Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 18th of September 2009 (Fri)   #1
7up
7up's Avatar
Question why ( Mirror ) is a bad reflector ?
sometimes you need a reflector for the flash or for any light you use - to take a photo
so why ( Mirror ) is bad reflector ?
just a thought came into my mind.
canon 40D / sx200 /canon 28-135 is / canon 55-250 / canon 50 1.8 / sigma 105 / sigma 70-300/iphone4 /ipad2
Buying a camera doesn't make you a Photographer. It makes you a camera owner...
7up is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #2
XterraJohn
Default Re: why ( Mirror ) is a bad reflector ?
Who said that a mirror is a bad reflector?
XterraJohn is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #3
TweakMDS
TweakMDS's Avatar
A mirror only changes the angle of a lightsource. It does *not* soften it at all, which is mainly what you will use a reflector for. If you use a mirror to reflect sunlight or direct flash, rather than getting a soft, shadowless fill, you get almost an identical power of light the other way, including hard shadows.
Reflecting an umbrella or softbox will give pretty decent results though.
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr
"My featured shots"
TweakMDS is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #4
tim
Light Bringer
tim's Avatar
A mirror IS a bad diffuser, I tried it once. It's because it provides no diffusion.
tim is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #5
PacAce
Moderator
PacAce's Avatar
On the contrary, a mirror is a perfect reflector, as evidenced by the millions of them hanging in bedroom and bathroom walls all over the world.
But, as Tim pointed out, they are very poor diffusers. AAMOF, they don't diffuser the light at all unless they've become frosted on the surface.
...Leo
PacAce is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #6
tim
Light Bringer
tim's Avatar
A jug of hot water could deal solve the problem!
Old 18th of September 2009 (Fri)   #7
TMR Design
TMR Design's Avatar
Mirror's make excellent reflectors, and like any tool we use, you have to know when and how to use it. The late great Dean Collins used flexible mirrors outdoors to bounce some sunlight back on to his subjects for hair, edge and accent lights.
As others mentioned, a mirror is not a diffuser. It reflects very directional light and offers lots of contrast. When used correctly, it's a powerful modifier.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 18th of September 2009 (Fri)   #8
Hermes
Glass mirrors aren't great to use for anything larger than tabletop as they're heavy and shatter into dangerous shards pretty easily.
Unless you want the specfic effect a mirror gives you (reflection with a very defined edge), It makes a lot more sense to use a shiny silver reflector - they're lighter, safer, cheaper, more portable, and more practical in just about every way.
Hermes is offline   Reply With Quote
Old 21st of September 2009 (Mon)   #9
badaml
New to this as well, and I have seen some diffusers for speedlights that reflect some light forward (used as fill) while the rest is bounced. Has anyone tried to make something where if the flash is pointed one way, using a mirror with a diffuser in front to give a stronger diffused light, kind of like using a second flash?
badaml is offline   Reply With Quote
Old 21st of September 2009 (Mon)   #10
tim
Light Bringer
tim's Avatar
Kinda like this Metz flash?
Using a mirror on a flash doesn't sound like a great idea to me, the light will be too harsh.
Old 21st of September 2009 (Mon)   #11
badaml
Not really like that. I also said to use a diffuser, so why would the light be harsh?
Think of it this way: Point the flash straight up. Now tape a mirror to the back of the flash, so you can see yourself in the mirror. Now at the front of the flash, use a diffuser. Now the flash itself will bounce from the ceiling, but the mirror will reflect a lot of flash forward into the diffuser, giving you 2 sources of light. Now if you can make it look pretty and also adjustable, you would be all set lol. Just wondering why this hasn't been done, or if it has and is just a crappy idea lol.
Old 21st of September 2009 (Mon)   #12
tim
Light Bringer
tim's Avatar
It's called a bounce card, a white card comes built into a 580EX and you can buy bigger versions. The only difference putting a mirror there instead of a white card is the light will be more specular and less diffused. Putting a diffuser in front of the mirror would lose the advantage of having the mirror.
Summary: it's called a bounce card, it's been around for decades
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Icechest+Moon unit inner reflector= bad. bolantej Small Flash and Studio Lighting 2 3rd of April 2008 (Thu) 04:10
One light...and one bad reflector? jwinker Small Flash and Studio Lighting 12 28th of February 2008 (Thu) 22:43
500mm Reflector/Mirror Lens for EOS StaticThought Canon EF and EF-S Lenses 13 19th of March 2007 (Mon) 15:37
Mirror Slap Really Bad! soupdragon Canon EF and EF-S Lenses 16 29th of October 2005 (Sat) 15:06
bad shutter or mirror pinball Canon EOS Digital Cameras 5 31st of January 2005 (Mon) 08:37
