Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 20th of November 2009 (Fri)   #1
beacherz
Default nite sports and ghosting
I recently shoot soccer under the lights using my new Manfrotto 322B to eliminate some of the red eye (but that's another post). Some of the shots exhibited ghosting and my understanding is that this is due to shooting too close to ambient? How many stops below do you need to be to guarantee no ghosting? I'm pretty sure I was hovering around -2 to -3. Should I just make sure I'm at least 3 to 4 stops below and stay within range of my 580EX?
Wayne
MaxPreps
beacherz is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #2
Patrick
Default Re: nite sports and ghosting
Without some means to measure the light it's just trial and error. It should only take a couple of shots to figure it out though. From my own experience; The lighting changes pretty dramatically on different parts of the field so you may need to change settings as you move about.
Bodies, Lenses, Lights, Stands, Transmitters, Receivers, Tripods, Meters, etc...
Patrick is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #3
beacherz
Thanks, that's true, the light does change from the 50 yard line to the end zone. I was thinking that I could use the exposure meter in the camera, keeping it pegged at the -2 mark.
Wayne
MaxPreps
Old 20th of November 2009 (Fri)   #4
bobbyz
Take a shot without flash. There should be barely anything visible. Now turn on the flash.
Back to basics 5dc with 35L & Sigma 85mm f1.4
bobbyz is offline   Reply With Quote
Old 20th of November 2009 (Fri)   #5
Patrick
There you go!
Old 20th of November 2009 (Fri)   #6
beacherz
That works! Thanks bobbyz.
Wayne
MaxPreps
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ghosting outoffocus2 Canon EOS Digital Cameras 5 28th of April 2008 (Mon) 15:08
What causes this ghosting? Ojum General Photography Talk 17 28th of August 2007 (Tue) 19:04
Ghosting? Joe Cyr Sports 7 16th of March 2006 (Thu) 07:42
Ghosting - what causes this ? Panza Canon EOS Digital Cameras 3 5th of September 2004 (Sun) 06:32
