FORUMS Canon Cameras, Lenses & Accessories Small Compact Digitals by Canon
Thread started 22 Oct 2009 (Thursday) 14:06
Prev/next
S90 adapter for filters and close-up lenses
aostling
Phoenix, Arizona
Oct 22, 2009 14:06 |  #1
It would be easier if the S90 incorporated a mount for an accessory tube, like the LX3 does. But if you have access to a lathe you can machine a simple adapter, as shown below, which slips over the S90 innermost lens barrel. I used the adapter tube from my LX3, which has 46mm filter threads.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/assembledview.jpg
The insert in the LX3 tube is Delrin (acetyl), a very easily-machined plastic. It does not scratch the lens barrel when it is slid on or off. Here is a polarizing filter attached, probably the only filter you will want to mount. The tube does not cause any vignetting, even at 28mm.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/explodedview.jpg
Because Delrin has such a high C.T.E. temperature changes cause the Delrin insert to expand or contract at ten times the rate of the aluminum adapter tube. A hand-sawn slit takes up this slack and makes the device usable over a range of temperatures. I've tested it at 40ºF (in my refrigerator) and 80ºF (the current temperature here in Phoenix), and at both extremes the fit is not too tight or too loose.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/insertdetail.jpg
It's also possible to mount high-quality close-up lenses, such as those from Raynox. Here is a full-frame 28mm f2 shot without a close-up lens. As you know, the close-up range is restricted to the wide end, near 28mm, and the working distance is between one and two inches.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/macromode.jpg
Here is a full-frame 105mm f4.9 shot with a 5.0 diopter doublet close-up lens. The working distance increases to four inches or more, depending on the magnification desired.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/close-uplens.jpg
-AP-
-AP-'s Avatar
Arizona
Oct 23, 2009 08:02 |  #2
Excellent, Excellent, Excellent post. I now may get this camera. The only thing holding me back was that I have 2 s80 cameras and was not willing to give up the lens adaptor.
Thanks..
WEBSITEexternal link | FACEBOOKexternal link | Canon 5d3 | SX50 HS | T3I |70-200L | 24-70L | 50mm f1.4 | YN-622c | Bunch of lights and other stuff..
WatchFan1
WatchFan1's Avatar
Tampa Bay, FL
Oct 24, 2009 01:36 |  #3
doesn't it kinda' beat the whole nice pocket-ability of this camera ?
* * * * 'Someday' I hope to get better at photographing watches.external link* * * *
Gear: Canon S100, Nikon D800
& a buncha' big black lenses....
http://...
http://...
http://...
strictfunctor
Oct 24, 2009 06:10 |  #4
Or just buy a G11 instead.
-AP-
-AP-'s Avatar
Arizona
Oct 24, 2009 06:35 |  #5
Not even a little for me... The adaptor would accommodate an IPIX fisheye lens for QTVR..
aostling
Phoenix, Arizona
Oct 24, 2009 08:22 |  #6
WatchFan1 wrote in post #8884295external link
It does when attached. But I intend to keep the tube stowed in a bag, to be brought out only on occasion.
aostling
Phoenix, Arizona
Oct 25, 2009 16:14 |  #7
-AP- wrote in post #8878708 (external link)
Thanks, it's nice to hear from a fellow enthusiast who sees possibilities rather than limitations.
You can take high-magnification macro shots with the S90 without going to the trouble of machining an adapter tube. Here is a set-up which uses the close-up lenses which were made for the Kodak Retina cameras. These close-up lenses came in two series: the "N" series, which are simple one-element lenses, and the really fine "R" series, which are achromatic doublet lenses. As far as I know these are the smallest doublet close-up lenses ever made for 35mm cameras.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/Rkit.jpg
There are three lenses in this kit, designated as "1:4.5", "1:3", and "1:2", which are the magnifications produced when used on the Retina. These have powers of 4.44, 6.66, and 10.00 diopters.
The outer diameter of the the "R" lenses is 1.255", which is precisely the O.D. of the outer lens barrel on the S90 (measured with my digital caliper to the nearest thousandth). It's almost as if they were intended to be used on this camera, sixty years after the lenses were manufactured. You can attach the lens with a rubber band. The rubber bands used to hold stalks of broccoli together are the perfect fit. This food-grade rubber is of the highest quality, and resists UV degradation better than anything you can buy. You can buy some broccoli, or ask the grocer for a rubber band like I did.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/bandlens.jpg
You can stack two of the "R" lenses, to get increased magnification. I would not usually do this, but did it here merely to show one of the two stacked lenses protruding beyond the rubber band.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/rubbermacro.jpg
Here is a shot taken with the 10.0 diopter lens at f=105mm, which allows a comfortable working distance. With these "R" achromats the image quality holds up very well right out to the edge.
