Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 1st of October 2009 (Thu)   #1
jack lumber
jack lumber's Avatar
Default IS THE LIGHT RIGHT?
I suffer from seasonal affected disorder (SAD) for which I use a light therapy lamp that emits 5000 lumes.
I have been exploring using this lamp as a light source, and would appreciate comments on this photo, and anything I could do to improve the lighting.
Thanks, Bob.
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8 580 EX 11 flash- manfrotto tripods and monopods.
jack lumber is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #2
philodelphi
philodelphi's Avatar
Default Re: IS THE LIGHT RIGHT?
What a couple of cuties! Seems too red.
http://www.davidbalick.com
Canon 5DII, 6D
philodelphi is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #3
jack lumber
Thanks, I have noticed that all the shots taken with this lamp are a little too ruddy.
I might try some kind of diffuser material to try and correct that, any suggestions?
Old 1st of October 2009 (Thu)   #4
philodelphi
I did this in Photoshop Elements in about 2 seconds. What do you think?
Canon 5DII, 6D
Old 1st of October 2009 (Thu)   #5
philodelphi
If you shoot raw, you can change the color balance with no data loss. Or, maybe you could put blue film in front of the light? I'd try to fix it in post processing.
Canon 5DII, 6D
Old 1st of October 2009 (Thu)   #6
GorgeShooter
GorgeShooter's Avatar
The white balance seems off. If you shot in RAW and use a PP program that has a W/B clicker, click the eye dropper on the white knitted blanket.
1DX | 5D MkII (gripped)
16-35 f/2.8L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/4L IS | 100-400 f/4.5-5.6L IS | 24 f/3.5L TS-E | 45 f/2.8 TS-E | 40 f/2.8 Pancake | 15 f/2.8 Fisheye | Tokina 100 f/2.8 Macro | Canon 1.4x TC | 580 EX II | 430 EX II | Manfrotto 055CXPRO4 | Kirk BH-1
:: Smugmug :: | :: Photography BLOG :: | :: Workshops and Classes ::
GorgeShooter is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #7
jack lumber
I like the edit David, but on my (uncalibrated) monitor the cheeks now look a tad hot.
Thanks for that GorgeShooter, will attempt a rework on the RAW file.
Old 1st of October 2009 (Thu)   #8
Benji
If you place an 18% gray card in the scene for the first shot as shoot in Raw your white balance can be made nearly perfect in ACR IF the original light source is not severly deficient in one or more of the colors in the spectrum.
Benji
Benji is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #9
jack lumber
Reworked the white balance, better?
Last edited by jack lumber : 1st of October 2009 (Thu) at 12:46. Reason: replace image
Old 1st of October 2009 (Thu)   #10
Flo
Gimmie Some Lovin
Flo's Avatar
I did this really quickly.but just to give you the idea ...
Thought this would eliminate the red issues. Sorry to hear about the SAD, but thankfully there are remedies for it!
With this light being used as a source, you will always be fighting the red.
Cute girls.
Flo is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #11
jack lumber
Aww thanks Flo, the real remedy would be not living in the land of NOD (not enough light!).
Old 1st of October 2009 (Thu)   #12
dimad
What is regarding lights I would say it is too flat. A volume of objects is getting lost when you're using front light. Try 45 degrees angle for the main light and a reflector opposite side of the light. I guess it will improve an image light pattern dramatically.
dimad is offline   Reply With Quote
Old 1st of October 2009 (Thu)   #13
Flo
Gimmie Some Lovin
Flo's Avatar
I hear ya Jack.....its starting here for many.although its the rain we need help with in the winter) Keep taking your daily dose of Vit D as well!
Old 1st of October 2009 (Thu)   #14
jack lumber
Thanks dimad will try that,, and welcome to the forum.
Hey Flo at least you don't have to shovel rain!,,,we have snow forecast for the weekend.
Old 1st of October 2009 (Thu)   #15
Flo
Gimmie Some Lovin
Flo's Avatar
Yikes! They had snow on the Coquahalla(sp?) the last few days. We are supposed to have sunshine next week.but right now I am eyeballing the woodstove!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Product Photography : Light Tent, Light Table, or HomeBrew StealthLude Small Flash and Studio Lighting 5 6th of April 2010 (Tue) 12:17
Viewfinder info light unusable in bright light conditions cookie99 Canon EOS Digital Cameras 3 9th of December 2007 (Sun) 11:28
needed a light for light tent and other general indoor/around the house shots troyer16 Small Flash and Studio Lighting 3 7th of January 2007 (Sun) 14:37
Help? Low-light, natural light, high-speed, fill flash juneappal Canon EOS Digital Cameras 14 23rd of June 2005 (Thu) 05:23
