Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of September 2009 (Tue)   #1
benjo
Default Interfit 150 lights
I have two Elinchrom BX 400 lights. I am wanting two lights for background use only. Will the Interfit 150 lights be up to the job or will they not sync with the Elinchroms.
benjo is offline   Reply With Quote
Old 15th of September 2009 (Tue)   #2
steveathome
steveathome's Avatar
Default Re: Interfit 150 lights
They will sync, but you will find they are of a slightly different colour temperature/cast.
steveathome is offline   Reply With Quote
Old 15th of September 2009 (Tue)   #3
OneStrobe
Anyone know if two of these will be sufficient enough to blow out a white seamless background?
OneStrobe is offline   Reply With Quote
Old 15th of September 2009 (Tue)   #4
TMR Design
TMR Design's Avatar
Whether or not you can achieve pure white will depend on the size of the background, distance from subject to background and your shooting aperture.
If you're shooting at f/16 you may not have the power in your background lights to achieve the additional 4 stop reflective exposure on your background. If you're shooting at f/5.6 then you probably won't have a problem.
If the distance between subject and background is very limited then even if you have the firepower you may have to shoot at wider apertures so as not to cause wrap and have light returning from your background to the subject area. Remember, a 9 foot white background is acting like a giant reflector.
The term 'blown out' implies clipping. There is a difference between white with no detail and clipping. You want to have the correct amount of light hitting your background but you really don't want to blow it out, which seems to be a common misconception and incorrect use of the term. Pure white is not blown out.
Please call me Robert or Rob, not TMR
Gear List & Feedback | The Lighting Academy
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Interfit Lights! Smad728 Small Flash and Studio Lighting 2 7th of April 2009 (Tue) 14:15
for interfit 150 users muscleflex Small Flash and Studio Lighting 6 2nd of January 2008 (Wed) 07:17
2 580ex's or swap one for Interfit 150 studio kit? muscleflex Small Flash and Studio Lighting 7 23rd of September 2007 (Sun) 16:32
UK where is cheapest place for INTERFIT 150 kit? muscleflex Small Flash and Studio Lighting 4 25th of May 2007 (Fri) 12:32
