Thread started 15 Oct 2009 (Thursday) 09:29
Prev/next
Best Lens for Full Body Portraits or Fashion?
Slitherbeth
Slitherbeth's Avatar
St Marys, Kansas
Oct 15, 2009 09:29 |  #1
I have been doing portraits with my 85mm 1.8 on a 50D, but I would like a lens that is better for full body poses. The catch is that my budget it around $500...any suggestions?
Thanks! :D
xdmg
Joined Sep 2009
Austin, Texas
Oct 15, 2009 09:31 |  #2
Try to get a nice copy (no focus issues) of the Sigma 30 f/1.4... around $350-400$ used
or maybe a Tamron 17-50 f/2.8
http://rohofoto.comexternal link | facebookexternal link
Wilt
Wilt's Avatar
Belmont, CA
Oct 15, 2009 10:17 |  #3
What format...135/FF or APS-C? What distance to the subject? Set shots? runway?
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
tkbslc
Utah, USA
Oct 15, 2009 10:25 |  #4
I am assuming you don't have room to back way up with your 85?
Anyway, I agree on the Sigma 30 1.4 or also look at the Canon 28 1.8. (assuming aps-c camera)
If you are in the studio with strobes and don't have to worry about blurring the BG to death, any decent wider zoom will do.
Taylor
Galleries: Flickrexternal link
60D | ELPH 330 | iPhone 5s
JelleVerherstraeten
JelleVerherstraeten's Avatar
Antwerp, Belgium
Oct 15, 2009 13:23 |  #5
Sigma is very good for it's money!
-Jelle l Gear l Website (external link) l
toxic
California
Oct 15, 2009 14:36 |  #6
There is no "best" lens for any sort of portraiture. It depends on how far away you are and what look you want.
amfoto1
San Jose, California
Oct 15, 2009 16:08 |  #7
I'm also assuming this is for use with one of the crop sensor cameras... (Rebel, 40/50D, etc.)
Canon 28/1.8, Sigma 30/1.4... However, both can impart some wide angle distortion if not careful. Keep people away from the edges of the frame and don't get in too close with them (makes for oversized noses and undersized ears!).
If you have adequate room to work get a 50/1.4, either the Canon or the Sigma. This focal length will render very natural perspective and little distortion. I saw comparative examples from each of these on some website the other day after a Google search... I have been using the Canon for years and had heard a lot about the Sigma, thought I might want to try it. Frankly, after seeing the sample images, I think I'll just stick with the less expensive Canon. I didn't see enough difference in head to head comparisons to make it worth the extra. The Sigma is better built, but the Canon isn't bad.
Alan Myers "Walk softly and carry a big lens."
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - EXPOSUREMANAGER (external link)
cdifoto
Don't get pissy with me
cdifoto's Avatar
Oct 15, 2009 16:11 |  #8
I do most of mine around 50mm, but I've used 24mm and 135mm as well just about every focal length my lenses cover. "Best" is subjective and therefore has no single, definitive answer.
Did you lose Digital Photo Professional (DPP)? Get it hereexternal link. Cursing at your worse-than-a-map reflector? Check out this vid!external link
Slitherbeth
St Marys, Kansas
Oct 16, 2009 08:44 |  #9
Thanks so much everyone, I think I'll go with the 28 1/8 :)
SkipD
SkipD's Avatar
Joined Dec 2002
Southeastern WI, USA
Oct 16, 2009 09:37 |  #10
Slitherbeth wrote in post #8833420external link
WAIT. Don't be in a rush to buy glass if you don't know how it will work out for you.
I suspect you may find yourself getting a bit too close to the subject (for a proper perspective) with that focal length on an APS-C format camera.
Do you have any answers to the various questions above about intended camera-to-subject distances, etc?
Do you have a zoom lens that would cover the 28 through 50 or 60mm range? If so, test your ideas with that before buying another lens. Pay attention to the perspective in the test images. You may very well find that you need to change your distance and thus the focal length. After choosing the proper distance to get the desired perspective, THEN you should be choosing a focal length to get the desired framing.
Skip Douglas
SkipD
SkipD's Avatar
Joined Dec 2002
Oct 16, 2009 09:39 |  #11
amfoto1 wrote in post #8829173external link
Focal lengths, in themselves, do not create perspective distortion. It's the camera-to-subject distance, and nothing else, that causes that. Please read our "sticky" tutorial titled Perspective Control in Images - Focal Length or Distance?.
Skip Douglas
Wilt
Wilt's Avatar
Belmont, CA
Oct 16, 2009 10:04 |  #12
There never was a reply about format, only presumptions about APS-C. So let me answer in that context and hope the OP has that camera format...
85mm is too long on APS-C for head and shoulders, forcing one to be positioned farther back than optimal to permit easy and quick adjustment to poses and lighitng...back and forth and back and forth.
Conversely, 28mm is a bit wide for full length, although it can work without problem. A 'normal' FL is usual for full length work, at 10' shooting distance it sees 7' x 4.7''
I would not worry about induced perspective distortion with 28mm, as I have found that one can work without much fear of that with a lens as wide as 74 degree angle of view (18mm on APS-C)
Slitherbeth
St Marys, Kansas
Oct 16, 2009 11:53 |  #13
well I have a crop body, so wouldn't 28mm be about "normal" . and I'd probably be about 10 feet away
SkipD
SkipD's Avatar
Joined Dec 2002
Oct 16, 2009 12:01 |  #14
Slitherbeth wrote in post #8834575external link
Yes, a 28mm lens is approximately a "normal" lens on that format camera. However, it may not be appropriate for framing the portraits that you intend to make at the distance you choose to use.
The 10-foot camera-to-subject distance would probably be OK. Make sure you have at least six feet between the subject(s) and the backdrop if you're using a typical studio backdrop.
What lens(es) do you currently have that you could experiment with? If you could set a "kit" lens to 28mm, for example, you could confirm whether or not that focal length would work well for your intended setup.
Skip Douglas
Slitherbeth
St Marys, Kansas
Oct 16, 2009 12:45 |  #15
I only have he 85 1.8, so its kind of hard to tell with that
11,001 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00667 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is wshooter
445 guests, 354 members online
