#1 |
anybody here use ebay triggers with a canon 5D? i used the CTR-301P with mine and i find that i can only get 1/160 without a black bar at the bottom. with my old xsi i used to get 1/200 without the black bar. i'm wondering if its just me or if its the norm. thanks
Canon 5D III | 17-40L | 24-70L | 70-200L II | 50L | 85L II San Francisco Bay Area Real Estate Photographer - Sammy Lo Photography |
| sponsored links |
#3 |
i'm thinking the same. with a flash on the body i can get faster than 1/160. but on the trigger thats all i can get. i find that i can't quite kill the ambient light with that speed. even at 1/200 i still pick up some ambient.
| sponsored links |
#4 |
Light Bringer
I think Canon publishes the EOS DSLRs can sync at 1/125th with anything other than a speedlite. The shutter speed only matters for controlling ambient light, if flash is your main light it's not really an issue.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
#5 |
"Got a thick monopod?"
1/200 gives me a small black bar.
#7 |
ctr-301p. i had no problems when i had a xsi, but on the 5d its slower...bummer...
#8 |
have you tried using the sync adapter on the side of the 5d to see if you get better results?
Flickr |Gear|The-Digital-Picture|The $6 mic for 5dmkii | MAGIC LANTERN | Tundra underwater kinetic cases are great, affordable alternatives to pelican cases. Go Support Magic Lantern 2.3!! |
#9 |
I am using one of the variations of the "eBay triggers" - RD-604, to be exact. I can sync at 1/200 with no issues at all. Here's the trigger set: http://item.taobao.com/auction/item_...jhtml?cm_cat=0
#10 |
1/100, ISO100...stop down your aperture more if there's ambient and you dinnae want it
#11 |
1/160 with the yongnuo RF-602s. I can live with it.
http://www.chromewaves.net |
#12 |
The 5D shutter curtain velocity is just barely able to eak out a 1/200 sync speed. It doesn't have any "sync headroom"--that is, it isn't a bit faster than marked as the other cameras are. If anything introduces any sync lag at all, you will lose a bit of flash coverage on the image at 1/200. If it doesn't look like you're losing any, you're probably not shooting a subject that shows it.
That's probably why the manual advises using 1/125 with anything other than a hotshoe-mounted flash. That's slow enough to be safe for practically anything. |
#13 |
1/160 fine here, 1/200 has a tad of black banding.
(CTR-301P firing YN460) |
#14 |
The X Sync speed published for a camera is the fastest speed when both curtains are clear of the sensor. This assumes the flash is triggered by the electrical connection at the sync connection.
The remotes convert the electrical signal to a radio fequency signal which then has to be received and converted back to an electrical signal to fire the flash. This signal conversion takes time. Some devices are faster than others. I recall that PCB says the Cyber sync is about 1/4000 second. Others may be faster or slower. I find that I can use 1/200 with my Cyber syncs but have to use 1/160 when using Pocket Wizards at a friend's studio. The Quantum triggers another friend has also require 1/160 or less. My guess is that the eBay trigger, generally, will have greater processing delay than others since speed and cost probably have a correlary. |
#15 |
I am using the Cactus triggers and the best I can get is 1/125!! Bit of a bummer when you are shootin crazy toddlers who wont stay still!! Ok for everything else though!!!
--------------------- Canon 5D MKII + grip | Canon 5D MKI + grip | Canon 20D | Canon 17-40mm f4L | Canon 70-200mm f4L IS | Canon 50mm f/1.4 | Canon 580EX Speedlite | Canon Remote Switch | Manfrotto 055PROB Tripod & Head |
| Thread Tools | |
| Display Modes | |
| Sync Speed of AB800 with Ebay (Phottix Tetra) trigger | ZGMF-X20A | Small Flash and Studio Lighting | 5 | 16th of April 2009 (Thu) 19:19 |
| Rear curtain sync + ebay triggers | talbot_sunbeam | Small Flash and Studio Lighting | 4 | 28th of March 2009 (Sat) 13:56 |
| High speed sync, max sync speed, and outdoor fill questions. | Nielsen277 | Small Flash and Studio Lighting | 21 | 15th of February 2009 (Sun) 17:45 |
| canon 40d and the cheap ebay triggers.. | benny g | Small Flash and Studio Lighting | 11 | 5th of September 2008 (Fri) 23:24 |
| Ebay Triggers and Canon units | Nuttcraker | Small Flash and Studio Lighting | 3 | 2nd of May 2007 (Wed) 18:53 |
