Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing > Computers
Reply
Thread Tools Display Modes
Old 25th of December 2009 (Fri)   #1
S-Man
S-Man's Avatar
Default Can you change "Open With" list titles in Mac?
When I right-click on a photo or something, then go down to "Open With" to choose which app to open it with, my CS4 has made an obscenely long title somehow taking up the whole desktop. As you can see, it looks like nonsense after it says CS4. All I need it to say at the most is Adobe CS4, or just be like CS2.
Anyone know how to change this mess?
Thanks!
S-Man is offline   Reply With Quote
Old 25th of December 2009 (Fri)   #2
René Damkot
Moderator
René Damkot's Avatar
Default Re: Can you change "Open With" list titles in Mac?
Open With > Other > select Application and tick "always open with".
Edit. Oops. I misread your post.
No idea on how to change thŕt...
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 25th of December 2009 (Fri)   #3
MaxxuM
MaxxuM's Avatar
You can do the following...
Go to -> Home/Library/Preferences
Find -> com.apple.LaunchServices
Delete it (make a copy if you like)
That folder holds the settings for all your software. If you have problems with corrupt or missing settings with programs this is usually were you would go to reset them to default.
Canon 7D & 60D With Grip's
Canon: EF-S 17-55 F2.8 IS, EF 70-200L F4 IS, EF 85mm F1.8
MaxxuM is offline   Reply With Quote
Old 25th of December 2009 (Fri)   #4
S-Man
S-Man's Avatar
^I deleted that (it's in the trash bin) but it's still the same...Do I need to restart?
Thanks for your help.
Old 25th of December 2009 (Fri)   #5
MaxxuM
MaxxuM's Avatar
Yep, the finder has to be restarted.
Old 25th of December 2009 (Fri)   #6
S-Man
S-Man's Avatar
Yeah, restarted and it's still as long as ever...
Old 25th of December 2009 (Fri)   #7
MaxxuM
MaxxuM's Avatar
Try this (for Snow Leopard only):
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister -kill -r -domain local -domain system -domain user
Just drag into Terminal window then hit Return then restart.
Old 25th of December 2009 (Fri)   #8
S-Man
S-Man's Avatar
MAn, I don't know what all that command line did, but it didn't fix the long title string on the "open with" menu...
I even ran Onyx and cleaned the caches and such, but no dice.
Someone mentioned that CS2, 3 and 4 add long strings like that. There HAS to be a way to fix it!
I really do appreciate your time MaxxuM.
Old 25th of December 2009 (Fri)   #9
S-Man
S-Man's Avatar
BOOOYAAAAAAAAAHHHHH!!!
Fixed baby!
This is what I did: I went into Finder>Apps> Adobe CS4 (folder)> Right-Click on CS4.app> Show Package Contents> Contents> Open info.plist
Then 6-lines down it stated what was in the "open with" string, so I removed it, restarted, and Voilá! Like a BOSS!
Thanks for y'alls help. You pointed me in the right direction MaxxuM.
Old 25th of December 2009 (Fri)   #10
MaxxuM
MaxxuM's Avatar
Cool, glad to toss out confusing Terminal commands Yea, I figured PS was putting the commands right back in after reboot after I tested it myself. Kudos to you for finding the plist yourself
Old 25th of December 2009 (Fri)   #11
BeritOlam
BeritOlam's Avatar
Glad you figured it out. I thought of that when I initially read your problem....but Christmas duties called me away for a few hours!
Blessed are the young, for they shall inherit the national debt. – Herbert Hoover
BeritOlam is offline   Reply With Quote
Old 26th of December 2009 (Sat)   #12
shooterman
village idiot, actually a genius!
Fixed baby!
Thanks very much! That had been bugging me for ages too.
Randy
ModelMayhem
shooterman is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
What should a camera strap say? "Sexy Beast", "Canon", "Pro", "Wedding Photographer" nemo man General Photography Talk 206 6th of June 2012 (Wed) 11:46
How to set my thread titles as "bold" font koigirl Forum Talk 7 19th of March 2009 (Thu) 17:29
Simpleviewer and Picasa2 "Titles"? taygull Presentation 5 13th of December 2006 (Wed) 11:00
"A" list out for dinner in Carmel (Nicole Kidman and Rupert Murdoch) mikegoat People 16 2nd of August 2006 (Wed) 10:56