IMAGE: http://i168.photobucket.com/albums/u183/aostling/butterflystamp.jpg
Dick ­ Emery
Dick Emery's Avatar
Oct 29, 2009 06:52 |  #8
Do you think it there is a cpl that would fit?
Canon 450D/XSi (Retired), Canon 70D, Canon 18-135mm F3.5-5.6 STM, Canon 18-55mm f/3.5-5.6 EF-S IS, Canon 55-250mm f/4.0-5.6 EF-S IS, Canon 80-200mm f/4.5-5.6 EF II, Sigma 30mm F1.4, 430EX Mk I, Canon Powershot S2 IS, Canon Powershot S90 IS, Sigma 1.6x closeup lens.
My Flickrexternal link
www.maunders.comexternal link
aostling
Phoenix, Arizona
Oct 29, 2009 11:03 |  #9
Dick Emery wrote in post #8916691external link
Sorry, cannot make any sense out of your question.
sneakerpimp
sneakerpimp's Avatar
The O.C.
Oct 29, 2009 12:28 |  #10
aostling wrote in post #8917903external link
cpl = circular polariser
Canon EOS M | G7 X | S90
Jon
Jon's Avatar
Joined Jun 2004
Bethesda, MD USA
Oct 29, 2009 12:46 |  #11
Yes, but a CPL to fit the adapter the OP talked about, or a CPL that would function like the Kodak Retina slip-on close-up lenses?
By the way, for the PowerShot line you don't need a circular polarizer. Those are a requirement for EOS cameras and other DSLRs due to the partially-reflective mirror ("beam splitter") used in AF, which is basically another polarizing filter; polarized light is passed thorough and reflected to the AF sensors while unpolarized light is reflected up to the focusing screen. If you've already polarized the light coming into the camera and the beam splitter is polarizing at right angles to the incoming light's direction, the AF sensor won't get any light to work with. A Circular Polarizer essentially "depolarizes" the good light after the "bad" (glare) light has been filtered out so the beam splitter gets usable light no matter what. Since PowerShot cameras don't have a beam splitter, but rely on detecting contrast changes on the main CCD sensor, you don't have that problem.
Jon
Cocker Spaniels
Markpotn
Joined Sep 2009
Michigan
Oct 29, 2009 13:22 |  #12
That is so cool, I may just buy those lenses in anticipation of one day buying an S90. Thanks to you and the OP for excellent posts.
aostling wrote in post #8892175external link
...Here is a set-up which uses the close-up lenses which were made for the Kodak Retina cameras.
aostling
Phoenix, Arizona
Oct 29, 2009 14:41 |  #13
Jon wrote in post #8918546external link
Jon,
This is valuable information. The OP photo shows a circular polarizer mounted via a 46-49mm step-up ring. I thought about getting a dedicated 46mm polarizer, but I found that a Hoya HMC Circular Polarizer in this size costs about $85. But linear polarizers are available for much less. I'm happy to know that these will work on the S90.
aostling
Phoenix, Arizona
Oct 29, 2009 14:48 |  #14
Markpotn wrote in post #8918794 (external link)
When you get a set of those "R" close-up lenses you need not be shy about stacking them to increase magnification. I happen to have two of the 1:2 size (10 diopters), and combined them to make an equivalent 20-diopter close-up lens.
Here is a photo taken with the camera lens only:
IMAGE: http://i168.photobucket.com/albums/u183/aostling/fullstamp.jpg
And here is a photo taken with the two "R" lenses, held in place with the broccoli rubber band, at f=105mm, f8:
IMAGE: http://i168.photobucket.com/albums/u183/aostling/PNGcorner.jpg
aostling
Phoenix, Arizona
Oct 29, 2009 17:35 |  #15
Okay, now I understand you want to fit a polarizing filter. Thanks to Jon we know it need not be a circular polarizer.
I've been thinking what polarizing filter might be fitted with the broccoli blue rubber band. That is so much simpler than having to use a custom-turned adapter, I may leave the adapter behind if I can find a polarizer which is the same diameter as the 32mm Retina filters and close-up lenses.
A "pola" filter was made for the Retina, but I've not found any source for this. According to the Retina Manual by E.S. Bomback it also included a hood.
A possibility might be to use the Series V filter adapter rings. The pair of rings traps the filter (which has no threads). The OD of the Series V adapter ring is 33.5mm, which should not be too much of a mismatch for the rubber band set-up. I don't know if a polarizer comes in a flat sheet which could be trimmed to fit into the adapter.
74,513 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00312 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is bashmct
916 guests, 299 members online
