours.
The Promote Control Unit
The Promote Control unit can be seen here: http://www.promotesystems.com/produc...e-Control.html. I'm not going to post any shots of it, since I don't really think it's necessary.
The control unit is a bit larger than a deck of cards - about 1.5 times as thick, and about an inch longer. It measures 4.9 x 2.6 x 1.1 in (125 x 65 x 27 mm for metric-minded). It can easily fit into a shirt pocket, and weighs about 6 ounces with batteries. Extremely portable.
It comes with a thin wrist strap, a special USB cable, and a very nice carrying case that is too small to hold the manual or both cables.
AA batteries are included.
The unit is very-well constructed. This is a fine piece of work, really. There are four input connectors on the front (AC power, USB cable, shutter cable, and "accessory" whatever that might be) and they are covered with rubber-like material to help seal them from the elements. The battery cover door is lined with a rubber seal for the same reason. I'm not sure if the screen has similar protection, but it looks like it would do a fine job of protection against mist and spray and such. All of the buttons are raised "squishy" buttons, so they're also protected.
The unit has a wide plastic "loop" that can be used to hold the included wrist strap.
Another reviewer on another site (http://www.hdrlabs.com/cgi-bin/forum...=1247806902/14 and http://www.panoguide.com/forums/commercial/6520/) commented that the unit needs a way to attach it to a tripod. His solution can be seen in either of the links above, and I'm sure that I will do something similar. From those links, it seems like Promote is going to do something about this. Until then, it's a simple problem to solve.
The carrying case is fairly nice, other than its size. It's made from a fairly stiff material, so it's not going to provide a lot of shock protection but will help. It zippers about 3/4 of the way around, so it flips open and lies flat. There's a wide rubber "belt" to hold the unit in, and a mesh pocket on the other side. I have no idea what this mesh pocket is supposed to hold - the manual doesn't fit, and the case won't close if you put a cable in it. This unit really requires 2 cables - it would be really, really nice if the case held the unit and both cables.
Using The Promote Control
It does everything it says it does - as long as you purchase the shutter cable. And that's not a knock against them - they can't provide a cable for every single camera it supports. I'm just trying to let you know that you really want one.
It does everything it says it does, easily. I only had to reach for the manual once, to figure out why my shutter cable wasn't working. That's when I found out how to get into the Setup menu (press both Mode and Start) since you have to enable it. The other menus and extremely easy to use and understand and change. OK, here's your other usage guideline - on the 4-way controller on the front of the unit, press the left button to cycle through items to change. The center button confirms the setting. You no longer need to read the manual.
A Major Problem
OK, my Promote Control is not perfect.
The major glitch first - the battery compartment in my unit did not have one of the strips of metal that connects the batteries in series. That is, only one end of each of the batteries make electrical contact with the unit, and that doesn't make a full electrical connection between the two batteries. I popped in the batteries, and they fell right out. They did not make full electrical contact with the unit, and - of course - the unit wouldn't turn on.
Needless to say, at 8 PM on a Friday night - with a dawn shoot planned - my unit was useless. Scream this aloud: "ARGH!"
I got around this easily - I taped a piece of wire to connect the 2 batteries together and make the necessary connection. But I was fairly PO'd for a while. This is just pathetic quality control at its worst. This is not good.
But I'm not worried about it, either. From reading the web, and finding a discussion of another user's problem, I think they'll fix my problem right-quick. If not, I can return it to Adorama and get another one - it's only 2 days old, and came defective. Stuff happens. I got over it.
But I'm still not happy with their quality control, and I'll be speaking to them in a curt tone of voice.
A Minor Problem
When I got my unit powered up, I went right into HDR mode. But it would not take a picture if the exposure was greater than 10 seconds. I set up a string of 3 shot at 5s, 10s, and 20s. It would not take the 20s shot, and gave me an error message. I spent almost an hour trying to get this to work.
Well, it turns out that I was the problem, not the unit. Somehow I didn't plug the shutter cable release into the unit in all the way. Three times. I finally saw it dangling out, and once I plugged in completely everything worked perfectly.
Right now, I have to say this was my fault. User error.
Then again, I plugged this cable in 3 times, and 3 times it wasn't plugged in enough t work properly. Was it really me, a bumbling fool who couldn't plug a silly stereo jack in correctly? Yes, it probably was me. But I'm going to keep an eye on this one.
The Other Problems
So far, none.
There are a few things I wish this did, or did better, but it works as advertised.
Pros
Works as advertised.
