Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 20th of December 2009 (Sun)   #1
jacksonvillenp
jacksonvillenp's Avatar
Default first attempt at photomerge
Was out today and took some nice shots. When I got home I thought that 2 shots would be great combined. Never had done it before and thought I would give it a go. I did this without the aid of tut...sheer trial and error what do you think?
jacksonvillenp is offline   Reply With Quote
Old 20th of December 2009 (Sun)   #2
gibsonla
gibsonla's Avatar
Default Re: first attempt at photomerge
Was the girl on the right the one you merged in?
Michael L. Solomon
DP/AC/Colorist
www.SolomonM.com
gibsonla is offline   Reply With Quote
Old 20th of December 2009 (Sun)   #3
Pardes
Pardes's Avatar
You may want to extend the shadow of the pylon she is standing on in the right merge; otherwise it's easy to expose the trick. I like the idea and good for you flying by the seat of your pants without a tutorial!
Pardes is offline   Reply With Quote
Old 20th of December 2009 (Sun)   #4
jacksonvillenp
Yes the one on the right is the one I merged in. These are the original shots. She was actually standing on the same post for both pics. As you can see from shot #2 there was no shadow...it was underwater, LOL
Old 20th of December 2009 (Sun)   #5
vk2gwk
vk2gwk's Avatar
Very nicely done.
Cheers from Henk.
It is all in the eye of the beholder.....
5DMkIII, 50D, 24-105/1:4L IS USM + 100-400/4-5.6L IS USM + 50mm 1.4 USM + 580EXII + 430EX(as slave), reflectors, umbrellas and some more bits and pieces...
Have a look at my photos while I am still controversial Flickr!
vk2gwk is offline   Reply With Quote
Old 20th of December 2009 (Sun)   #6
sam4205
Great work....
5D Mark II | 5D Classic w/grip | 85mm 1.2L II | 70-200 2.8L IS USM | Canon EF 50mm f/1.8 | YN-465
sam4205 is offline   Reply With Quote
Old 21st of December 2009 (Mon)   #7
jhuckelberry
you need to work on the water a little more. you can see where the white foam disappears and reappears right next to her leg
Canon 7D / Tamron 17-50mm / Canon 50mm 1.8 / Canon 85mm 1.8 / Sigma 70-200mm 2.8 / 580EXii
Huckelberry Photography
My Flickr
jhuckelberry is offline   Reply With Quote
Old 21st of December 2009 (Mon)   #8
sue.t
sue.t's Avatar
Nice job with the merge! Sometimes, however, when working an image we get too focused on the detail and not enough on the big picture ... the horizon is not level.
Also, the fat shadow on the right pylon does not match the skinny pylon.
sue t.
10-22, 24-105 & 100-400 partnered with a 7D, plus a G12
Living in Yukon and travel to Alaska -- http://suethomas.ca/
sue.t is offline   Reply With Quote
Old 21st of December 2009 (Mon)   #9
DragonDan
DragonDan's Avatar
I'd clone stamp out the stray shoe on the lower LH. Otherwise (after horizon tilt) it's a fun shot!
Canon EOS 50D gripped; Tokina 11-16mm f/2.8; ∑30mm f/1.4; ∑105mm macro; 70-200mm f/4L; 430EX II
DragonDan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
After using photomerge in ACR 4.1 chauncey RAW, Post Processing and Printing 1 29th of July 2007 (Sun) 21:08
Photomerge in cs2 penfolduk RAW, Post Processing and Printing 1 7th of July 2007 (Sat) 06:03
Crater Lake from Mt. Scott... 1st Photomerge attempt slacker Nature & Landscapes 7 18th of July 2005 (Mon) 17:49
My First Photomerge Sydor25 Critique Corner 0 23rd of February 2005 (Wed) 17:34
