Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 27th of November 2009 (Fri)   #1
LowSpark420
LowSpark420's Avatar
Default Metering Question
Ok ~ this is something that has confused me for a good while. I think I am doing it right, but there are so many variables to photography, I have to ask.
Based on my camera, when looking through the viewfinder I see the information line at the bottom.
When metering for a "correct" exposure; let's say I am using the sky to set the exposure. I should basically be setting my ISO and aperture and then, while pointing the camera to the sky, adjust the shutter speed until the meter dial is showing the dead center...correct?
http://codphotography.blogspot.com/
___________________________________
Canon EOS Rebel XSi ~ Canon EF-S 18-55mm IS ~ Canon EF-S 55mm - 250mm f/4-5.6 IS ~ Canon EF 50mm f/1.8II ~ Canon 430 EXII Flash ~ Canon Off-Shoe Flash Cable ~ Kenko Extension Tubes (Full Set) ~ Delta Flash Bracket ~ Lowepro Flipside 400AW
LowSpark420 is offline   Reply With Quote
Old 27th of November 2009 (Fri)   #2
krb
krb's Avatar
Default Re: Metering Question
What you describe is the correct method for getting what the camera thinks is the correct exposure for the sky. You may find through experience that your camera will give better results if you expose a little more or a little less under those conditions.
-- Ken
Flickr
Gear list
krb is offline   Reply With Quote
Old 27th of November 2009 (Fri)   #3
JeffreyG
JeffreyG's Avatar
If you set the needle dead center while pointed at the sky the camera will have metered to make the sky a middle tone. Unless it is very close to dawn or dusk, the sky is generally not a middle tone, it is a very bright tone.
For mid-day if I was metering the sky I would probably set the needle to something close to +2 stops. If you set it to -0- the sky will look dull and the objects on the ground will be very dark verging on black.
My personal stuff:http://www.flickr.com/photos/jngirbach/
Commercial sports:http://girbach.zenfolio.com/
I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550
JeffreyG is offline   Reply With Quote
Old 27th of November 2009 (Fri)   #4
neilwood32
neilwood32's Avatar
If that is how you are metering, you might as well let the camera do it.
My way (not neccesarily the right way) is get a metering of the sky. Then same for the shadows. Decide on the important aspect of your shot and then make the decision of what to use depending on whether exposing that correctly will lose the highlights or shadows.
You meter can (and will be) misled by bright or dark objects. Meter on them at your peril.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
neilwood32 is offline   Reply With Quote
Old 27th of November 2009 (Fri)   #5
LowSpark420
That all makes sense - I just wanted to make sure that "technically" dead center on the meter scale (whether doing it yourself or letting the camera do it) is dead center.
Old 27th of November 2009 (Fri)   #6
Wilt
Wilt's Avatar
Technically, 'dead center' simply indicates that reading which the camera meter wants to render 18% overall average brightness, for the things seen within metering zone(s) selected!
That is one of the fundamental flaws of any in-camera meter. If the object in the metering zone is white, the meter will show an exposure which makes that white item to be 18% gray in the shot. If the object in the metering zone is black, the meter will show an exposure which makes that black item to be 18% gray in the shot. If the object in the metering zone is 80% light gray, the meter will show an exposure which makes that 80% gray item to be 18% gray in the shot.
Using the sky to take a reading can be a good surrogate for an average scene in bright sunlight. It is a poor surrogate for an average scene in the shade, too.
Metering an overcast sky can also give you a very erroneous reading! For example, right now the sky at my location is overcast and ISO 400 1/125 reads f/32...an incident light meter gives a reading of f/8, 4EV error if you use the sky reading.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 27th of November 2009 (Fri)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
This is what I use:
Need an exposure crutch?
Why?
Post #47
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
metering question? THE TROOPER General Photography Talk 9 27th of March 2008 (Thu) 05:09
metering question thelightofsound Small Flash and Studio Lighting 8 17th of March 2008 (Mon) 14:45
Metering Question dbiggs Canon EOS Digital Cameras 0 3rd of December 2006 (Sun) 07:24
Metering question twinsrus Canon EOS Digital Cameras 12 20th of August 2006 (Sun) 14:44
Metering Question Sageg General Photography Talk 24 24th of January 2006 (Tue) 20:59
