Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 21st of August 2009 (Fri)   #1
JoshTPhoto
Default Recommend Canon Sd1200 w/underwater housing or Canon D10
Anyone have thoughts on if I should buy the WP-DC29 underwater housing for the SD1200 or just purchase the D10 instead of the SD1200 combo?
Uses would be the pool and beach. I reckon the DC29 seems a little much for casual use. Although the D10 looks a little bulky.
Josh
5D II :: 24-70 F2.8L / 70-200 F4L IS / 85 F1.8
JoshTPhoto is offline   Reply With Quote
Old 22nd of August 2009 (Sat)   #2
kja
kja's Avatar
Default Re: Recommend Canon Sd1200 w/underwater housing or Canon D10
I'd probably go with the camera and housing just because I spend a whole lot more time on land than underwater and when I take my compact, I want it SMALL.
Either, either I think you'll have a good system and lots of fun
kja is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cheapo Underwater Housing for SD1200? Pitter Small Compact Digitals by Canon 4 4th of July 2009 (Sat) 23:28
Canon SD880 IS Underwater Housing... chinoamigo Small Compact Digitals by Canon 3 21st of May 2009 (Thu) 21:33
WTB - Canon Underwater Housing for G9 Cam101 Classifieds: Buy 0 5th of April 2008 (Sat) 15:16
Why no canon underwater housing for G series Freeflyer Canon G-series Digital Cameras 7 6th of September 2004 (Mon) 00:51
Canon S50 and underwater housing euren Small Compact Digitals by Canon 3 9th of January 2004 (Fri) 09:43
