Reply
Thread Tools Display Modes
Old 6th of April 2001 (Fri)   #1
dbterrana
Default File Numbering System
My camera seems to have lost its ability to assign folders in its numbering system.
With the camera set "FILE NO. Reset Off ",
the file numbers look as below:
Img_0123.jpg , with the next image numbered sequencially, with no folder number.
They used to look like this:
101-0123_IMG.JPG.
There were three folders 100, 101, and 102, before this problem started.
How did this happen?
Any suggestions?
Thanks , Don Terrana
dbterrana is offline   Reply With Quote
Old 8th of April 2001 (Sun)   #2
dbterrana
Default Re: File Numbering System
Since no one has replied to my post I am not sure anyone will bother read my own reply.
But if anyone did and has any interest in this , the problem stems from not realizing that only by first importing the camera image directly into the Zoombrowser database does the file name acquire the
folder prefix, i.e. xxx-xxxx_img.jpg.
If you load the image from the card reader into any other folder in the file system it will have the
IMGxxxx.jpg format.
PS,
While this is a fine forum , there doesn't appear to be nearly as much activity as in the other DP forum.
Perhaps when more people find out about its existance the interest will pickup.
Sincerely,
Don Terrana
Old 8th of April 2001 (Sun)   #3
John - NJ
Default Re: Re: File Numbering System
Thank for posting. I was interested in knowing what the problem was. Unfortunately, I didn't know the answer to your question. That's why I didn't post. I'm sure others felt the same way.
I really hope this forum doesn't get as busy as the "other" forum. I can't keep up that kind of pace.
PS,
John - NJ is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
File Numbering Technographer Canon EOS Digital Cameras 1 15th of February 2007 (Thu) 13:33
5D file numbering Canongirl Canon EOS Digital Cameras 15 21st of June 2006 (Wed) 08:42
Digital Rebel XT Numbering System kennyahn Canon EOS Digital Cameras 10 20th of July 2005 (Wed) 08:11
File Numbering? pmed Canon G-series Digital Cameras 1 19th of May 2003 (Mon) 09:01
File numbering estivie Canon EOS Digital Cameras 2 17th of May 2003 (Sat) 16:03