Does it all very well, and easily.
Excellent construction!
Cons
None for my needs. But read below since you may see something that is a Con for your needs.
Possible Improvements
For Time Lapse mode, it would be very nice to be able to set an interval of 0, so that it takes the next shot immediately. I can see this being of great importance to astrophotographers who wish to take many exposures and stack them. The forced 1-second delay may cause dashes instead of clean star steaks.
You can set the exposure time for Time Lapse and One Shot modes, but only in 1-second intervals. It would be very nice if this unit could set sub-second shutter speeds, like 1/250th. The real frustrating thing is that these shutter speeds are available for the middle exposure used in HDR mode.
I really wish the carrying case were a little bigger. Although I said earlier that it isn't big enough to hold both cables, I was able to squish them both in. JUST barely. And this isn't an exercise that I'd want to do at night in the field. Funny, I think this is my biggest complaint.
(Promote, if you're listening: Don't make the case thicker, make it wider! Then the cables could be folded and placed under the rubber strap so they're held in place, too. Besides, I hate thick things in my camera bag. Thinner is better. And don't make it hold the manual. It's easy enough to use - you won't need the manual in the field.)
The Focus button only seems to work if the camera is not using back-button focus. A LOT of us HDR and night shooters use back-button focus because that means the focus point will never change during a sequence or while taking shots to test exposure. Granted, this is a minor thing, and the camera can be set back to the factory default setting. And, personally, I doubt that I would ever use the Focus button.
A way to hold this onto a tripod would be good. Again, this is minor. It's too easy to solve in many ways, and Promote does include a carrying strap so you can at least hang it on the tripod.
Once you start a series of shots you can't stop it unless you turn the camera off. Even the TC-80N3 has a start/stop button, and you can cancel a sequence at any time.
Back to my cable user error problem. I think there's a possibility that the cable connections could be better. Or maybe it was just me. Again, I'll keep an eye on this.
Once again to my cable user error: It would be nice if the unit could detect that the shutter cable wasn't available, and give a clear error. Instead, I got things like "Manual exposure mode could not be set" and "Error setting exposure time". The manual listed these errors, but implied that the camera was not compatible with the attempted setting. Looking back, that was less-than-helpful, and frustrating.
Final Words
In a nutshell, this is an excellent unit. It works wonderfully, is very well-constructed, and does what I've wanted to quite some time.
Yes, it's expensive at $300. But there's nothing else like it, it works well, and the next solution (a laptop) is at least twice the price and 5 to 10 times the size and weight. I like small things like this Promote Control, since I like to travel light.
In a nutshell, I highly recommend this product.
(Note that I have absolutely nothing to do with Promote Systems. They've never heard of me - well, they will tomorrow when they read my email about the battery connection issue. This review is just my way of giving back to the community, with the hope of introducing this very neat device to someone, or helping someone make the decision to purchase one, or not.)
Promote Systems Website
You can read their web page about this device here: Promote Control from Promote Systems
Purchasing
The unit can be purchased from Adorama, or directly from Promote. The price is the same. Note that Adorama does not - at the time of this writing - carry the shutter cables, so you might want to purchase both from Promote. I got my cable from Amazon.
Promote Systems has a "Dealers" listing on their website which does not list any dealers at this time. (The least they could do is list Adorama - hint hint.)
Note: Many, if not most, of the cool features listed in this review require the purchase of the optional shutter release cable. If you're interested in a Promote Control then you want this cable. Trust me. You have to get one specific to your camera, so it's not included and must be purchased separately.
(I don't have anything to do with Amazon or Adorama, either.)
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Old 17th of August 2009 (Mon)   #2
Scottes
Scottes's Avatar
Default Re: Review: Promote Control advanced remote shutter control
Update: I just spoke to the owner of Promote Systems, and they're taking care of the battery compartment problem tomorrow.
Apparently it was a clear case of "stuff happens" - my unit failed quality control, and was put aside. Someone else came along and shipped it out thinking it was OK.
After having spent 5 years in quality control, I know that this is a lousy, absolutely embarrassing situation - and I could hear that in John's voice on the phone. It was good to hear him clearly show such concern.
Old 25th of August 2009 (Tue)   #3
rustyjaw
rustyjaw's Avatar
I just ordered one! I've been hoping for something like this for a long time. I can't believe camera manufacturers limit the flexibility of the bracketing functions so much.
flickr | website | vimeo | my book
rustyjaw is offline   Reply With Quote
Old 27th of August 2009 (Thu)   #4
rustyjaw
rustyjaw's Avatar
Bleh, well mine appears to be defective. The display only intermittently shows any text, most of the time it is blank. The unit seems to function based on hitting buttons and watching the camera respond, but it's useless without the display.
