Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 25th of August 2009 (Tue)   #1
texshooter
Default Multiple speedlites to one remote receiver???
Is it possible to connect, say, three 580exii's to a single Cybersync or PW transiever? There's got to be a splitter cable to allow a gang of stropes to be fired from the same receiver trigger, so I don't need to dangle so many triggers on top of each other? But then maybe I need a reality check.
texshooter is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #2
DYORD
DYORD's Avatar
Default Re: Multiple speedlites to one remote receiver???
correct me if I'm wrong....
i think using a 580EX II, u can use 1 transmitter and a 580EX's receiver then the rest can be slaves of that 580EX that has a receiver...
Body (w/ transmitter)
580EX - A - Master ( w/ receiver )
580EX - B - Slave
580EX - C - Slave
Canon 450D; Kit lens 18-55mm f3.5-5.6; 50mm f1.8, 55-250mm IS; 430EX II.
http://www.flickr.com/photos/dyord/
DYORD is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #3
TMR Design
TMR Design's Avatar
You can safely split sync and feed multiple slaves from one trigger.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #4
Kevin Song Photography
DYORD is correct - that'll work, but obviously not with the non-dedicated off camera manual flash units that a lot of people use for this stuff.
But yes, I believe you can split and use multiple flashes from one trigger. I know the cheap-o eBay ones can, and I see no reason why Cybersyncs or PWs can't. Nothing special going on, it's a simple switch/trigger - nothing that a split will affect.
Canon EOS 7D | Canon EOS 1D mark II
Tamron 17-50mm f/2.8 XR Di-II LD SP ZL Aspherical (IF) | Canon 80-200mm f/2.8 | EF 50mm f/1.8 II
Speedlite 580EX
Kevin Song Photography is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #5
texshooter
Anybody know the make and model of such a splitter cable. To piggy back two speedlites, the splitter cord would have to have two PC connectors that each goes into the flash units and one 2.5mm male mono connector that goes into the trigger.
But wouldn't the electrical signal that is sent from the trigger up two separate cords to the flash units be weakened to the point of failure? I would think the signal might become delayed.
Old 25th of August 2009 (Tue)   #6
TMR Design
TMR Design's Avatar
Hermes has successfully split sync numerous times. He used something like this:
http://store.purplus.net/bero53hesp.html
The plug is connected to the sync jack of the trigger. Then you use miniphone to Nikon screw lock cables to connect the individual jacks on the splitter to the flashes.
If you want to look into this further you can check out the thread Hermes had started:
http://photography-on-the.net/forum/...d.php?t=680745
Old 25th of August 2009 (Tue)   #7
texshooter
That Belkin splitter looks amazing. I'll have to pick one up.
Old 25th of August 2009 (Tue)   #8
Mark1
Mark1's Avatar
They have PC cord splitters as well if you are useing a PC cord.
http://www.bhphotovideo.com/c/produc...c_Adapter.html
Keep in mind "Its not the camera, its the photographer" works just as well for bad pictures as it does for good ones.
www.the6by6frame.wordpress.com
Mark1 is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #9
mufutau55
mufutau55's Avatar
If you want to do it with wire, you could use the splitter below, it uses 3.5mm and you coulod connect five flashes to it using one trigger and using more for more splitters. I have the same setup inspired by Hermes and tested it with out three flashes and it works, Hermes has also done the same here and confirmed it worked too.. So, see the link below, it's only $13.99 but you need to buy five more 3.5mm to 3.5mm long cables:
http://www.amazon.com/Belkin-RockSta...1240861&sr=8-1
Mufutau
mufutau55 is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #10
Redfire_Cobra
Redfire_Cobra's Avatar
Does anyone know if this is possible to do with a PW FlexTT5 and retain ETTL, at a reasonable cost? I found a cord to do so on Amazon but it was only 30 or 40 less than a new PW transmitter.
Canon 60D
Canon 50 f/1.8, Canon 70-200L f/2.8,
-Chris
Redfire_Cobra is offline   Reply With Quote
Old 25th of August 2009 (Tue)   #11
aram535
aram535's Avatar
I think the only thing you have to worry about is length. With standard receivers all it is, is a simple on signal short and to the point. However the longer each of the runs, and the more times you split it, the less power is going to be going to each receiving station.
I would think, though have not tested it, that the Flex doing ETTL, actually talks to the flash and is more than just a trigger.
Gear List * www.tranquilphotos.com * My Blog
aram535 is offline   Reply With Quote
Old 26th of August 2009 (Wed)   #12
awdark
I am probably being a pessimist here but is there a concern about the amperage going through the remote receiver? I know most of the flashes are the nice 6v or below ones, but if they are wired in parallel the amperage will be higher and more for the trigger to switch. I don't know what kind of switch or scr they use though.
Edit: looks like the other post did take a look at that issue seems fine O.o
awdark is offline   Reply With Quote
Old 26th of August 2009 (Wed)   #13
tim
Light Bringer
tim's Avatar
Originally Posted by awdark View Post
I am probably being a pessimist here...
Yes
...is there a concern about the amperage going through the remote receiver?
No.
tim is offline   Reply With Quote
Old 26th of August 2009 (Wed)   #14
Austin.Manny
Austin.Manny's Avatar
I am probably being a pessimist too, but why would you wanna buy a set of PW if you're just gonna use cords for the others? I would use the ETTL method.
400D Gripped | 35-80 f/4-5.6 III | Σ 30 f/1.4 | 85 f/1.8
Yongnuo YN-467 | Yongnuo YN-460 |
RF-602
Flickr
Austin.Manny is offline   Reply With Quote
Old 27th of August 2009 (Thu)   #15
photobitz
PlatinumMeasurebaiter
photobitz's Avatar
I assume the idea is to trigger a group of flashes in one place creating a larger burst eg. to counter the sun. No point using more than one PW for that sort of thing. It then leaves you with spare PWs for other flashes in your setup...
Why ETTL?
Dan
My gear | Me on Flickr
photobitz is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
how to position Multiple speedlites beaconlightboy Small Flash and Studio Lighting 16 5th of December 2008 (Fri) 17:36
Question about multiple Speedlites gooble Small Flash and Studio Lighting 6 5th of December 2008 (Fri) 08:36
Multiple speedlites BaumannPhotography Small Flash and Studio Lighting 0 21st of November 2008 (Fri) 18:06
Multiple Speedlites versus studio lighting DavidW Small Flash and Studio Lighting 13 7th of February 2006 (Tue) 12:01
Multiple Speedlites - Ratios Question markubig Small Flash and Studio Lighting 3 4th of February 2006 (Sat) 09:09
