Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 14th of June 2005 (Tue)   #1
volcomnator999
Lightbulb help with broken SD300
i found this canon IXUS 4.0mp camera (SD300 in the states) and after inspectioning it i found out that the LCD was cracked...theres lines running from the upper-right hnd side down to the middle....and the case has a little dent...after opening it the part with the dent is not broken....and the liquid did not spill on the inside of the camera. it seems that it might have been thrown or dropped from a moving car because i found it in the middle of the street. I dont think it was ran over bucause the it right right smack in the middle. So any suggestions if i its worth fixing or not. does any know if theres any good repair shops in Los Angeles CA? thnx for the help...really appreciate it
volcomnator999 is offline   Reply With Quote
Old 14th of June 2005 (Tue)   #2
rent
rent's Avatar
Default Re: help with broken SD300
silly question: does it still work?
a broken LCD or some dents may not interfere with the camera's core functionality which is taking pictures. pop in a battery and see if it works.
if not, the repair cost is probably going to be the same as getting a new one. you might want to see if Samy's camera in LA (near farmer's market, i think) can give you a quote; or come down to irvine and visit the canon service center.
-alex
rent is offline   Reply With Quote
Old 14th of June 2005 (Tue)   #3
volcomnator999
well...it has a battery...and a 256sd card....when i press the power button nothing happens..its either something is broked inside or the batter is dead...i dont have a charger to test it, imma try and find someone that might have a battery or a charger..thnx for the help ill check out the samys camera,...i think i know where it is
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SD300 broken display drjack3 Small Compact Digitals by Canon 1 23rd of June 2007 (Sat) 13:40
POWERSHOT SD300 BROKEN DISPLAY drjack3 Small Compact Digitals by Canon 0 6th of June 2007 (Wed) 18:02
SD300 USB 1.1? information Small Compact Digitals by Canon 3 29th of July 2005 (Fri) 16:30
Help with new SD300 cnladd Small Compact Digitals by Canon 2 21st of March 2005 (Mon) 13:11
SD300 august23 Small Compact Digitals by Canon 6 11th of March 2005 (Fri) 15:40
