#1 |
Hi, I feel I did a fairly extensive search for this situation before and didn't find anything. My apologies if I missed a thread on this.
My gear: 1 MiniTT1 1 FlexTT5 1 580exII 1 430exII My situation: MiniTT1 on xti hotshoe 580exII on FlexTT5 hotshoe 430exII fired by IR from 580exII When the 580 is set to master, and 430 is set to slave, (pw's off) the master can fire the slave (using the test button). Once I connect the flex to the 580, the test button on the 580 no longer fires the 430. When I press the shutter on the xti, neither the 580 nor the 430 fires. When I press the test button on the MiniTT1, the 580 doesn't fire. Touching nothing else, but changing the 580 from Master to normal, the xti can fire the 580. Thanks in advance!
My flickr Rebel XTi, BG-E3, 18-55 kit, 50 1.8, 70-200mm f/2.8 L IS, 28-135 IS, Tammy 17-50 2.8, 580EX II, LP120, 7MDH, 46" Softlighter II |
| sponsored links |
#2 |
there has been known issues of firmware issues with the new pocketwizards. check to see if you have the latest firmware for the pocketwizard. that's what i recall someone else who had the same problem
Flickr |Gear|The-Digital-Picture|The $6 mic for 5dmkii | MAGIC LANTERN | Tundra underwater kinetic cases are great, affordable alternatives to pelican cases. Go Support Magic Lantern 2.3!! |
#3 |
Thanks for the quick reply.
I just checked using the PocketWizard Utility and it says I have the most recent version - Version 4.3
| sponsored links |
#4 |
hmmmmmmmmm..... not sure what to do. scan the forums with the search function and see if you turn up with anything. if i had a set of those pocketwizards i could be more helpful, but i'm using cheap ebay triggers and suffer with their manual abilities
#5 |
Do you need another Flex to fire the 430? I didnt think they could control the master/slave element of the speedlights.
Click Here and Join the POTN flickr Group Today! |
#6 |
Don't know if you have a second flex on the 430 but if you don't, you need one. The slaves should also be set to normal ETTL, not 'slave' mode, and the groups set using the group switch on the flex. Ratios will still work.
Just to clarify, are you saying the camera will fire the flash via the flex in normal mode but not in master mode? The test button on the flash is disabled once you attach the flex so don;t expect it to work. The test button on the flex should work though and the camera should be able to trigger the flex in any mode. Are you sure you don't have the flash configured to not fire in master mode? |
#7 | ||||
#8 |
Pretty sure the flex disables the normal communications of the speedlites (otherwise the slave would be getting two sets of instructions) so I don't think you'll be able to get them to slave without a second receiver.
| Thread Tools | |
| Display Modes | |
| MiniTT1/FlexTT5 WITH Skyport's on top? | aznmarkofdafiji | Small Flash and Studio Lighting | 10 | 25th of June 2011 (Sat) 03:41 |
| MiniTT1/FlexTT5 ETTL Metering? | Redfire_Cobra | Small Flash and Studio Lighting | 19 | 21st of July 2009 (Tue) 15:02 |
| Multiple 580EXii with MiniTT1/FlexTT5 | texshooter | Small Flash and Studio Lighting | 1 | 23rd of June 2009 (Tue) 13:52 |
| 5D Mark II / PocketWizard MiniTT1/FlexTT5 and 430 EXII Speedlights: Help! | PubUltraStar | Small Flash and Studio Lighting | 11 | 26th of May 2009 (Tue) 21:58 |
