Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Birds
Reply
Thread Tools Display Modes
Old 10th of October 2009 (Sat)   #1
Harvey_G
Harvey_G's Avatar
Default 7D Flight Shots... post-AF Microadjustment (LARGE POST)
I spent some time last evening doing AF Microadjustments on my various lens and TC combos with the 7D. Having done that, I wanted to get out this morning and try it out. I had hoped for some ducks and/or geese but all that was available in the air were gulls.
I was using the 7D with my 300 f/2.8L IS and 1.4xTC combo for all shots, hand held. The combo locked AF quickly and accurately.
There are 3 different flight sequences that follow.
The first is a head-on inbound flight sequence of 3 shots.
-Harv-
Residing in Cobourg, Ontario, Canada
Shooting with more great Canon gear than I deserve.
I don't need a second childhood. I'm not finished yet with the first one.
Harvey_G is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #2
Harvey_G
Harvey_G's Avatar
Default Re: 7D Flight Shots... post-AF Microadjustment (LARGE POST)
The next is a crossing flight sequence of 7 shots.
-Harv-
Old 10th of October 2009 (Sat)   #3
Harvey_G
Harvey_G's Avatar
The last is a quartering inbound flight sequence of 5 shots.
-Harv-
Old 10th of October 2009 (Sat)   #4
edgar-Junior
edgar-Junior's Avatar
This shot's damaging my mind !!!!! I want one
As always harvey nice detail,colors and exposure
In compare with the mark III did you like the AF system on 7D?
Powered by Canon®
edgar-Junior is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #5
kenn3d
kenn3d's Avatar
Geez Harvey,
I'm totally unqualified to judge BIF shots or camera/lens combos in this league, but I just gotta say....
DAYUMMMM!
The focus, DOF, and exposure on all these shots looks fabulous to me. I see you're shooting in manual mode so this is obviously your fault at least in part.
Sure seems to me you've got that new machine under control my friend. Now go find us an Osprey or somethin'.
Kenn
Kenn & Temple
Backyard Birders in St.Louis, MO
Canon S3-IS w/Sony DH1758 1.7x TC ; S5-IS ; SX-30; SX40; Fuji S100fs
2013 Gallery
Blog: Backyard Birding with Kenn & Temple
kenn3d is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #6
Duane N
Duane N's Avatar
I like what I see...the time you adjusted it really payed off.
www.3rdicreations.com
Duane N is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #7
artyman
artyman's Avatar
Looking good, there was some guy over on DP that returned his 7D as he was unhappy with it's one shot AF capabilities for urban shooting!!!!!
Art that takes you there. http://www.artyman.co.uk
Ken
artyman is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #8
Stormin_24
Stormin_24's Avatar
WOW, Wonderful captures Harvey... Whatever you've done has worked very well..
New Hampshire State Bird: Purple Finch
http://www.netstate.com/states/symb/...rple_finch.htm
Gear
Norman
Did they get you to trade, your hero's for ghosts?
Stormin_24 is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #9
joove
Very nice!
You are phenomenal at tracking those birds. Handheld ? I am getting more practice these days, hopefully one day I'll be able to track somewhat better, leave alone like you. I would appreciate any tips though!
Also, how did you micro adjust the AF ? If you can, I would appreciate the process you used. A general outline would suffice.
I find that if I use Spot AF while I am micro adjusting, the numbers don't work well for non-Spot AF. So I redid my adjustments using regular single pt AF. What AF pattern did you use for your micro adjust ?
Vamsi
Gear list
joove is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #10
monty28428
monty28428's Avatar
Nice shots as always Harvey...
Although judging from your 7D/500 post - those looked fine as well and I take it you had not microadjusted that lens at the time.
I have not found the need to adjust my lenses but out of curiousity what method/distance did you choose to use to do the adjustments?
monty28428 is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #11
jgrussell
Looking around nervously
jgrussell's Avatar
Here's another one asking for the microadjustment info -- I am DEFINITELY going to have to adjust for the 100-400. The 70-200 and 17-55 are fine, the 100-400 is not on the 7D.
-- jgr
blog | gear | my birds
jgrussell is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #12
Marcy
Marcy's Avatar
did the TC work with or without taping the 3 pins?
Marcy is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #13
canonloader
canonloader's Avatar
They all look alike. What I took away from this series is, the bird in the last five shots has a peg leg and is named Pete.
Mitch- ____...^.^...____
My Microscope Stuff
Gear List, My Flash Gallery, My You Tube, Ride My Bi-Sickle
canonloader is offline   Reply With Quote
Old 10th of October 2009 (Sat)   #14
joove
He says he is using the 1.4x on a 300/2.8. That would make the effective wide open f4 which is below the 5.6 limit of the 7D. There should be no need to tape the pins unless the effective max F # is 8.
Vamsi
Gear list
Old 10th of October 2009 (Sat)   #15
DaMoose
Awesome pics, can't wait to get my 7D!
DaMoose is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Post your flight shots...1000th post! (Yes, my turn!) dancad Birds 93 22nd of March 2013 (Fri) 19:48
Habitat Shots (Large Post 7 Images) hTr Birds 22 15th of August 2008 (Fri) 09:34
First Post - Large Sea Bird in Flight wrxflame Birds 5 6th of February 2008 (Wed) 11:17
Few bird and lion shots (large post) c75mitch Wildlife 3 29th of August 2005 (Mon) 09:48