I wrote to Promote Systems, so we'll see what they say.
Old 27th of August 2009 (Thu)   #5
rustyjaw
rustyjaw's Avatar
They are going to replace it. I'm pretty disappointed that I won't be able to use it today, but such is life.
Old 27th of August 2009 (Thu)   #6
Scottes
Scottes's Avatar
This kinda sucks that they are 0-for-2 for purchased units. At least they seem to be quick to take care of the issue. I had a phone call within 10 hours of sending an email (Sent on a Sunday night) and it seems like they replied to you in less than an hour. Bad shipments, great support.
I'm hoping this is new-product jitters, and that they'll get things down and this kind of problem will go away quickly.
Old 27th of August 2009 (Thu)   #7
Scottes
Scottes's Avatar
I almost forgot about this... On another forum, someone asked a very good question:
"Why not just get a netbook or small laptop?"
Since I had thought about this same things for some time, I answered with the following:
As far as comparing to a netbook, I most certainly thought about that. I was thinking long and hard, until I stumbled upon the Promote thanks to a post that pointed me to [a thread on another site].
Netbook pros:
Versatility! Viewing photos, storing photos for long trips when you don't have enough cards, storing manuals, mapping software, GPS maybe, Internet access, yadda yadda yadda. You can't beat the versatility of a laptop.
Netbook cons:
Size & weight. I like to travel light. A netbook is 5 to 10 times the size and weight of a Promote.
Field use. How are you going to set this up? Sit on the ground and hope the cables reach? (They won't.) Add something like flip-out "legs" to your tripod to make a table? Hold the laptop in your hands during the whole shoot? Sure, all of those are possible, and can be done, but at a large pain-in-the-butt factor IMHO. And possibly with added weight, if you do something like a tripod attachment to hold it.
Power limitations. A spare set of AAs will keep the promote going for a long, long time. Far longer than a netbook. A spare laptop battery is always possible, but at a much, much larger cost of size, weight, and price compared to a set of AAs.
Price. First, remember that you'll need to spend $75 for Breeze Systems remote control app. (I couldn't find any alternatives to do what I wanted to do.) Then the laptop itself: The cheapest laptop I could find was a small Dell for $350. The smallest laptop that could run Breeze was a Sony for $1000. (Breeze needs real Windows, not Mobile or CE.)
Promote pros & cons are pretty much the flip of everything above. [It's small, light, cheaper, tremendous power life with a couple spare tiny AA batteries, easy field use, etc.]
Now compare to a good timer remote like the Canon TC-80N3. Price is $142 on Amazon, about half of the Promote. It does less than the Promote - but not by much unless you do HDR. (Um, isn't that why we're here on this forum??)
And Promote will be adding capabilities, too. I was talking to the owner, John Moran, and they have some plans for adding features. They plan on doing Depth Of Field calculations in the next version (or real Soon Now). They can possibly keep adding software features that will blow a TC-80N3 out of the water.
Comparing back to a netbook, in many ways there are no comparisons. They're so very different, in size, cost, weight, power life, and especially capabilities. If you want all those other capabilities of a laptop or netbook, then it should be an easy decision. If you want the small size and weight of the Promote, it might be an easy decision. If you don't really need all those netbook capabilities, that makes the decision easier.
And that's how i ended up with a Promote: I wanted small and light, I didn't want the netbook hassles of weight and field use, and I don't need or want the capabilities of a netbook.
Sure, if I had a netbook I would do all those things, no doubt - but they were simply unnecessary to me, and didn't even make my list of considerations when deciding. I truly did not want a netbook, for all the cons listed above. But I was almost ready to deal with one just to get the features of the Promote. So I'm very glad that I found the Promote.
Old 27th of August 2009 (Thu)   #8
rustyjaw
rustyjaw's Avatar
Yeah, a netbook isn't really an option for me. I do a lot of "urban exploration" shooting that requires a lightweight setup. It's why I carry my gear in a hip-bag, and why my tripod only weighs 2lbs.
Old 27th of October 2009 (Tue)   #9
Addicted2EOS
Addicted2EOS's Avatar
Hoping to revive this thread. Have the problems been fixed? Now that you have owned it for awhile would you reccomend it.
