Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 29th of August 2009 (Sat)   #1
FullStop Photography
FullStop Photography's Avatar
Default Diffuser/modifier for beach strobe lighting at sunset?
Recently did some model shooting down at the beach at sunset, using OCF and one of my Vivitar 285s (I would have brought my 580 but didn't want to risk it falling in the water). After some experimentation (lower shutter speed to bring in the background sky) I got pretty decent results, except the flash was kind of harsh. I was shooting the 285 bare, in wide mode with the wide diffuser screen.
Before I try another shoot with another model, I'd like to get opinions on what modifier or diffuser I should use to get a little softer light. I don't want to bring an umbrella or softbox, due to needing weights to keep the light from blowing over. I looked at the Lumiquest Big Bounce and Softbox III, but they both seem to be only effective at lighting close-up (i.e., lose too much power to light full-length). I could get a Stoffen Omni-bounce, but not sure that will do much either. Any alternatives? If I get really serious, I'll eventually invest in a AB1600 and their line of modifiers, but want to see what I can achieve strobist-style. Thanks.
website · facebook · tumblr
FullStop Photography is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #2
TMR Design
TMR Design's Avatar
Default Re: Diffuser/modifier for beach strobe lighting at sunset?
I understand what you're saying but at some point you're going to have to bring some sandbags or weights and use a modifier of some sort. Tupperware and Sto-Fen's are ineffective outside and just waste power and light.
You might want to grab a small softbox. It helps direct and focus the light and depending on the box you get you can use it with or without the front diffusion material to control whether you have more specular or softer nonspecular light.
Many of us use a beauty dish when it is breezy or windy. You still want to stabilize the stand but the dish doesn't act like a sail, as umbrellas or open boxes will. Most beauty dishes are available with a diffusion sock to soften the light is desired.
Having a modifier like a softbox or beauty dish will give you a larger light source and when used close to your subjects, it creates an apparently large light source.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #3
Thanks, Rob. I had a feeling this was going to be the answer but wanted to be sure. Do you think my 24" Ezybox would be worth a try, or would it be a waste of time/susceptible to wind? Just hate the thought of having to lug around sandbags/weights. Appreciate the feedback.
Old 29th of August 2009 (Sat)   #4
FlashZebra
This space available
FlashZebra's Avatar
If you are going to be on a "traditional" beach, sand for weight should not be an material in short supply that would require you to lug it from another location.
Bring some sort of ad hoc bags, or other suitable containers and make your weights on location.
Enjoy! Lon
http://flashzebra.com/
FlashZebra is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #5
Edbee
Edbee's Avatar
Been wondering if gallon milk jugs could be used rather than sandbags. Fill one or two with water at the site and tie them to the light stand, lifting them a bit off the ground. They should weigh around 7.5 lbs each.
Edbee is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #6
TMR Design
TMR Design's Avatar
A 24" EZYbox will work nicely. You can use it with or without the diffusion panel. At any distance, it's a much larger light source than the flash head on your Vivitar. Up close it's a nice large light source.
You can either carry a few sandbags or do as Lon is suggesting and fill them on the spot. Some people carry water jugs and fill them up when needed and then empty them when done.
Having a few sandbags in your car is easy enough and not any big deal to bring with you on a shoot. I have a lot of them and carry them in a duffel bag but when I'm shooting with a very small and light kit I have a daypack that holds 2 sandbags and since it's on my back I don't even feel it.
Lots of options. I would figure out the best way to have some sort of weight for stability and just do it so that you can make use of modifiers. To not use modifiers because of a little extra weight is only hurting your ability to capture better images IMO.
Old 29th of August 2009 (Sat)   #7
Excellent advice, thanks everyone. Lon, you're right, sand is obviously not in short supply, just need to get some ad hoc bags that will do the job (large ziploc?) and empty them afterwards. And Rob, you're right, being lazy is not conducive to better pictures.
Old 29th of August 2009 (Sat)   #8
TMR Design
TMR Design's Avatar
If you're going to use Zip Loc bags then make sure you place them in a heavier canvas bag of some sort. A Zip Loc is easily torn or broken. Use something with D-rings, loops or a handle so you have something or some way to attach it, hang it or bungee it to the stand. Keep your sand bags as low as possible at the base of the light stand. I place a sandbag over each leg brace so it's uniformly stabilized. It's about 30 pounds but once I'm set up that stand ain't goin' nowhere.
Old 29th of August 2009 (Sat)   #9
Hermes
Wear a white top, white trousers and bounce the flash off yourself. Large fill sources don't get any easier than that.
For sunset work, you really want to fill as subtly as possible. In a pinch I've bounced the flash off the sand on the floor in front of the model, and got far more natural results than direct lighting with any sort of modifier would have done, especially the tiny ones designed for speedlites. Make sure you're in control of the colour temperature of your flash and set the white balance accordingly.
Hermes is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #10
PhotosGuy
Moderator
PhotosGuy's Avatar
There's a low-tech solution, too, which is to bring a friend to hold the umbrella.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #11
TMR Design
TMR Design's Avatar
Not always possible Frank. I do a lot of location work by myself and you can only be so resourceful.
Old 29th of August 2009 (Sat)   #12
Joergeske
Personally I use my velbon tripod, a super clamp, and a light stand and combine them all into a very sturdy wind resistant boom. I put the velbon as the base and open it up to where it is spread fairly wide so it has a very large support, then I mount the super clamp to my tripod head and use the clamp to hold a small light stand. Instant boom with a massive base that is very tough to blow over. Setup takes me about 3 minutes. Also I generally try to use rocks and such in the field to put over the legs when I need extra weight. Sometimes with sand or gravel I just dig the legs in a bit too.
www.joergeske.com
Nikon D800, Nikon D600
Nikon 14-24 2.8AF-S G, Nikon 24-70 2.8 AF-S G, Nikon 70-200 2.8 VR AF-S G, Nikon 28 1.8G, Nikon 50 1.4G, Nikon 85 1.8G, Nikon 105 2.8 VR Micro
Nissin Di866II x2, Pixel King transmitters, PCB studio.
Joergeske is offline   Reply With Quote
Old 29th of August 2009 (Sat)   #13
Interesting idea, does that really work?
Color temp: do you mean greater fractions of CTO as the sunset gets more orange? White balance: I shoot RAW, but what would you recommend the WB be set at?
Old 30th of August 2009 (Sun)   #14
FlashZebra
FlashZebra's Avatar
For water wight estimation - "one pint, one pound, the whole world round."
Enjoy! Lon
Old 30th of August 2009 (Sun)   #15
ed.
ed.'s Avatar
Your softbox will be fine.
This was with a 60x60cm softbox on sunrise with a metz 54.
ed. is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
beach wedding sunset lighting tips? craiglee Weddings and Other Family Events Talk 18 4th of October 2010 (Mon) 07:36
Elinchrom modifier for accent lighting... symbolphoto Small Flash and Studio Lighting 29 23rd of June 2009 (Tue) 12:54
DIY Flash modifier/diffuser The_Terminator Small Flash and Studio Lighting 10 23rd of March 2009 (Mon) 12:50
New to lighting - Strobe or Continuous? TheGaffer Small Flash and Studio Lighting 26 3rd of May 2008 (Sat) 09:09
what's more important strobe or modifier? superstar Small Flash and Studio Lighting 1 12th of December 2006 (Tue) 13:42
