Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 20th of November 2009 (Fri)   #1
mkville
mkville's Avatar
Default Focusing with more then one face in a picture
So here is a question, when I shoot a single person, I shoot in Manual AF mode with the pointer in the middle which locks in on the persons face, now I'm starting to shoot my two kids together, it was after about ten minutes I realized that one of the kids faces was out of focus, my question is do I shot in automatic mode for the AF points to detect both faces I've been playing around with the different settings but can't seem to get both of the faces to focus. obviously in Auto it works fine
Mark
5D II|Tammy 28-75|35 1.4L |85 1.8
Site Flick
mkville is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #2
gonzogolf
Default Re: Focusing with more then one face in a picture
Remember, not matter what setting it can only focus on one point regardless of the setting. You can manipulate that point a little, by focusing on something halfway between the two faces but if you dont have sufficient depth of field then that means two faces out of focus. In the case of two kids, just focus on one, and make sure your aperture is small enough (f/8 ) that you get some depth of field.
gonzogolf is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #3
Dennis_Hammer
The key is finding the balance in the depth of field for subject sharpness and background bokeh. Try bracketing for awhile and then when you edit you can look and see which aperture is giving you the desired effect.
Dennis_Hammer is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #4
snyderman
snyderman's Avatar
mkville:
look for the 'single light' post in the lighting section. Lots of multiple person shots with exif data and lighting diagrams. For your situation, the easy answer is being able to stop down to 6.3 or greater for 'acceptable ' DOF to focus faces that aren't exactly the same distance from your lens.
dave
Canon 5D2 > 35L-85L-135L
snyderman is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #5
mkville
mkville's Avatar
Thanks for all the info guys, I'll be trying some of these methods out this weekend
Mark
Site Flick
Old 20th of November 2009 (Fri)   #6
tester3000
The focus point does matter all that much. What you need to do is reduce the size of the aperture (by increasing the f-stop #). This will give you a greater DOF and will allow more of the image to be in focus. It all depends on what lens you are using, the sensor size, and the subject distance. But generally, around f/8 should get you close. If your 2 subjects are on the same plane (ie. same distance from the camera), you can decrease the f-stop (maybe f4 or 5.6). Just try different apertures and see what you get. It's pretty easy to catch on after you see the results.
Canon 60D | Canon 24-105 f/4L IS | Canon 50mm f/1.4 | Canon 55-250 f/4-5.6 IS | Canon 10-22mm f/3.5-4.5 | Canon Speedlite 430EX II
tester3000 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
You know, sometimes you spot a face in a crowd, and just have to grab a picture neil_r People 18 22nd of September 2009 (Tue) 18:33
Portrait session: web gallery vs face to face presentation workflow Canonymous The Business of Photography 18 21st of July 2009 (Tue) 04:55
bird with ghost cat face to face rwenglish1 Birds 7 28th of February 2007 (Wed) 16:37
Face-to-face with a Great-Blue Heron dancad Birds 37 12th of October 2006 (Thu) 00:26
Rhino: Face to Face (56k warning) Juan23 Wildlife 7 24th of February 2006 (Fri) 18:06