I have a 40D and want it for HDR bracketing!
Thanks!
Canon 40D and more lenses than my wife knows about...
Addicted2EOS is offline   Reply With Quote
Old 27th of October 2009 (Tue)   #10
Scottes
Scottes's Avatar
The problems with bad units, as experienced by myself and rustyjaw, has been fixed. It was a one-time double-failure - units that failed QA were misplaced and got sent out as good ones. So the problem happened, QA caught it as they should, but then someone misplaced the bad units by putting them into the "good" pile.
I've talked to the folks there a few times about both issues (failed units and misplacement) and have been assured they were both fixed. My conversations with them gave me a lot of very good feelings for everything to do with their product and support.
I wholeheartedly recommend them. Easily.
I've been using it for months now, and it has performed flawlessly every time - as long as I remember to set my camera to Manual mode and Single-Frame mode (not burst or timer).
It's a great device.
The fact that this is such a dead thread is kind of a bummer given all the HDR enthusiasts around here. You might want to keep an eye on this thread, over on Christian Bloch's forum:
http://www.hdrlabs.com/cgi-bin/forum...num=1247806902
There's much more activity and information in that thread.
Old 27th of October 2009 (Tue)   #11
DANATTHEROCK
DANATTHEROCK's Avatar
Be sure to contribute any thoughts here as well
http://photography-on-the.net/forum/...d.php?t=771873
Looking to buy one of these myself.
Canon 5D Mark II & 50D with 17-40, 24-105, 100-400, 50 f/1.4, 100 f/2.8 macro, and 1.4TC
FEISOL CT-3442 (ARL) tripod w/ Photo Clam 40-NS ballhead
DANATTHEROCK is offline   Reply With Quote
Old 3rd of November 2009 (Tue)   #12
Addicted2EOS
Just ordered from one from Adorama (using a 10% Bing promo). I sure hope it works for me.
Old 2nd of November 2010 (Tue)   #13
DougHerrick
I recently tried this unit with my 5Dm2. Bottom line: It just didn’t work. Customer Service was frustrating as they refuse to use the phone. I returned the unit after several days delay due to the repetitive emails exchanged. Like “are you sure it’s plugged in?” Maybe they have a lot of problems solved because people who spend $300 on a camera accessory aren’t savvy enough to insert a plug. They returned the same unit back to me after they determined there was nothing wrong. Same unit! At least they could have tried a different unit. I knew it was the same unit because the batteries that came with it were dead and I used my own, which were still installed (shouldn’t they be removed for shipping?). Between the time they shipped it back to me and its return I got an email from them apologizing, that they in fact admit there is a problem with the firmware support for my particular camera and provided another beta update to their previous firmware update(why was this not done prior to returning?). I’m sure that the many happy users, for whom this unit works with their camera, aren’t wrong, but, it did not work with my 5Dm2.
DougHerrick is offline   Reply With Quote
Old 3rd of November 2010 (Wed)   #14
Addicted2EOS
That's a shame. I love mine and it works great with my 40D. Now I am concerned as I assumed the 5Dm2 was my next body.
Old 3rd of November 2010 (Wed)   #15
PicSniper
PicSniper's Avatar
The 7D and 5DII have known communication issues with the Promote Control. Apparently, once the camera goes through its "timeout" (the 4-5 seconds after a half-shutter press when the data in your viewfinder disappears), communication via the USB cable becomes erratic. The band-aid solution for this problem (one that they suggested and it worked for me) is to press the "Focus" button on the Promote Control before pressing the "Start" button in whatever mode you may be in. Since hearing of this workaround, my unit has performed properly in "One Shot", "High Dynamic Range" and "Manual Hold". I have not tried this in "Time Lapse" mode, yet, so I can't say for certain whether the workaround works in this particular mode. The folks at Promote Systems know of this communication issue and are, according to them, currently working on a new firmware revision that will remedy the problem.
I hope this helps!
Good luck to you...
Hello, my name is Victor.
My Gear List
PicSniper is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advanced Remote Control for Digital Cameras tonybear007 Accessories & Storage 6 1st of July 2009 (Wed) 22:31
Remote Shutter/Control bomberman Accessories & Storage 2 10th of June 2008 (Tue) 12:38
Phottix Wireless Remote Control Review orisky Accessories & Storage 2 12th of January 2008 (Sat) 17:37
Nokia Hands-free Remote Control as a Remote Shutter Release 4walls Canon EOS Digital Cameras 0 28th of March 2004 (Sun) 20:52
