Reply
Thread Tools Display Modes
Old 22nd of November 2009 (Sun)   #1
masayako
masayako's Avatar
Default Techniques on keeping lens dry during long exposure?
Hi there,
Anyone can provide some techniques on keeping lens dry during long exposure?
Last night I play with my 16-35mm and stayed outside for over 2 hrs to take long exposure star trails pictures. The front element of my lens start to collect dew since it's quite cold... how to prevent dew in cold weather? Any help is appreciated.
Thanks!
masayako is offline   Reply With Quote
Old 22nd of November 2009 (Sun)   #2
Courierman
Courierman's Avatar
Default Re: Techniques on keeping lens dry during long exposure?
leave the lens in a cold place before you go out side , so the lens is already cold so no dew
Courierman is online now   Reply With Quote
Old 22nd of November 2009 (Sun)   #3
wimg
wimg's Avatar
With dew it is the other way around. Dew condenses on cool objects, when the temperature gets below the dew point..
IOW, keep the camera warm -> no dew.
Kind regards, Wim
wimg is offline   Reply With Quote
Old 22nd of November 2009 (Sun)   #4
nardes
To prevent atmospheric moisture condensing on the objective lens of telescopes, most amateur astronomers use dew heater strips wrapped around the lens cell. These are low powered electrical heaters and you can also wrap them around the barrel of the lens just below the lens hood.
These keep the air temperature around the lens just above the ambient air temperature and so dew will not condense on the lens. They do require power, either from a battery (car type) or mains adapter.
Here are some examples from AstroZap and Dew-Not.
http://www.astrozap.com/pages/dew-strap.htm
http://www.dew-not.com/dew-not-desc-01.htm
Cheers
Dennis
nardes is offline   Reply With Quote
Old 22nd of November 2009 (Sun)   #5
masayako
masayako's Avatar
Thanks alot. Will look into it.
Cheers
Dennis
Old 23rd of November 2009 (Mon)   #6
PM01
Having the lens hood on helps a little bit. Also, the dew heaters help quite a bit but don't crank up the heat too much on them as it will change the focus point. Might not be critical on a wide angle though, but on a telescope it makes a difference.
PM01 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Exposure Comp. vs Long Exposure Kaptekarev Small Compact Digitals by Canon 4 19th of July 2009 (Sun) 18:22
Long Exposure. Long Save Time. 360° Canon EOS Digital Cameras 13 19th of July 2009 (Sun) 02:30
Long Exposure Help Name Pending... Nature & Landscapes Talk 3 14th of May 2009 (Thu) 04:20
Groton Long Point Long Exposure. Tom K. Nature & Landscapes 2 20th of January 2008 (Sun) 19:01
long exposure techniques...panning techniques... NationYell Canon G-series Digital Cameras 7 10th of October 2007 (Wed) 16:04
