| sponsored links |
Thread Tools | Display Modes |
#1 |
So I think I'm making this a much bigger deal than it needs to be, but still!
I need to find a folder structure that I can use across Lightroom, Picasa and Windows Explorer! I currently put my pictures in: <path to>\Pictures\Dated\yy.mm.dd - Event name This works fine, but it doesn't work when I take "random" photos... like of my dogs or "one off shots" of something I might see that is interesting. Also not sure how to handle multi-day events (like a weekend) I am NOT a professional photo who goes out on paid projects or anything. It's all personal photos and such. I would appreciate someone helping me out and helping me figure out a folder structure that will work once and for all! Thanks! |
| sponsored links |
#2 |
The structure that I have for my personal shots is year and then a subfolder for each month of the year. I always assign keywords before I do anything else so if I want to find those photos of my cat the keywords work fine to facilitate this. Everything that I shoot just gets put into the one folder for the month. I don't use Picasa or Windows Explorer to find images but I see no reason that a structure such as this would not work for them. This limits the number of folders you are going to end up with at the end of a year.
My life is like one big RAW file....way too much post processing needed. Sheldon Simpson | My Gallery | My Gear updated:26Aug09 |
#3 |
I use a similar idea to Sheldon: YYYY/MM keyworded, but then within the MM I may put a subfolder for a special event with lots of photos i.e. a wedding, in case I want to find it in other software (i.e. Bridge, Finder/Explorer), and everything else is just within the MM folder. I'd take Picasa out of the equation personally.
Victoria Lightroom Queen website Lightroom Book available now! Free List of Lightroom Shortcuts |
| sponsored links |
#4 |
"I'm the original idiot"
I'd stick with a file named "Rover" and put all of Rovers pictures into it, I'd not complicate things with dates unless really needed.
Typical files from my own system: Venice 2008, Sailing, Valencia F1, Donington 2008 etc, etc. I can remember where a certain image is and can go straight to it using the simple structure above. The individual images keep the RAW file name Canon gave them and I search the file using thumbnails. Unless you are shooting professionally, and need to find say Mr and Mrs J Bloggs wedding from 8 years ago for a lucrative reprint order ASAP, why complicate life? |
#5 |
But what if Rover and Freddie are both in the same photo - would you put it in Rover's folder or Freddie's?
#6 | |
If you had enough goggie images you could create a collection set - 'Dogs' and have collections for Rover and Freddie. The images with both of them could live in both collections - but you still only have one copy of the image somewhere on your hard drive (and if you need to find it you just right-click on the image in a collection). Once people get used to Win7 and its Libraries I think we might start moving away from this obsession about where files actually live in our storage. |
#7 |
For me I put Month with Year/Event/pictures.cs2
|Canon 40D | 430EX | Kenko Ext Tubes| 1.4x MKII TC | | 50mm f/1.8 | 70-200mm f/4L | 24-105mm F/4L IS | 100mm F/2.8 Macro | Sigma 10-20mm |
#8 |
Simple -both. |
#9 | |
See that'd confuse me - if I edited one, I'd then have to go back and find all of the others to do them too.
#10 |
Victoria,
Thats easy too. I've got a file labeled Family. And they only get filed once I've post processed. If I need to reprocess I go back to the RAW files. |
#11 |
on my file system i use create 1 directory per year then each month i may have 1 or 2 sub sirectories depending on the type of photos i take, e.g. under 2009, for October, i have 2 sub direcotries 10-Sanibel and 10-Bahamas (and in 10-Sanibel is all the photos from 4 separate visits)
e.g. ~/Pictures/Photos2009/10-Sanibel and Photos2009/10-Bahamas Inside Lightroom i don't tag with the month, more just the location and other info, and sometimes then create collections also. i find having it split out by year makes it easy to backup. I take probably 10-12k photos per year, so this is manageable. If you take a lot less you may want to ignore the year directory and add the year to the sub-sir like ~/Pictures/2009-10 Dir1 and 2009-10 Dir2 or if you have Family or Pets where you take just a few photos (but take them throughout the year) you could drop the "month" idea and for those just create a folder you drop in those photos for the whole year or put the in the folder for the month but tag them with a key word or add to a LR collection. From LR you can then export your best to an export folder you can create per collection to upload in Picassa |
#12 |
No need, because you can filter by date.
#13 |
Year_month_date_CoupleOfKeyWords all under one folder. Pretty easy to find anything, but I also have a pretty good memory with things like this.
I tried the cataloging thing, but I wasn't consistent enough with adding everything to it. The backlog became insurmountable, so I dropped it. I'm looking at giving that another shot once the weather turns crappy here. |
#14 | |
40D / 10-22 / Sigma 17-70 / 28-135 IS / Sigma 50-150 f2.8 II / 100-400L / Vivitar 2X / 580EX II / 22-55 USM / 28-105 f3.5-4.5 II/ 50 f1.8 II Gear / ShutterStock / Eagle's Nest Photography / My Alamy |
#15 |
I guess it depends on how much you shoot, but for me this works great so far, to me it is easy to find pictures. At first I had a folder for each month inside every year, but then I would need to search several folders before I found the pictures:
Pictures/2009/2009 10 Dogs in the park --2007 --2008 --2009 ------2009 10 Dogs in the park If I shoot Dogs in the park more than one time pr month, I put it in the same folder, Unless it is something special, then I make a new folder with a new name like 2009 10 Dog in Hyde Park
40D (gripped) & 5D, EF 17-40, EF 24-70, EF 70-200 f2,8 IS
| Thread Tools | |
| Display Modes | |
| Lightroom - reorganizing folder structure | BluewookieJim | RAW, Post Processing and Printing | 13 | 18th of December 2009 (Fri) 14:51 |
| EOS 30D CF card Folder Structure | jim.r | Canon EOS Digital Cameras | 0 | 24th of February 2008 (Sun) 07:48 |
| Export Folder Structure from Lightroom?!?! | eslaydog | RAW, Post Processing and Printing | 2 | 15th of October 2007 (Mon) 15:37 |
| Photo folder structure | Rezarf | RAW, Post Processing and Printing | 10 | 6th of October 2006 (Fri) 05:23 |
| Can I change Rebel XT folder structure? | darkvibe | Canon EOS Digital Cameras | 6 | 6th of June 2006 (Tue) 13:46 |
