#1 |
I didn't know if this was posted anywhere else, so I apologize if it was; below is a comparison I made of the available focal lengths and maximum apertures of both the S90 and G11 compared.
-The left half of the chart is the S90, the right half is the G11. -The first column is the actual focal length. -The second column is the effective focal length based on the diagonal field of view (or a crop factor of 4.55x). -The third column is the 3:2 effective focal length based on the horizontal field of view (or a crop factor of 4.737x) which is what I find most useful. -The fourth column is the maximum available aperture at that focal length. I note that the S90 begins at a full stop faster at 28mm. At approximately 50mm both cameras equalize at f/3.2 and remain equal until about 70mm at which the G11 pulls ahead by 1/3rd stop and stays there until at the S90's full tele of 106mm where the G11 is about 2/3rds stop faster. Also note the S90 has 10 zoom 'steps' while the G11 has 14 'steps'. A tip, if you are using the S90 Ring as a Zoom selector, and you turn it to the 50mm position you will have a maximum aperture of f/3.2 but if you just touch the zoom out by one 'step' to 45mm you get a 1/3rd stop of aperture at f/2.8 but only loose about 5mm. Code:
---------------------------------------------------------------------- S90 FL EffFL 3:2FL S90Ap | G11 FL EffFL 3:2FL G11Ap ---------------------------------------------------------------------- 6.000 27.3 28.4 f/2.0 | 6.100 27.8 28.9 f/2.8 6.850 31.2 32.4 f/2.2 | 6.790 30.9 32.2 f/2.8 7.490 34.1 35.5 f/2.5 | 7.410 33.7 35.1 f/2.8 | 8.110 36.9 38.4 f/3.2 8.560 38.9 40.5 f/2.8 | | 8.900 40.5 42.2 f/3.2 9.640 43.9 45.7 f/2.8 | 9.780 44.5 46.3 f/3.2 10.701 48.7 50.7 f/3.2 | 10.775 49.0 51.0 f/3.2 | 12.074 54.9 57.2 f/3.5 12.845 58.4 60.8 f/3.5 | | 13.761 62.6 65.2 f/3.5 14.976 68.1 70.9 f/4.0 | | 15.673 71.3 74.2 f/3.5 18.189 82.8 86.2 f/4.5 | 18.098 82.3 85.7 f/4.0 | 21.461 97.6 101.7 f/4.0 22.500 102.4 106.6 f/4.9 | | 24.978 113.6 118.3 f/4.5 | 30.500 138.8 144.5 f/4.5 ----------------------------------------------------------------------
-AdamJ |
| sponsored links |
#2 |
Great info - thanks for the comparison.
#3 |
Excellent -- thanks!
Someone had posted a similar chart on DPR, but it's nice to have it here as well. |
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Focal Length Comparison | MG30D | Canon EF and EF-S Lenses | 19 | 25th of September 2009 (Fri) 02:03 |
| Focal Length Comparison Tool?? | jimmyfingers | Canon EF and EF-S Lenses | 9 | 17th of January 2009 (Sat) 23:29 |
| Focal Length Comparison | The Fox | Canon EF and EF-S Lenses | 1 | 17th of July 2008 (Thu) 03:30 |
| Interesting Focal Length Comparison | sumyungguy | Canon EF and EF-S Lenses | 3 | 5th of November 2007 (Mon) 23:54 |
| focal length comparison | palmerstoat | Canon EF and EF-S Lenses | 4 | 30th of September 2005 (Fri) 06:54 |
