Thread started 08 Feb 2003 (Saturday) 12:25
Studio lighting advice for a amateur
Tom ­ Batinich
Joined Jan 2003
Feb 08, 2003 12:25 |  #1
I want to purchase a studio lighting system to use with my D60. I am looking at this system
http://www.bkaphoto.co​m …00K&cart_id=699​5140.30328 (external link)
I am a Amatuer , and I realize that I could get a cheaper "home" system to learn with but I read on this forum buy cheap and you will buy it twice.
So, my question is how does the type of system connect to the D60 ? I have a 550 EX and I understand how it can use other Canon flashes as a slave but this is a whole different animal.
I want the system for portraits.
Dans_D60
Joined Apr 2002
Feb 08, 2003 23:09 |  #2
The D60 is so flexible that just about any reasonable strobe setup will work fine. I found using small 110 WS strobes with larger size (45 inches) umbrellas can do the job just fine with very little investment. My favorite setup is three strobe units; two in front at angles that set the mode and shadow depth and one hair-light usually with a honeycomb filter. More importantly select the correct lens for quality and perspective. I found the 28-70 2.8 L and 70-200 2.8 L work best for portrait work (28-70 at the 65-70 end). I have examples on my web site that were done in my garage studio with several variations of studio lighting setups. Have fun!
Dan
http://www.pettusphoto​.com (external link)
Dan (external link)
Dan Pettus Photography (external link)
BLOG (external link)
FB (external link)
Tom ­ Batinich
Joined Jan 2003
Feb 09, 2003 10:46 |  #3
Thanks , for the info. BTW How does the D60 control the strobes ? Is a shoe attachment or thru the PC terminal ?
JR92
Joined Jul 2002
Feb 09, 2003 17:27 |  #4
I have a really good Britek set up I will sell for a great price. It comes with everything you need to get started without breaking the bank. I bought it all in September and used it three times. Does not lack a powerful punch when it comes to lighting your subject.
In interested e-mail me.
reynolds@sisqtel.net (external link)
Dans_D60
Joined Apr 2002
Feb 09, 2003 18:19 |  #5
Good question. The PC sync connector on the D60 is my preferred method because the cables are out my way. But, you must be careful with maximum trigger voltages. The D60 like most modern digital cameras can tolerate a maximum trigger voltage of approximately 6volts. It can work with higher voltages but will ‘stress’ the internal circuit design. I have tested all my strobe lights and actually sent one system (an older Novatron VR 400) back for modification. Another method is to use what is called “safe sync†adaptors on the hotshoe. Many manufactures make these so-called adaptors. And, there are many other methods from IR to wireless radio transceivers. But for me in the studio, the old PC sync connector is the easiest and by far the least expensive.
Dan
Dan (external link)
FB (external link)
lziering
Joined Nov 2002
Feb 09, 2003 19:20 |  #6
I've been using my D60 and 550ex with a Photek umbrella/softbox. The flash mounts on a light stand and is pointed into the umbrella with the light coming out of the umbrella diffused by a removable defuser cover. I control the flash with a Canon Wireless transmitter ST-E2. It is a nice set up but you need to be careful when using a D60 with a 550ex as the camera's meter tends to under expose.
Mark ­ Cullenane
Aug 09, 2009 21:28 as a reply to  @ lziering's post |  #7
If you can't run to studio lights, try this web site if you havn't already it's a great site for using single or multiple small flash units to achieve pro studio like results.
www.strobist.blogspot.​com (external link)
5DMk2, 50D & 40D all with Grips| Sigma 17-70mm f/2.8-4.5 | Canon 85mm f/1.2L | Canon 24-105mm f/4L IS |Canon 70-200mm f/2.8L IS | Canon 100-400mm f/4.5-5.6L | 2 x 580EXII | Pocket Wizards | Studio Lights & Elinchrom Location Lights and lots of other toys :D
Veemac
Aug 10, 2009 02:55 |  #8
Mark Cullenane wrote in post #8429849 (external link)
Ummm...you do realize this thread was last posted to over 6 1/2 years ago, right? ;)
Mac
-Stuff I Use-
MR ­ do ­ little
Aug 10, 2009 04:35 |  #9
LOL
Regards
Paul L.
Mark ­ Cullenane
Aug 10, 2009 17:54 as a reply to  @ MR do little's post |  #10
Oops, Ah well better late than never, I was just surfing a few threads at work in between work interupting me and didn't look at the date.
Naturalist
Adrift on a lonely vast sea
Gallery: 36 photos
Aug 10, 2009 17:58 |  #11
ROFL
Was stroboist around then?
Doug
My Gear List
http://www.douglasbrow​nsr.com (external link)
Entered: 2-16-84 Passed: 5-22-84 Raised: 6-19-84
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Aug 10, 2009 18:03 |  #12
Wow. This has to be the oldest thread resurrection I've seen yet :p How did you find it?
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
8,884 views & 0 likes for this thread
version 2.0 /
Latest registered member is apaulavicius
579 guests, 286 members online
