#1 |
Thank you. I'm no longer monitoring this thread.
Greetings. First post in this forum. I'm trying to learn a bit about post-processing. As an exercise, I rescued an image shot with Canon 70-300 on XT. The image was soft, needed heavy cropping, and the subject had a shadow across its face. The result is technically rather weak - but has been a show-stopper when showing to friends as part of a slide show. The background bokek is disturbing to me - unless the image is viewed at a reasonable distance. Your opinion would be welcomed: should the background be blurred to eliminate the very fine pattern that makes me dizzy? Or is it just me? Last edited by Meanderthal : 7th of January 2010 (Thu) at 20:38. Reason: Closure |
| sponsored links |
#2 |
I don't know if additional blur would help it but you may want to try making it darker so that the highlights are reduced and the subject stands out more.
#3 |
Thank you, Ken. Something like the attached? It's a crude job with the burn tool, but lets me see that your suggestion is most helpful. Advice on how to work around hair would be appreciated.
| sponsored links |
#4 |
Very carefully?
I'm still learning, but one thing I've found is that you see every hair that gets covered/deleted while you're "painting" but the next day when somebody else is looking at it they are not going to notice anything so long as you don't overdo it. |
#5 |
Good point, Ken. A comforting thought: the ultimate measure of image quality at the amateur level is the emotion that the image elicits. I thoroughly enjoy myself at concerts by the local semi-professional symphony orchestra. There is joy and immediacy in the performances, and I don't notice faults as long as they are not gross. Which they never are.
I guess I have been lurking POTN so long, reading expert opinions, that my perspective on my own potential needs readjustment Should I need leads on working on "The Hair of the Dog", I'll post it in another forum. |
#6 |
You should be able to find info on working "hair of the model" in either the post-processing forum, the people talk form or the glamour/nude talk forum.
#7 |
OK, Ken, I'll browse the PP forum and, when ready, seek further advice there. Your company here has been appreciated.
| Thread Tools | |
| Display Modes | |
| Canon body opinion wanted | -g- | Weddings and Other Family Events Talk | 19 | 28th of November 2009 (Sat) 10:36 |
| Your opinion is wanted! | benton.sampson | Urban Life & Travel | 4 | 11th of November 2009 (Wed) 12:59 |
| Fireworks, Your opinion wanted | 10range | Urban Life & Travel | 1 | 4th of July 2008 (Fri) 23:32 |
| Opinion wanted on photo site | Transportithere | Presentation | 4 | 28th of July 2006 (Fri) 20:40 |
| Expert Opinion wanted ? | loebas | Wildlife | 14 | 24th of April 2005 (Sun) 16:02 |
