Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 18th of October 2009 (Sun)   #1
js09
Default discharging capacitor on 580EX flash
i've got a broken 580EX flash and wan't to open it up and see what may be wrong. any ideas on how to discharge the capacitor?
or any repair tips
thanks!
js09 is offline   Reply With Quote
Old 18th of October 2009 (Sun)   #2
equetefue
equetefue's Avatar
Default Re: discharging capacitor on 580EX flash
send it to Canon and be safe
http://www.Photo-Galleria.com
Powered By Canon
1D Mark III l 5D with Grip l 50mm f1.8 l 17-40mm f4 L l 135mm f2 Ll 70-200mm f2.8 L IS l 400mm f5.6 L l EF 1.4x II l 580EX II l Feisol CF tripod l Wimberly Head II with F9 Bracket l Better Beamer
equetefue is offline   Reply With Quote
Old 18th of October 2009 (Sun)   #3
js09
I want too, but im afraid of what they will charge. Why not do it myself and save $50? or $100?
Old 18th of October 2009 (Sun)   #4
equetefue
equetefue's Avatar
My life is not worth 50/100 dollars, besides you might get lucky and they'll fix under warranty.
Powered By Canon
Old 18th of October 2009 (Sun)   #5
Mark_Cohran
Moderator
Mark_Cohran's Avatar
Unless you know exactly what you're doing, how to recognize the capacitor connections, and have the proper tools to safely discharge the capacitor, you risk further damaging the flash as well as injuring yourself.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 18th of October 2009 (Sun)   #6
Lonnie
Lonnie's Avatar
You will not be able to fix the flash by asking in a forum thread. Plus, you are not a trained electronics technician - you don't know how to discharge a capacitor. Do you have a multimeter? Do you have soldering equipment and know how to solder?
It would be cheaper and less frustrating if you just sent the flash to Canon. I've heard some really good stories about people's experience with Canon service - give it a shot - it might be cheaper than you think.
My non-photography related blog
My Flickr
I use a crop sensor Canon dSLR, 4 primes and 3 cheap flashes.
Lonnie is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #7
jeremyvi
Hi,
Use a 1 megaohm resistor, if you have enough knowledge in electronics, you might know how select it.
Be warned that the high voltage inside is a risky business. If unsure, you can use latex gloves, but it will not helps you if you don't know what you are doing.
Btw, anyone knows what is the capacity of the capacitor in a 580 EX ? 1100µF ?
KR, and safety first !!
Jeremy.
jeremyvi is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #8
SkipD
SkipD's Avatar
Ordinary latex gloves would NOT be a suitable insulation for 1000 volts or more. Forget that suggestion.
If you don't have the proper training and tools, forget working on the flash unit. Send it in for repair.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #9
RichSoansPhotos
RichSoansPhotos's Avatar
+1 the 580 EXII is darn expensive
Bodies: Canon 50D, Canon 5DMKII
Lenses: Canon 50mm 1.8, Canon 85mm 1.8 USM,
Canon 16-35mm 2.8L USM II Canon 24-70mm 2.8L USM, Canon 70-200mm 2.8L IS USM II
Compact: Canon G12
RichSoansPhotos is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #10
Wilt
Wilt's Avatar
Even a trained technician would likely NOT be able to repair a flash unit without access to FACTORY parts, simply because the value component which has failed is likely to be a particular size and shape to fit into a very restricted space. Decades ago, since I know what I am doing, I attempted to repair a Honeywell electronic flash. I opened it up and determined the failed component, a capacitor. Seems simple enough, right?! Wrong. My uncle, who was a pro repairman of TVs and stereos and other electronic items, could NOT find a suitable replacement part even in all his catalogs.
Send it to Canon!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #11
440roadrunner
User is banned from forums
Boy there's some GREAT info in this thread----using 1meg resistors to discharge 1000V caps while working on 'em with latex gloves.
440roadrunner is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #12
number six
"After 40 years still not housebroken, I still piddle on the carpet"
number six's Avatar
Yeah, latex gloves are much too thin to be trusted. The 1 meg resistor would work (power dissipation would be 1 watt for 1000 volts) but it'd take a while.
I'd just short the pins. But then I like bright flashes and loud noises.
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
I do not piddle on the carpet!
number six is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #13
jeremyvi
Is the capacitor inside a 580 EX a is 1000V, or a 300 Volts ?
For exemple into a Vivi 285hv, the capa is 300 V and 1100uF
I do not wear gloves while disassembling electronic card, neither when I am servicing a 2 MWatts converter, simply because I have done some checkings first...
Old 31st of January 2010 (Sun)   #14
essvee
I can give you step by step instructions on how to do this. But you'll need to put me in your will first.
(I'm kidding!)
essvee is offline   Reply With Quote
Old 31st of January 2010 (Sun)   #15
itzcryptic
I've taken apart a few disposable cameras and IIRC, the capacitors charged to 120v. If you short out that connection with a screw driver, it can actually melt the solder to the screwdriver. It can give you quite a shock as well.
itzcryptic is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
580ex, 580ex ii, Nikon SB-80dx (optical flash) shh777 Small Flash and Studio Lighting 4 22nd of June 2009 (Mon) 01:34
Flash capacitor replacement/repair cost? dFreezy Small Flash and Studio Lighting 11 4th of August 2008 (Mon) 16:29
Flash discharging - am I wasting my time? philthejuggler Small Flash and Studio Lighting 2 9th of December 2007 (Sun) 23:14
D60 Battery Discharging.... tony4563 Accessories & Storage 2 1st of August 2003 (Fri) 16:00
Discharging Batteries Marley Small Compact Digitals by Canon 4 2nd of February 2003 (Sun) 19:44
